EQX - AudioControl Pre-Amp Equalizer/Crossover (sold,thanks modcom....)
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/191466
    EQX - AudioControl Pre-Amp Equalizer/Crossover.........sold
    Retail Price $379.99
    Description:
    AudioControl designed the EQX to make your car audio system sound better. This 2-channel equalizer features 13 bands of adjustment for sonic fine tuning, along with a 2-way crossover that allows you to add a powered sub to your setup. And speaker-level inputs allow you to connect the EQX to just about any car stereo, even to factory amps up to 400 watts.
    Most car audio problems occur in the bass frequencies, so the EQX gives you six bands of equalization between 31.5 and 180 Hz, along with a rolloff filter that keeps bass below the range of human hearing out of your subwoofer system. You also get seven bands of equalization at octave intervals from 250 Hz all the way up to 16,000 Hz.
    Features:
    dual 13-band equalizers with level matching controls
    * gray steel chassis with gold-plated RCA jacks
    * Linkwitz-Riley 2-way crossover (90 Hz at 24 dB/octave)
    * top-mounted controls for easy adjustment
    * preamp- and speaker-level inputs
    * 6-channel outputs: full range, high-pass, and low-pass
    * balanced inputs eliminate noise
    * 33 Hz subsonic filter eliminates extreme low bass (rolloff point can be adjusted with optional module)
    * EQ points: 31.5, 45, 63, 90, 125, 180, 250, 500, 1000, 2000, 4000, 8000, 16000 Hz
    * frequency response: 10 to 20,000 Hz
    * signal-to-noise ratio: 110 dB at full output
    * maximum output level: 9.5 volts
    * fuse rating: 2 amps
    * size: 6-15/16"H x 8-15/16"W x 1-1/4"D
  2. clickbet88.com
    3 Days 6 Hrs 43 Mins 11 Secs
    bosss,, brape an nie brg,, ex servis gakkk...
    Barang no ex service,pm sent yach bos..
    Thanks...
    klaten,jogja,solo
    4 Hrs 35 Mins 52 Secs
    nett brapa bos?
    Pm sent bos jockger,thanks...
    PM net ke smg berapa Boss ??
    pm sent bos bayu,thanks.....
NGK Busi GT Radial
  1. wts: equalizer 30band audiocontrol
    By leon9 in forum Power Amplifier
    Last Post: 30th May 2012, 17:10
  2. wts: equalizer audiocontrol
    By leon9 in forum Bursa Audio Lainnya
    Last Post: 5th May 2012, 01:07
  3. WTS audiocontrol EQT equalizer
    By LRP in forum Bursa Audio Lainnya
    Last Post: 29th May 2011, 23:09
