WTA : Monoblock AudioQuart AQ A3000.1D Dan Agako 4500D silver
Results 1 to 10 of 11
  • Short URL:  http://modifika.si/191452
    Djakarta...
    4 Wks 1 Day 12 Hrs 19 Mins 59 Secs
    Maap ni agan2.... newbie numpang nanya Antara 2 power itu bagusan mana yah....
    Ada yang punya spec rated powernya gk... koq saya baca Agako Agako XT-4500D (AK4500D Power Monoblock Class D) maxnya 2000 watt koq sama Agako CA2000D..... sama2 2000 watt harga beda.....
    Kalau yang AudioQuart ada yang punya pengalaman atau data soal power ini ?
    Mohon pencerahannya agan2 sekalian.....
    08999942533, 02140389555; MGK Kemayoran Lantai 6 Blok E5 No. 2; Bursa Mobil Gading - Kelapa Gading
    1 Yr 9 Mths 1 Wk 4 Days 8 Hrs 11 Mins 54 Secs
    Quote Originally Posted by 3dwind View Post
    XT4500D Power Monoblock Class D 4500 watt max Rp. 5.000.000,-
    Mono block digital subwoofer amplifier Class D
    Remote bass boost at 60Hz control :0-18dB
    Balanced low input & high input
    Line out ( by pass )
    Variable Subsonic filter : 15~30Hz, 18dB /oct
    Variable low pass filter : 40~230Hz, 24dB/oct
    Variable bass boost at 60Hz control :0-18dB
    Variable phase control 0~180
    Protection circuit for thermal, short circuit and reverse polarity connection of Battery
    Frequency Response : 15Hz~250KHz
    RMS power at 4 OHM Stereo : 600W
    RMS power at 2 OHM Stereo : 1200W
    RMS power at 1 OHM Stereo : 1800W
    Max Power : 2000W
    T.H.D : 0.1%
    Input Sensitivity : 200mV~4V
    Input Impedance : 10K ohms
    Damping Factor >200
    S/N Ratio : 100dB
    Kalo sy mending Agako aj yg ud terbukti badak bwt SPL
    Tenaga tetep beda CA 2000D ama XT4500D krn bda d hambatan aj
    Kalo CA 2000D cuma bs kuat smpe 2 ohm aj, kalo XT 4500D silahkan hajar smpe 1 ohm
    Djakarta...
    Bingung lagi nih agan2
    Bingungnih agan2.... itu kan spec nya stereo 1800 watt...maksudnya teh kumaha... kan mono ( satu keluaran )
    Apa maksudnya stereo dua keluaran masing2 1800 watt... jadi bisa bridge lagi donk.... gimana agan2 ??
  5. 15th June 2010, 10:03
    Reason
    SPAM
  6. #4
    Setau sy kalo monoblock gag bs d bridge ky pwr 4 ch, psti sama aj. Bridge itu artiny d link (pke 2 pwr)
  7. #5
    cibubur
    5 Days 10 Hrs 36 Mins 34 Secs
    uda ga usah pusing2 bozzz.... lm3200 sama agako tenaga mirip2, kalo diukur db, angkat 1 subw, 2 sub ataupun di link 2 pwr angkat 2 sub tenaganya sama, jd tergantung hrga sama tempat buat naro sub. lm lbh pnjang n gak lebar, agako ga sepanjang lm tp lbh lebar dr lm, selamat mencoba boz
  8. #6
    Quote Originally Posted by ROY XENIA View Post
    Nah betul tuh, tergantung sesuai selera yg mau beli aj
    hehehe
  9. #7
    1 Day 11 Hrs 30 Mins 51 Secs
    Quote Originally Posted by andyanto_wibowo View Post
    Max Power : 2000W
    T.H.D : 0.1%
    Damping Factor >200
    S/N Ratio : 100dB
    up lagi ah.. Skalian tanya, dr spek di atas kan power di 1 ohm 1800w, max power 2000w. Nah klo sub yg di pake 2 bj concept zt masing2 1000w continues 1200w max 2x4 ohm pararel jd 1 ohm, mono yg agako 4500d tuh kuat ga yah? Thank buat jawab pertanyaan nubitol, hehe
  10. #8
    up lagi ah, blum ada yg jawab
  11. #9
    Quote Originally Posted by roodeyz View Post
    Kuat koq... Ud bnyk yg pke gt
    Itu sub jg gag murni 1000 watt continious koq...
  12. #10
    sip.. Thank gan
Mega Glodok Kemayoran
  1. [WTS] AGAKO XT-4500D (2ND)
    By dimsaudio in forum Power Amplifier
    Last Post: 16th January 2014, 20:56
  2. SALE MONOBLOK AGAKO 4500D
    By abello in forum Power Amplifier
    Last Post: 4th May 2011, 01:14
  3. agako 4500D vs VD2600s
    By inal in forum Diskusi Power Amplifier
    Last Post: 20th February 2011, 19:29
  4. wts monoblok agako xt 4500d
    By masbob in forum Power Amplifier
    Last Post: 9th December 2010, 14:53
  5. WTS : agako XT- 4500D, HDT 1200.1
    By 3dwind in forum Power Amplifier
    Last Post: 13th June 2010, 09:21
