Hi-end FOCAL UTOPIA 5-WS 5 inch Subwoofer.............sold
Size 5.38"
Nominal Power Handling What is "Nominal Power Handling"? 80 Watt RMS
Powered What is "Powered"? Non-Powered
Technical Features
Peak Power Handling 160 Watt
Frequency Response 45 Hz - 2.5 kHz
Sensitivity 87 dB
Impedance 5 ohm (Dual Coil)
Mounting
Enclosure What is "Enclosure"? Non-Enclosed
Top Mounting Depth 2.91 In.
Focal 5WS Subwoofer - Test Report
by CAE, Mar 01, 2002
Share
Computer Simulation Data (4 woofers series/parallel) Vented Box 1 (ft3) 0.71 (no fill material) Box Tuning Frequency 50.5Hz -3dB for vented box #1 52.5Hz Voltage to achieve Xmax + 15% 54V SPL at Xmax +15% 117.5dB Vented Box 2 (ft3) 0.96 Box Tuning Frequency 50.2Hz -3dB for vented box 46.5Hz Voltage to achieve Xmax + 15% 46V SPL at Xmax + 15% 116.5dB
Measured T/S Parameters Nominal Impedance (Ohms) 6 Revc (Ohms) 5.13 Sd (cone area in sq. Meters) 0.0077 Cone Diameter (inches) 5.375" BL (motor strength in Tesla Meters) 7.25 Vas (in Liters) 11.3 Cms (micrometers per Newton) 1344.62 Mms (Grams) 15.8 Fs (Hz) 34.5 Qms 4.08 Qes 0.34 Qts 0.31
Power and Excursion Data Sensitivity (2.83V/1M in dB) 85.0 Continuous Power Handling(Watts RMS) 60 Peak Power Handling (Watts) 120 Xmax ([coil length-gap height]/2 in mm) 8.0 Xmax + 15% (mm) 9.2
Computer Simulation Data (single woofer) Vented Box 1 (ft3) 0.18 (no fill material) Box Tuning Frequency 50.5Hz -3dB for vented box #1 53.0Hz Voltage to achieve Xmax + 15% 28V SPL at Xmax +15% 106.dB Vented Box 2 (ft3) 0.24 Box Tuning Frequency 50.2Hz -3dB for vented box 46.5Hz Voltage to achieve Xmax + 15% 25V SPL at Xmax + 15% 105.0dB
Music Selection Artist & title Music Type Points Possible Focal Utopia 5WS Harry Connick Jr. We Are in Love Big Band 10 7 10,000 Maniacs Peace Train Pop 10 9 Macy Gray Harry R&B 10 8 The Cranberries When You're Gone Rock 10 7 Shoanna Z Left Wing Trickery Rap 10 7 Total 50 38
So, I went for some rap. I broke out Shoanna Z's album "Racism Exposed", "NBC, ABC, CBS, CNN, AKA Left Wing Trickery". This track features massive energy at 40Hz. While the 5WS did not have the authority of larger subs on this opening passage, it is one of the tightest and most "impactful" subwoofers that I have ever used. I would love to hear this again with eight of these bad boys instead of just four.
Now I wanted to see what kind of "Jolt Factor" the Utopia 5WS subwoofer could reproduce. (The term was coined by my friend and teacher Rob Greene; he uses it to describe how well an audio system can jolt you by a surprise hit of volume.)
