DIGITAL DESIGN 512b (seri terbaru dari digital design USA) kondisi BARU..........@2,
Rgotogel Simota 36Goal.com
  • Short URL:  http://modifika.si/191370
    Cool DIGITAL DESIGN 512b (seri terbaru dari digital design USA) kondisi BARU..........@2,
    DIGITAL DESIGN 512b (seri terbaru dari digital design USA) kondisi BARU..........@2,3jt
    price list : USD 449
    DD500b
    The newly upgraded 510b and 512b sub[/SIZE]woofers bring DD impact and durability to the most affordable price ranges we've ever offered. You still get the hand built, high performance quality at a price within every budget. The 500b Series was designed to optimize performance from amplifiers in the 100-400 watt RMS range. Not everyone is going to try to crush their tonsils with the latest bass-jacked MP3, but that doesn't mean one should have to settle for lower quality parts or design.
    The 500b series woofers benefit from the highest quality parts available, close production tolerances, and hand built quality as do all DD woofers. The motor and moving systems have been designed to get higher efficiency from lower powered systems. We found ways to reduce mass from the cone, surround, spiders and voice coil which raises the efficiency on a given level of power. The suspension stiffness and excursion capability were carefully dialed in through many real world test samples. The result is a very fast woofer capable of delivering surprising output from modest power sources.
    The 500b Series feature multiple layers of durable cloth in the spider system, our exclusive laminated lead wires into the spider layers, double laminated half-roll surround, non-pressed cone and a motor system modeled after the 3500e Series woofers. The 510b and 512b are very easy to use in vented, TLs, and specialized band-pass boxes and are the perfect presents in gift boxes. Now there aren't any excuses to get anything less than a DD system in every car.
    We recommend to allow at least several weeks of playing time to break in DD Woofers, full break in may take many months. DO NOT play subwoofers at max amplifier power in the first couple of days, give the suspensions a chance to loosen up. As the suspension breaks in, the subs will play lower and louder.
    After you give the woofers a chance to break in (you'll know when this happens because the woofers will be playing lower and louder) you can start to look at port changes to alter the sound to your personal taste and your vehicles acoustic loading conditions
    Features
    * Optimized for 100-300 watt systems
    * Multi-layer spiders
    * Laminated surround
    * Double stack magnets
    * High-temp voice coil
    * Laminated tinsel leads
    * Hand-built quality
    * Rubber Magnet Boot
    SPECIFICATIONS
    Series 500b
    Voice Coil Diameter 2.0"
    Magnet Weight 90 oz
    Power Handling RMS/Peak 300/1200
    Suspension 50 mm
    Nominal Impedance 4.0 Ohm
    DC Resistance 3.4 Ohm
    Model 512b
    Rec Box (cubic ft) 2.5
    Port Area (sq in) 40
    Port Length (inches) 22
    Woofer Diameter 12"
    Free Air Resonance 36 Hz
    Qts 0.433
    Qes 0.499
    Qms 3.29
    Vas 60L
    Sensitivity 89dB
    Shipping Weight 14 lbs
    call
    081388575788
    up..........................
  1. Replies: 6
    Last Post: 21st June 2012, 01:39
  2. Replies: 4
    Last Post: 23rd October 2010, 13:58
  3. Replies: 32
    Last Post: 17th September 2009, 06:36
