ALPINE 1din center speaker SBS-05 DC + MEI -PA7420 Amplifier............1,1jt
  • Short URL:  http://modifika.si/191293
    Wink ALPINE 1din center speaker SBS-05 DC + MEI -PA7420 Amplifier............1,1jt
    Planning to install a mobile car stereo video structure in your vehicle along with a double sized car stereo opening in your dash then you can rely on Alpine to get a better solution for your installing process. With the new product from Alpine called SBS-05DC you can make a cleaver solution in installing a center channel speaker to your vehicle. A soft dome tweeter along with double midbass drivers is fixed into the 2? tall enclosure that can perfectly fit in the dash as it would offer perfect sound from the multi channel sound system.
    As you mount the speaker below or above your aftermarket car stereo you will appreciate the crisp, enhanced sound effect, clear movie dialog and detailed highs. The Alpine SBS-05DC is a very important part to create a clear 5.1 digital surround sound in your car.
    Alpine SBS-05DC which is a center channel speaker features an excellent quality mobile speaker that can be mounted in the dash with dual 2″ x 1.6″ egg-shaped mid-range drivers along with a balanced soft dome tweeter of 1?. The product is exclusively designed to be used as a center channel speaker with a multi channel sound surround system. Benefiting from a perfect design the speakers is self mounted in the dashboard of your vehicle with the additional mounting base. The design would perfectly mount in the idle DIN opening of your vehicle. The speakers can be easily mounted in Euro DIN dash opening or in an ISO DIN. To mount in a Euro DIN mode you can use the gasket pads and mounting sleeve to install the speakers and to mount in an ISO DIN you can use the supplied four screws to protect the speakers with the dash with the help of factory brackets.
  2. Hokinusa
    Bogor
    23 Hrs 16 Mins 32 Secs
    Bro Christ,
    Kalo yg ini Rp. 750 rb boleh kan?ditunggu kabarnya
    trims
    pm sent bos,thanks......
    up..........................
MBtech Venom 300x250
  1. [WTS] ALPINE CENTER CHANNEL SPEAKER + AMPLIFIER (2ND)
    By dimsaudio in forum Speaker - SubWoofer
    Last Post: 26th July 2011, 14:15
  2. WTS : Speaker Center Alpine + Speaker AVT belakang
    By hendrasudjono in forum Speaker - SubWoofer
    Last Post: 6th September 2010, 20:00
  3. WTB : Speaker center alpine
    Last Post: 30th March 2010, 07:59
  4. Replies: 0
    Last Post: 1st February 2010, 18:34
  5. Replies: 1
    Last Post: 22nd October 2009, 07:54
