Phass ALNICO 6,5" midbass driver MW 6512AL-N & MD-1096.......
Results 1 to 10 of 18
  • Short URL:  http://modifika.si/191276
    Wink Phass ALNICO 6,5" midbass driver MW 6512AL-N & MD-1096.......
    Phass ALNICO 6,5" midbass driver MW 6512AL-N......
    Phass ALNICO 6,5" midbass driver MD 1096.......
    PHASS / ファス MD 1096 定価 81,900円(税込)
    PHASS MW 6512AL-N......Price 621.23€
    MW 6512 AL-N
    New PHASS MW6512AL-N also uses Alnico magnet which is increased the magnet power and the one piece construction paper cone which features rigidity and optimal curved figure. As the main altered points, a gathering of small column type alnico magnets has been changed to a ring type alnico magnetwith one piece construction. And the flat slanted cone figure has been changed to the curved figure of cone with keeping the same cone material. As the results, MW6512Al-N has achieved the wider frequency range in comparison to previous model, and it can reproduce more profound and dense sounds and show the connecting balance with various type tweeters in condition.
    The midbass drivers of Phass’ new MW 6512AL-N drivers. They are 6.5” diameter woofers that feature a unique alnico magnet motor. Alnico, which is short for aluminum-nickel-cobalt, is a more rare and expensive type of magnet that produces a stronger magnetic field than typical ferrite pieces.
    Features:
    Alnico magnet
    One piece construction paper cone
    52 mm diameter voice coil
    Specification:
    Fs:80 Hz
    Efficiency: 85 dB
    Frequency response: 80 - 4,000 Hz
    Phass MD1096 Alnico midbass. The light weight and durable natural fiber(paper) cone with the optimal internal loss, and the corrugated natural fabric edge which are produced Japanese traditional skilled craftsman, the excellent Alnico magnet performs clean magnet field, CNC lathed precise metal part, they accomplished detailed and dynamic sounds with the exact music information.
    new price :
    MD 1096 6.5" mid bass specifications:
    Music power: 120W;
    Sensitivity: 87dB;
    Frequency response: 70-7,000Hz;
    Outer dimension: 165mm;
    Fixing hole: 142mm;
    Installing depth: 58mm;
    impedance: 6ohm
    Made in Japan
    call
    081388575788
    21 Mins 3 Secs
    pm netnya bro untuk MD 1096 nya
    Pm sent bro,thanks...
    harga berapa bos
    pm sent bro,thanks........
    bintaro-cikampek
    3 Days 22 Hrs 4 Mins 50 Secs
    Quote Originally Posted by hmhm View Post
    sama bos... minta pm... thanks...
    pm sent bos,thanks....
    1 Day 12 Hrs 17 Mins 26 Secs
    Ko, yg cocok ama at28 yg mana ko? Di hrg brp? Thks
    Md1096 bos,harganya 5,25jt nett bos,itu sudah last stock bos,brg udah hampir habis bos,tinggal sisa 1 set bos,thanks..
    Bos mw6512al hrga brp? Di pm in dong bos
  1. Replies: 1
    Last Post: 1st October 2012, 20:21
  2. FoR SAlE **** MidBass PHASS ALNICO 6,5 inch *****
    By bang-t in forum Speaker - SubWoofer
    Last Post: 25th June 2012, 11:57
  3. Replies: 19
    Last Post: 28th July 2010, 06:57
