SEAS tweeter spec sama dengan 9700 (sold out,thanks modcom..)
Results 1 to 6 of 6
  • Short URL:  http://modifika.si/191263
    SEAS tweeter (spec n suara persis sama dengan scanspeak 9700).....sold
    suaranya dynamic dan detail,top end nya ok.....
    ScanSpeak D2905/9700 28 mm Dome Tweeter
    The Scan-speak D2905/9700 uses the same hand coated dome and voice coil of the D2905/9500, but uses the motor system of the Revelator. The Symmetric Drive technology eliminates almost all electrical phase shift. The carefully machined top plate minimize air noise and compression. Copper caps act as heat conductors. High power handling is achieved without ferrofluid and improves micro-dynamic linearity. The tweeter has excellent dynamic and detailing capability.
    TECHNICAL DATA of SEAS TWEETER or SCANSPEAK 9700 :
    Sensitivity 2.83V/1M 89.5dB
    Free air resonance Fs 500 Hz
    DC resistance 4.7 W
    V.C. inductance 0.01 mH
    Power 225W@2.8kHz
    Effective cone area 8.5 cm2
    V.C. diameter 28 mm
    Lin. & max. excursion 0.4/ 1.5 mm
    Air gap flux density -
    BL 3.5 Tm
    Moving mass incl. air 0.45 g
    call
    081388575788
    up..........................
    1 Wk 2 Days 6 Hrs 27 Mins 49 Secs
    SOLDDDDDDD
    Bexazi ..
    da habis yah
    iya bos fully lebay,sorry yach bos..
    thanks yach dhan...
  1. SEAS Orchestra tweeter (sold,thanks modcom....)
    Last Post: 25th January 2010, 13:27
  2. Replies: 30
    Last Post: 29th October 2009, 14:59
