Phoenix Gold Xenon X1200.1 (1 x 1200W @ 4, 2 and 1 ohm)..........sold
Xenon ( zE'nän ) N. Greek. 1: A colorless, odorless, highly unreactive gaseous element found in minute quantities in the atmosphere, extracted commercially from liquefied air. 2: A whole new breed of competition-level car audio gear from Phoenix Gold.
Get ready for a revolution among stanch audiophiles. Hard-core competitors swore that nothing could top Phoenix Gold's Titanium series amplifiers, but they were wrong. The new Xenon series changes all the rules and breaks all the molds in both ground-pounding SPL and purist SQ. Audiophile technology abounds, with ultra-efficient Class D topology, ultra-low ESR capacitor bank, and MOSFET output transistors. Each Xenon model features all new XeFLOW thermal management with variable speed fan cooling, XeTUNE signal processing with 24dB per octave continuously variable crossovers, and XeLOAD circuitry for full power into any load from 4 ohms to an insane 1-ohm. The LPL (Low Pass Level) port allows for optional remote level control, and the RMD (Remote Monitor Display) port allows for optional voltage monitoring. Exotic sports car-inspired cosmetics include side and top-mounted vents with expanded metal highlights, and the unique rubber grommets that hide power and speaker connections are an industry first. Cast aluminum PG badge is backlit with Phoenix Gold's legendary Superbrite blue LED.
Please note that Phoenix Gold amplifiers and speakers are only shipped to destinations within the USA.
XeTUNE™ – Advanced input and signal processing circuitry
* Top-Mounted Controls
* 24 dB / Octave Crossover
o Continuously Variable from 40 Hz to 400 Hz
o 41-Detent Potentiometers for Precise Settings
* Continuously Variable Subsonic Filter (5 Hz to 55 Hz)
* Twin-T Variable 0 – 18 dB Bass Boost at 45 Hz
* Auxiliary Outputs Route Full Range Signals
XeFlow™ – Thermal feedback system with output optimization
* Bottom-Mounted Extruded Aluminum Heatsink
* Expanded Metal Mesh Intake & Exhaust Vents
* Ultra-Quiet Variable Speed Fan
* Temperature Monitoring with Automatic Output Optimization
* Superbrite 5mm LED Power Indicator
XeLOAD™ – Full power with automatic load sensing
* Load Sensing Optimizes Power Supply and Output Stage
* Maximum Power Output From 1 - 4 Ohms
* Class D Circuit Topology For Less Electrical System Strain
* 80% Average Power Efficiency Means Less Wasted Heat
* Direct Insert Speaker Terminals Accept Up To 8 Gauge Wire
* 4 Gauge Power Terminals with Removable Rubber Grommets
* Fully CEA-2006 Compliant Power Ratings Ensure Accurate Specs
* Optional LPL44 (Low Pass Level) Controller Allows for Driver's Seat Adjustment of Bass Volume
* Optional RMD (Remote Monitor Display) Allows Monitoring of the Amplifier's Battery Voltage, Power-On, and Thermal / Overload Status
* Requires external 100A fuse, available separately
Subwoofer Mono Amp Specifications
* Amplifier Type: Mono
* RMS Power: 1200W x 1 @ 4 ohms
* THD at 4-Ohm RMS Power: n/a
* Bridged RMS Power: 1200W x 1 @ 2 ohms
* Speaker Level Inputs: no
* Preamp Outputs: yes
* Built-In Crossovers: LP
* Bass Boost: 0 - 18 dB
* Frequency Response: 20-300 Hz
* Signal to Noise Ratio: > 90 dB
* Fuse Rating: 100 amps
