Legend n Rare Hi-end Couple ORION XTR-100
Results 1 to 10 of 34
  • Short URL:  http://modifika.si/191134
    Exclamation Legend n Rare Hi-end Couple ORION XTR-100
    One of the best, clearest sounding,and most sought after amp Orion ever made.Orion debuted it in '91 for $1350 each.
    Orion XTR-100 and XTR-200 they are top notch amplifier's "The best of the best." They are superior to the XTR-475, XTR-2150, and even the stunning 24kt GSX-300 that I was using prior to acquiring them.
    The Orion NT100 and NT200 were the predecessor's to the XTR's. Same PCB's just a purple/black anodizing to the heatsink versus the red/black. The specifications are identical according to the user manuals.
    The XTR 100 and 200 were world class amps, musically accurate, Powerful and the best of the best.
    If I could get hold of an XTR amp, i would give caddys and anz left nuts for it!!! AWESOME AMPS!!!!!!
    Orion XTR-200 Red/Black marbilized Dual Mono Block super ultra quality amplifier. .0005% THD, 1000 damping factor, 115db S/N Ratio.
    Here are a matching pair of XTR dual mono-block amplifiers. They are exactly the same (as you will see in the pictures) as the NT series amplifiers, aside from the red marbling instead of purple marbling in color.
    If you don't know what these amplifiers are, then you should take some time and go read the manuals on Orion's website. Link to manual http://www.orioncaraudio.com/Support...n%20Manual.pdf
    But here are the specs for those that are cliff-notes kind of people:
    XTR/NT100
    Power:
    50W x 2ch @ 4ohm on 12V battery [rated]
    100W x 2ch @ 2ohm on 12V battery [rated]
    200W x 1ch @ 4ohm on 12V battery [rated]
    400W x 1ch @ 2ohm on 12V battery [rated]
    800W x 1ch @ 1/2ohm on 12V battery [rated]
    THD: 0.005%
    Slew Rate: >500 Volts per microseccond
    Output Damping: >1000
    S/N w/balanced input: 112dB
    Power Bandwidth: 6Hz to 1000kHz +/- 5dB
    Idle Current: 1A
    Full Power: 28A @ 13.6V
    EXTREMELY UNDERATED!!!
    XTR/NT200
    Power:
    100W x 2ch @ 4ohm on 12V battery [rated]
    200W x 2ch @ 2ohm on 12V battery [rated]
    400W x 1ch @ 4ohm on 12V battery [rated]
    726W x 1ch @ 1.15ohm on 12.5V battery [measured]
    983W x 1ch @ 1.15ohm on 14.4V battery [measured]
    THD: 0.005%
    Idle Current: 1A
    Very conservatively rated at 100W X 2 @ 4 ohms. 400W mono bridged at 4 ohms.
    PRICES: Obviously, I will entertain REASONABLE offers, low-balls will be... not
    XTR100 - $750
    XTR200 - $750
    NT200 - $600
    sorry,real pictures will be uploaded soon.....
    here's some pictures from other sites :
  2. Jayapoker
    2 Days 56 Mins 4 Secs
    berapaan nih ?
    Pm sent bos,thanks...
    Jogjakarta
    10 Hrs 38 Mins 9 Secs
    PM harga dan kondisinya gimana Broo?
    pm sent bos fabri,thanks........
    4 Days 8 Hrs 1 Min 15 Secs
    pm net donk bos christ?
    pm sent bos ricky,thanks......
    surabaya
    1 Wk 21 Hrs 18 Mins 35 Secs
    waduh bos barangnya makin sip aja nih.........
    bisa aj nich bos,thanks yach bos.........
    3 Wks 5 Hrs 50 Mins 40 Secs
    barang rare nii... mantapss...
    UP lg.....
Mega Glodok Kemayoran MBtech
  1. honda legend V6 2,7 rare item
    By kresna_dj in forum Honda
    Last Post: 23rd November 2011, 11:07
  2. Replies: 242
    Last Post: 16th December 2010, 11:10
  3. Replies: 72
    Last Post: 6th January 2010, 06:36
  4. FS : The legend Sony ES- CDX C90 ( rare ) ALL SOLD
    By jeam in forum Head Unit & Processor
    Last Post: 7th August 2009, 23:44
