US AMPS US-100HC chrome edition (new model) kondisi muluuus........sold
link item yang sama n lagi dijual di ebay :
http://cgi.ebay.ph/US-AMPS-100HC-2-C...item19ae5e3933
High Current Amps
USA-50HC $423.00
USA-100HC $606.25
Tube Amps
TU-600 $461
TU-4360 $44
These amps were some of the first to bridge the gap between sound quality and high current spl application, and did both splendidly, hence the legendary reputation of the old school US AMPS. If you are reading this I'm not telling you anything you don't already know about these. If you think the specs I'm about to list are impressive, you should hear this amp playing.......!
HC 100
100% USA Designed, Manufactored, and hand assembled
Pure A/B Class Operation w/matched Bipolar outputs
(12 volt DC rating)
50 watts rms x 2 @ 4 ohms
100 watts rms x 2 @ 2 ohms
200 watts rms x 2 @ 1 ohm
400 watts rms x 2 @ 1/2 ohm
800 watts rms x 1 @ 1 ohm
(with 14.4 volts DC and 10 volts input)
over 1200 watts rms @ 1 ohm. These amps were extremely underated
Total Harmonic Distortion: .009%
IMD: .03%
Signal to Noise Ratio: 115db!!
Freq Response Capability: 5hz to 50khz
Slew Rate: 150Vus
Input Sensitivity: 10 volts
Inline fuse recommended: 100 amps
Competiton use: 225 amps
Dampening Factor of greater than 1000!!
Length: 18 inches
These amps have it all, sleek refined looks, sound quality that most amps today still cannot touch, and power to drive low impedance loads. So how many subs can you run on this one? How many can you wire up to 1/2 ohm!!!
call
081388575788
