Pioneer FH-P8800 24 bit Double-Din CD & Cassette Player.............
  • Short URL:  http://modifika.si/191082
    Arrow Pioneer FH-P8800 24 bit Double-Din CD & Cassette Player.............
    Pioneer FH-P8800 24 bit Double-Din CD & Cassette Player with Motorized Front Panel (Made in Japan) kondisi muluuus,optik bagus............1,5jt
    Product Description
    A new luxurious design of the Pioneer FH 8800 thrives on aluminum 'slide-flap' front panel, blue colored back-light display for easy recognition and higher visibility The present situation of all sources can be easily read at a glance. With the combination of the green colored LED that lights up the control buttons, a blue colored LED has been applied in the volume knob and cross-control key for higher visibility recognition at night. The green and blue LEDs will illuminate the whole car cabin. A wood grain panel has been applied in the CT slot that is hidden behind the 'slide-slot' front panel. When the user opens the motorized front panel, the wood grain panel will emerge from behind, to show another luxurious touch. The Control Keys have been allocated in a convenient order based on the frequency of use. The main controls have been centralized in the 'cross-control key'.The state-of-the-art technologies used bring a high quality sound. Pioneer FH 8800 has a built-in 45W x 4ch amplifier, which is the most powerful level in the industry, that can reproduce a clear high quality sound with a low distortion level equal to that of a component amplifier. 16bit based digital signals of MDs are first converted to 20bit data, then they're transferred through the DPS circuit and the signals are again converted to 24bit based signals to result in a real, high-quality sound. The 'Legato Link Conversion' will restore the rich harmonics and overtones (over 20kHz) that were lost in the CD and MD recording process. By using the enclosed microphone, the equalization can be set at its best to fit any acoustic condition in the car cabin, to reproduce the best quality sound.
    Basic Features
    # Blue-Back Display with CFL Backlight
    # Cellular/Navigation Mute Interface (Cellular Mute requires optional CD-CM1 Wireless Cellular Mute)
    # Wireless Full-Function Smart Remote Control (With Mounting Kit)
    # Fold Down Face: Motorized Front Panel
    # MOSFET: MOSFET45 (45Wx4-Channel High Power)
    Built-In DSP/EQ
    # 13-Band Auto-EQ (1 curve, Microphone Included)
    # EQ Memory: 2 User, 1 Factory Preset
    # Source EQ Memory
    # Graphic Equalizer: 13-Band Graphic Equalizer
    # Listening Position Control: Listening Position Selector (FL/FR/F/ALL)
    Cassette Playback
    # Music Search & Repeat
    # Tape Guard with Key-Off Pinch Roller Release
    # Dolby Noise Reduction: Dolby® B Noise Reduction
    # Full Logic Controls: Full Logic HPX Dual-Groove Tape Mechanism
    CD Playback
    # AGC (Automatic Gain Control) for Optimum CD Tracking Performance
    # Disc List
    # CD Text: 10-Character Display for Disc Title Memory & CD Text (SCD & MCD) (with Scroll)
    # CD Text: CD-Text Decoder (for use with CD-Text encoded CD’s)
    # CD-R and CD-RW Playback: Playback Compatible with Digital Audio CD-R (when disc is finalized)
    # D/A Converter: 24 Bit D/A Converter with Legato Link™ Conversion
    # Disc Title Memory: Disc Title Memory (48 Discs)
    Inputs and Outputs
    # Pre-Amp Output Voltage: RCA Preouts (x3 pair) (Front/Rear + Subwoofer) (2V)
    # Subwoofer Level Control: Sub-Out Crossover with Level Control (50/80/125Hz, -18dB/oct.)
    IP-Bus System Control
    # 6 & 12 Multi-CD Players
    # TV Tuner (GEX-P7000TV)
    # Voice Commander (CD-VC50 & CD-VC60)
    Tuner
    # 24-Station/6-Button (18FM/6AM) Presets
    # Supertuner III™
    # Best Station Memory: BSM (Best Stations Memory)
    call
    081388575788
  2. Hokinusa
    PERTAMAX BOS... HARGA NET DUNK... 800 rb ane mau deh... caLL aja gan kalo mau lepas 0818848815...TQ
    up.........
  1. [WTB] Head Unit Standar Avanza G 2008 ke atas (Cassette Player)
    By Hzhou in forum Head Unit & Processor
    Last Post: 1st March 2011, 11:02
  2. Head Unit Double DIN PIONEER FH-P5000 MP (CD/MP3/Cassette, etc)
    By autoklasse in forum Head Unit & Processor
    Last Post: 13th November 2010, 09:18
  3. PIONEER FH-P8800 Double DIN Headunit - CD/TAPE/TUNER - MADE IN JAPAN
    By rav4lution in forum Head Unit & Processor
    Last Post: 21st April 2010, 22:03
  4. wts: ddin pioneer fh p8800 sold.......
    By leon9 in forum Head Unit & Processor
    Last Post: 22nd July 2009, 15:49
