review donk JVC KD-DV5100 .. bagus ga yah ?? saingannya pio 5650 tuh..
Lumayan, gue pake KDDV 5000. Beda displaynya, KDDV 5000 lebih atraktif. Kalau 5100 bisa WMA.....
RN6 :
9017 / DSP PRO MK2 / DD1-DD4-DD6.5-DD10 / AN 2.200 MK3 #8Ball_edition /
RM3 :
916WS / D3004-12MU-18W-32W / Psix MK2 - 2075SE /
gw jg pake KDDV-5000 .. asik2 aja sih. Yang KD-AVX1 dah ada yg jual blom ya? ... berapaan tuh ya? kalo ada, gw mo jual nih yg DV-5000, blom ada 1 taun gw pake, masih bagus.
gw juga pake dv5000 ga ada keluhan... bagusah dv 5000 kali ya dah bisa gambar2, yang baru malah kaga bisa..
..Black Car and Black Gadget..
yang KD-AVX1 donkkk... di website tetangga lg abis euy barangnya.
emang kaya gimana barangnya... ada pic? beda feature apa aja..? eh ini buat dvd juga khan....
keren abist banget lah.. hehhe. pasti lo juga mo nukerin tuh DV5000nya buat AVX1 nih.. gw cari dulu gambarnya ntar gw post.
JVC KD-AVX1
AV Systems
DVD Player KD-AVX1
Video Format NTSC
Shock Proof Memory Yes
DVD-R/-RW Compatible Yes
Video DAC 10-bit/54MHz DAC
DTS/Dolby Digital/MPEG Audio Yes
GIGA MP3 Yes
Dual-Zone Function Yes
Pause/Step/Slow Yes (with remote control)
Zoom Yes (with remote control)
Direct Chapter Access Yes (with remote control)
Frequency Response 16 - 22,000Hz (DVD fs=48/96kHz), 16 - 20,000Hz (CD)
Dynamic Range 93dB (fs=48kHz)
Signal-to-Noise Ratio 95dB (fs=48kHz)
Channel Separation 85dB (at 1kHz, fs=48kHz)
Wow & Flutter Less than measurable limit
VCD Player KD-AVX1
Video Format NTSC
Video CD Playback Control Yes
Direct Track Access Yes (with remote control)
Pause Yes (with remote control)
Step Yes (with remote control)
CD Player KD-AVX1
MP3/WMA Compatible with ID3 Tag/WMA Tag Yes
CD-R/RW Compatible Yes
CD Text Yes
Disc Name Registration Yes
Random/Repeat Play Yes
Intro Scan Yes
CD Changer Control KD-AVX1
MP3 Control Yes (CH-X1500 Only)
CD Text Yes (CH-X1500 Only)
Intro Scan Yes
Tuner KD-AVX1
SIRIUS Ready Yes
Tuner Type
- HS-IIIi Yes
Preset Stations 18 FM, 6 AM
Station Name Registration Yes
SSM (for FM) Yes
AFNS/PNC Yes
Seek (Up/Down) Yes
Stereo/Mono Switch (for FM) Yes
TV Tuner Option Yes
Auto Antenna Yes
European Switchable Tuner Yes
FM
- Frequency Range 87.5 - 107.9MHz
- Usable Sensitivity 11.3dBf (1.0uV/75 ohms)
- 50dB Quieting Sensitivity 16.3dBf (1.8uV/75 ohms)
- Stereo Separation 35dB
- Capture Ratio 1.5dB
AM
- Frequency Range 530 - 1,710kHz
- Sensitivity 20uV
- Selectivity 35dB
Amplifier KD-AVX1
Maximum Power Output 50W x 4
Continuous Power Output (RMS) 20W RMS x 4 Channels at 4 ohms with no more than 1.0% total harmonic distortion + N
MOS-FET Amplifier Yes
Audio DAC 96kHz/24-bit DAC
Source-Specific Volume Control Yes
Volume Attenuator Yes
Balance/Fader Control Yes
Equalizer
- 7-Band iEQ Yes
Max. Amp Gain Switcher Yes
Amp Defeat Switch Yes
AV Input Terminals (Video + L/R) Yes (Gold-plated)
Video Output Terminal Yes (Gold-plated)
Line Output Terminals (pair) 2 Pairs (Gold-plated)
Second Audio Output Terminals Yes (Gold-plated)
Subwoofer Output with Level/Frequency Control Yes (Gold-plated)
Optical Digital Output Yes
Frequency Response 40 - 20,000Hz
Load Impedance 4 ohms
Pre-output level/impedance 2.0V/1k ohms
Video Output Level/Impedance 1.0Vp-p/75 ohms
Audio Output Level/Impedance 2.0Vrms/1k ohms
Video Input Level/Impedance 1.0Vp-p/75 ohms
Audio Input Level/Impedance 1.5Vrms/20k ohms
Monitor KD-AVX1
Screen Size 3 Inch
Angle Adjustment Yes
Screen Resolution 186 x 220 x 3
LCD Type TFT Active Matrix LCD with Wide Viewing Angle
Color System NTSC
Aspect Ratio 4:3
Switchable Dimmer Yes
Display KD-AVX1
Power Switch Standby Illumination Yes
General KD-AVX1
Face Type
- Motorized Slide-Out Face Yes
Detachable Face Plate with Carrying Case Yes
Steering Remote Control Ready Yes
Wireless Remote Control Type
- Multi-Function Wireless Remote Control Yes
Beep Tone Support Yes
COMPU PLAY Yes
Tel. Muting Yes
Power-Off Mode Eject Yes
Preferred Setting Mode Yes
Dimensions (W x D x H)
- Installation Size 182 x 52 x 160mm (7-3/16" x 2-1/16" x 6-5/16")
- Panel Size 188 x 58 x 18mm (7-7/16" x 2-5/16" x 3/4")
- Detachable Face Plate Size 169 x 58 x 24mm (6-11/16" x 2-5/16" x 1")
mantap..!!! berwarna pula layarnya... emang brapa harganya..?
nah itu.. gw mo minta tolong cari tau.. hehehe.. di kampung gw ga ada neh yg jual. ... klo ada info kabar2in ya.![]()
