WTA : JL 13 "W7 vs iDMax 12" D4V3 vs Aliante Ltd 12" vs Focal Utopia 13" 33WX2
Results 1 to 10 of 76
  • Short URL:  http://modifika.si/188653
    17 Hrs 13 Mins 28 Secs
    Permisi master2 Modcom sekalian....
    Sesuai judul saya ingin minta pendapat dari para master sekalian, klo keempat sub di atas :
    - JL 12" W7
    - iDMax 12" D4V3
    - Aliante Black Ltd 12"
    - Focal Utopia Beryllium 13" 33WX2
    diadu head 2 head,menurut pengalaman master2 sekalian mana yg lbh baik? Dgn harapan bhw sub tersebut mampuni utk bermain SQ n SQL (dari lagu audiophile sampe RnB )
    O iya sebagai tambahan, powernya pake JL 1000/1, utk dipasang di mobil Jazz GD3. Klo master2 sekalian berkenan tolong dibantu repiu nya dikit sama kira2 butuh box brp Liter. Makasi master2 sekalian buat bantuan repiunya....
    Ps : sedikit bantuan berikut spec masing2 sub di atas
    Load Vented
    Load Volume 35 - 50 litres
    Nominal power 400 W
    Maximum power 800 W
    Sensitivity 92 dB
    Nom. impedance 4 ohms
    Magnet Multiferrite (12 ferrites)
    Voice coil 77 mm
    iDMax 12" D4V3
    IMP 2 / 8ohms Nominal Impedance
    Re 3.0/ 6.0 Ohms DC Resistance
    Fs 20Hz Resonant frequency
    Qes .40 Electrical “Q”
    Qms 2.1 Mechanical“Q”
    Qts .34 Total “ Q”
    Vas 5.81 cuft (165 liters) Equivalent volume
    Xmax 24.9mm One way linear
    Sd 545 cm2 ConeArea
    Spl 93.1dB/88 dB 1w/1mG.P./SPLi
    Pwr 1000 Watts RMS POWER
    Prinzip / DIN-Ř 300 mm / 12" Subwoofer
    Belastbarkeit RMS / max. 500/1200 Watt
    Impedanz 4 Ohm
    Frequenzbereich 18-250 Hz
    Schalldruck 88 dB
    Aussendurchmesser 320
    Lochausschnitt 288 mm
    Einbautiefe 82
    Rdc 3,3 Ohm
    Fs 20 Hz
    Qms 2,19
    Qes 0,27
    Qts 0,24
    Vas 138 L
    Xmax 18
    Korb Mehrteiliger Alu Druckguss Stahl Korb
    Einbaudurchmesser 288
    Free Air nein
    Geschlossenes Gehaeuse / Q=0.7 24
    Bassreflexgehaeuse mittel 56
    Reflexrohre BR mittel Anzahl 1
    Reflexrohre BR mittel Durchmesser 10
    Reflexrohre BR mittel Laenge 34
    JL Audio 12" W7
    Free Air Resonance (Fs): 27.2 Hz
    Electrical “Q” (Qes): 0.514
    Mechanical “Q” (Qms): 7.807
    Total Speaker “Q” (Qts): 0.482
    Equivalent Compliance (Vas): 2.33 cu. ft. / 66.0 liters
    One-Way, Linear Excursion (Xmax)*: 1.15 in. / 29 mm
    Reference Efficiency (no): 0.249%
    Efficiency (1W/1m)**: 86.2 dB SPL
    Effective Piston Area (Sd): 84 sq. in. / 0.0542 sq. m.
    DC Resistance (Re): 2.47 ohm
    Nominal Impedance (Znom): 3 ohm
    Thermal Power Handling (Pt): 1000W
    Driver Displacement: 0.14 cu. ft. / 4.0 liters
    Net Weight: 45 lbs. / 20.4 kg
  2. clickbet88.com
    5 Hrs 14 Mins 28 Secs
    Subnya pada sadis2 semua.... Nubi numpang nyimak ya bos.... Btw FA1 kaga dimasukin juga... Hehe
    Quote Originally Posted by akaz View Post
    Sadiss mana ma sub pny suhu,hayooo...
    Bkn ga mao masukin FA1 suhu, ane udh dgr FA1,demen bgt, cm duitnya ga demen :cry:
    Makanya ga dimasukin... Bersedia bantu repiu na suhu?
    Sepi yeee... Anyone?? Suhu2?? Master2?? Ada yg mao bantu ane?? Wahh pd liburan smua nehh kyknya
    As usual,rame dihari kerja sepi dhari libur,wakakakkakakkaaa...
    Semua bagus2 koq pilihannya, cuman mesti itung enclosurenya spy bisa masuk ke GD3nya... Om blegug dah punya t/s parameternya tinggal diinput pake software box calculator macam winisdpro, butuh volume boxnya berapa besar... Muat gak dimasukin ke jazznya.... Hehe
    Nahh itu dia suhu,ane kagak ngarti cara itungnya :cry:
    Maklum msh nubie... Pgnnya sehh coba2 test dgr,cm jrg yg pake (kec. Aliante)
    klaten
    nubie ikutan menyimak aja.....
    pilihannya kelas berat semua nih....takut salah kasi saran..
    :p:p
    :p:p
    Jiahhhh yg nubie itu saya juragan :cry:
    Org kerjaannya tiap2 nanya molo di forum
    Klo juragan prefer yg mana gan?? Dgr2 idmax ok jg tuhh gan,cm rada penasaran ma focal jg. 2 brg itu jrg banget dipake org kyknya...
    East Java
    3 Days 17 Hrs 15 Mins 15 Secs
    Hanya 1 kata mainannya sadissssss....Kl cocok FA1 mending langsung naikin FA1 aja ketimbang nanti pilih yg lain trus krg cocok kebayang2 FA1 ganti lagi jual lagi rugi lagi :smt003
    USC Team's
    Quote Originally Posted by 417DR1 View Post
    FA1 kmrn udh nanya jg suhu,ga akan muat di jazz :cry:
    Bisa muat,tp bagasi abis smua... Ga akan bisa naroh ban serep
    Jd yaaa ane ikhlas d,lgan duitnya ga nyampe suhu... Ini jg cm nanya doank koq,msh ngumpulin "koin peduli blegug"
Venom 300x250 Datsun 300x250
  1. WTS : Subwoofer Idmax D4V3 10" (4 ohm) 2 pcs Muluzzzzz
    By blegug_sia in forum Speaker - SubWoofer
    Last Post: 19th May 2011, 19:13
  2. WTB : Sub iDMax 12" D4V3
    Last Post: 27th May 2010, 15:50
  3. FOCAL 27 K Pokykevlar 11" ~Vs.~ Aliante 12"
    By audiotech in forum Diskusi Subwoofer
    Last Post: 7th November 2007, 09:52
