Power, Monoblok, speaker, sub Fusion SPL kuenceng
Page 1 of 20 12345 ... LastLast
Results 1 to 10 of 192
  • Short URL:  http://modifika.si/187896
    Japan
    3 Days 23 Hrs 57 Mins 4 Secs
    SOLD thx 2 modcom
    Buat SPL dijamin kuenceng suaranya,,,,, barang masih bagus, belum pernah diservis, pemakaian normal jarang digeber, kalo lagi nongkrong disenayan aj. Pernah digeber 1 jam an ga protect, monobloknya juga Cuma anget aj ga panas. Kardus sudah gada, kecuali box Jonah Lomu masih ada.
    1. 2 pasang speaker 6,5” Jonah Lomu FJL 65C, tweeter n magnetnya krom , barang langka neh SOLD
    2. 1 set speaker 6,5” PP-CM65 SOLD
    3. 2 sub dobel coil PP-SW 12 H SOLD
    4. Power PP-AM8004 4 channel Rp 1,6jt , Power EN-AM6004 4 channel Rp 1,15jt jual salah satu
    5. Monoblok PP-AM20001 SOLD
    6. 1 Cap Bank 1,5 F Symbion 250rb
    7. Box buat Jazz GD3, bahan fiber dijamin ga bocor, bungkusnya dijahit Murano (putih), MB Tech(Biru) RP 1,2jt
    Bisa paket atau ketengan, khusus monoblok paket ma sub, kecuali subnya laku duluan
    Yg minat mw dapet harga special bisa hub:
    Jonah Lomu FJL 65C
    6.5" Component
    Speaker System
    240 Watts Max
    Jonah Lomu #11 component speakers deliver "Jonah power" right across the audio spectrum. Passive crossovers, silk dome airport and die-cast baskets come complete with dual stacked magnets, 10 gauge leads and chrome back plates.
    Product Specifications
    Crossover Features
    2-Way Passive Crossover Network
    High Pass: 2.5kHz / Low Pass: 3.5kHz
    12dB/Octave
    Ventilated Metal Protective Housing
    24kt Gold Plated Input/Output Connections
    Tweeter Features
    1.0” Superior Silk Dome Tweeter
    High Performance Neodymium Magnet
    Flush and Surface Mount Capabilities
    Spun Aluminum Tweeter Structure
    6.5” Mid Bass Features
    50 Oz Magnet Structure
    1” Kapton Voice Coil
    2 Ohm Impedance
    High Rigidity Pressed Paper Cone
    10 Gauge Connection Fly Leads
    Die-cast Speaker basket
    Chrome Back Plate
    Power Handling: 240 Watts (MAX)
    PP-CM65
    PowerPlant 6.5" Component Speaker System
    Detailed Light-Weight Polypropylene Cone
    Rigid, light-weight cone for accurate reproduction of mid bass frequencies.
    Industrial Cast Basket
    Provides maximum structural stability enhancing sound quality
    Moulded Terminal Wire Connector
    Ensuring fluid connectivity and consistent sound through specifically moulded terminal wire connections
    Sound Dispersing Tweeter Housing
    The PowerPlant tweeter housing disperses high frequency sound, expanding the sound stage.
    Gold Plated Connectors
    High end componentary and gold plated wire screw connectors ensure fluid connectivity
    Max Power Rating: 180 Watts
    RMS Power Rating: 60 Watts
    Compliance (Cms): 676.3
    Cone Area (Sd): 13.68
    D.C. Coil Resistance (Re): 3.3
    Electrical Q (Qes): 0.733
    Force Factor (Bl): 4.48
    Free Air Resonance (Fs): 55
    Frequency Response:52Hz - 21kHz
    Impedance (Nominal): 4
    Mechanical Excursion (mm): 12
    Mechanical Q (Qms): 7.04
    Sensitivity (dB) (1W/1M): 91
    Total Loudspeaker Q (Qts): 0.66
    Magnet Structure (Oz): 12.6
    Power PP-AM8004
    PowerPlant 4 Channel Amplifier
    Superior Thermal Conductivity
    PowerPlant amplifiers feature superior thermal conductivity ensuring heat dissipates efficiently
    Rugged Amplifier Case
    Single piece extrusion with seamlessly matched die-cast end caps which protects connectors and internal components
    Over-sized Mounting Feet
    The oversized mounting feet with their recessed holes provide secure and discreet fastening points.
    Over-Sized Power Connection
    Enlarged contact surfaces for high current connectivity
    Stage 2 System Management Panel
    Multi-function management panel enables you to refine the characteristics of the signal to suit your audio preferences.
    Multiple Fuse Protection
    Multiple fuses protect internal components and are easily accessible for quick changes in a competitive environment
    85 Watts RMS per Channel @ 4 Ohms and 1% THD+N
    110 Watts RMS per Channel @ 2 Ohms and 1% THD+N
    225 Watts RMS Bridged Channels @ 4 Ohms and 1% THD+N
    Max Power Rating: 800 Watts
    Max Current: 60A
    Full Rated Power Distortion (Max) 1kHz: 0.04%
    THD @ Rated Power 1kHz/100Hz: 0.1%
    Channel Separation:[b/] 50
    Frequency Response Hz (-3dB): 10Hz - 40Hz
    Signal to Noise: >90
    Variable High Pass Filter: 12 dB/Octave
    Variable Low Pass Filter: 12 dB/Octave
    Bass Boost @ 45Hz: 12dB
    Input Sensitivity: 0.2 - 8V
    Input Impedance: 47K
    Fuse Rating: 25A x 3
    PP-AM20001
    PowerPlant Monoblock Amplifier
    465 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
    750 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
    1150 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
    Linked Power Ratings @14.4VDC
    1000 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
    1800 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
    Max Power Rating: 2000 Watts
    Max Current: 100A
    Full Rated Power Distortion (Max) 1kHz: 0.45%
    THD @ Rated Power 1kHz/100Hz: 0.3%
    Frequency Response Hz (-3dB): 10Hz - 250Hz
    Fuse Rating: 25A x 4
    PP-SW12H
    PowerPlant 12" Heavy Duty Subwoofer
    Die-Cast FUSION Torsion Arm Dual Basket Structure
    The alloy dual basket features a FUSION Torsion Arm structure ensuring maximum rigidity to optimize performance
    Heavy Duty Motor Structure
    PowerPlant’s heavy duty stacked magnet structure is engineered for intense sound generation
    Recessed Mounting Points
    A rigid one piece cast frame integrates recessed mounting points for installation strength
    Press-formed Paper Cone
    Extreme strength, press-formed cone for accurate reproduction of low frequency sound
    Full Excursion Foam Surround
    Allowing full cone travel and movement, offering total control without restriction in the extra low range with a high roll rate.
    Composite Synthetic Motor Housing
    Made of high performance synthetic materials and tuned for maximum motor performance
    8 Gauge Oversized Power Connectors
    Providing ease of connection and superior power transfer into the motor structure
    Max Power Rating (Watts: 1200
    RMS Power Rating (Watts): 400
    Coil Height (Hvc): 28
    Compliance (Cms): 171
    Cone Area (Sd): 49.09
    D.C. Coil Resistance (Re): 1.85
    Electrical Q (Qes): 0.411
    Force Factor (Bl): 11.61
    Free Air Resonance (Fs): 31.02
    Frequency Response: 25Hz - 500Hz
    Gap Height (Hag) (mm): 10
    Impedance (Nominal): 2
    Inductance (Le) (mH): 0.34
    Linear Excurson (Xmax):30
    Mechanical Excursion (mm):9
    Mechanical Q (Qms): 5.25
    Moving Mass (Mms): 153.92
    Sensitivity (dB) (1W/1M): 88
    Total Loudspeaker Q (Qts): 0.381
    VAS (L): 58.52
    VAS (CuFt): 2.07
    Magnet Structure (Oz): 235
    Total Loudspeaker Displacement (L): 7.3
    Japan
    up...
    up...
    up...
    Japan
    up...
    up...
    up...
    4 Hrs 25 Mins 13 Secs
    Talking power
    bro, brpa net nya fusion pp 20001 am, kdsinya mulus n segel bro?
    Japan
    Quote Originally Posted by sulistio View Post
    monobloknya nunggu subnya laku dulu ya bos, kalo monobloknya laku dulu, ntar kalo ada yg beli sub susah nyari monoblok yg kuat ngangkat subnya
    Japan
    up...
    up...
    up...
    Japan
    up...
    up...
    up...
    Ngayogyokarto Hadiningrat
    10 Hrs 32 Mins 50 Secs
    bantu up aja bos...
    Japan
    Quote Originally Posted by ardian11 View Post
    bantu up aja bos...
    tengkyu bos
    Japan
    up...
    up...
    up...
Venom 300x250 Vkool
  1. Power, Monoblok, speaker, sub Fusion SPL kuenceng
    By coolz in forum Power Amplifier
    Last Post: 19th August 2010, 16:58
  2. Fusion EN-PK 112+PP-CM65 (Sub,power,box+Speaker Split)
    By phat_bastard in forum Speaker - SubWoofer
    Last Post: 23rd July 2010, 09:55
  3. Replies: 9
    Last Post: 12th July 2010, 16:21
  4. Replies: 77
    Last Post: 10th June 2010, 20:51
  5. [ASK] power fusion buat sub fusion
    By symbion in forum Diskusi Power Amplifier
    Last Post: 21st February 2007, 19:53
