MACAM-2 ENGINE PARTS E30 M40
Results 1 to 10 of 27
  • Short URL:  http://modifika.si/187787
    1 Mth 5 Days 3 Hrs 23 Mins 12 Secs
    Arrow MACAM-2 ENGINE PARTS E30 M40
    Permisi bung mod..
    FS Parts ex E30 M40:
    - Injection system
    - Throttle Housing
    - Intake manifold
    - Short Engine (booked)
    - Cover Distributor
    - Cover Engine Housing
    - Kabel Busi + Cap
    - Dynamo Stater
    - master Rem (Brake Servo Unit)
    - Tabung Oli Power Steering
    - Tabung Minyak rem
    - Tabung Minyak Kopling
    - Pompa Powersteering
    - Pompa Bensin (Fuel Pump)
    - ECU
    - ICV (Idle Control)
    - Radiator
    - Kompressor A/C
    - Tangki Bensin
    - Set Control Arm
    - Shift lever with arm
    PARTS LAIN PLS CALL..
    Lokasi: Bengkel Specialist Auto Body Works - Surabaya
    yang berminat harap japri atau hub:
    Email: roland.wetik@gmail.com
    Call: 081331548910
    Pin bbm: 2382fba6
  2. Jayapoker
    TANGKI BENSIN
    DYNAMO STARTER
    ICV (Idle Control)
    INJECTION SYSTEM
    EXHAUST MANIFOLD
    EXHAUST MANIFOLD GASKET
    UPPER INTAKE MANIFOLD
    LOWER INTAKE MANIFOLD
    POMPA POWER STEERING
    SHIFT LEVER WITH ARM
    THROTTLE HOUSING
    yang Dulunya Hutan Kal_ Tim
    15 Hrs 25 Mins 14 Secs
    Bantu up om....
    Quote Originally Posted by jues View Post
    Bantu up om....
    Thank u boss..
    salam..
    :smt068:smt068:smt068:smt068:smt068
    :smt071:smt071:smt071:smt071:smt071
  1. cuci Gudang parts Berbagai macam mbl always check every day
    By B198ERT in forum Bursa Eksterior Lainnya
    Last Post: 10th September 2012, 09:09
  2. Replies: 17
    Last Post: 18th June 2011, 10:49
  3. WTS: Jual macam-macam Parts mobil
    By R_Jo98 in forum Jual Beli Mesin Lainnya
    Last Post: 16th October 2009, 10:35
  4. FS: TURBO PARTS, ENGINE PARTS, BRAKES For 7th Gen Civic (banyak barang)
    By guyverias in forum Jual Beli Mesin Lainnya
    Last Post: 30th August 2009, 15:37
