Low Fuel Consumption
Results 1 to 10 of 19
  • Short URL:  http://modifika.si/1876
    2 Hrs 2 Mins 41 Secs
    Bro ..
    bantuin gue donk, gue ada yang gak ngerti dari penggalan artikel di sebuah web nih:
    Note that the manifold pressure increases as the air/fuel ratio is made leaner. To obtain the same power output with a leaner mixture, you have to use more throttle. Generally, fuel consumption decreases as the mixture is made leaner. Eventually the increase in manifold pressure offsets the reduction in fuel flow and fuel consumption increases once the mixture is leaned past 15.7:1.
    At the stoichiometric air/fuel ratio, fuel consumption is around two percent higher than optimum. Air/fuel ratios richer than stoichiometric sharply increase fuel consumption so that running 13.5:1 results in eight percent more fuel consumption than stoichiometric. This is why it's important to have a correctly functioning oxygen sensor.
    Yang dimaksud manifold pressure itu apa yah ?
    ada yang tahu informasinya ?
    http://rio.martin.mu/webgall/modcom04.jpg
    2E engine on My EE90 Rolla with 4-1 exhaust system.
    Brisbane
    Gw cuman bisa nangkep dikit yg paragraph pertama sih.
    Manifold pressure mnurut gw yah pressure dari throtte (intake pressure). Jadi kalo ratio air dan fuel dibikin lebih lean, inlet pressure nya itu yg harus dinaekin. Trus fuel consumption akan lebih sdikit.
    Maap nih kalo2x salah. Tap mestinya engga sih. hehehehe.
    US of A
    31 Mins 51 Secs
    yg dimaksud tuh pressure dari IM(intake manifold)temen deket nya TB.
    more throttle=more air=more pressure in the manifold.
    Quote Originally Posted by dayak
    TB itu apaan yak ?
    more throttle = more air, gue setuju ..
    1 Min 11 Secs
    TB = Throttle Body
    Jakarta hampir coret
    1 Day 1 Hr 39 Mins 42 Secs
    Quote Originally Posted by t3rm
    TB itu apaan yak ?
    4 throttle = 4 air = 4 throttle 4age blacktop...hehehehehe
    *=-BoDat sPeeD-=*
    Brisbane
    Quote Originally Posted by xesy
    TB itu apaan yak ?
    Mang 4age throttlenya 4 y?
    US of A
    31 Mins 51 Secs
    LOL, kaga bozz..
    4AGE tuh mesin nya toyota corolla lama..
    kalo TB nya 4 berarti dia make ITB dong
    @t3rm
    TB= throttle body
    Brisbane
    LOL, kaga bozz..
    To dayak:
    Gw nemu di net nih, 4AGE 20valve
    udah di modif kali y.
    Keren ... GREENTOP ..
    he he he ..
    gue punya aja masih standard, BLACKTOP 12 valve doank .. 8)
  1. Fog Lamp LED low electric consumption, high quality product, Super Bright
    By ismayamotor in forum Lamp (Headlamp, Stoplamp, etc)
    Last Post: 29th April 2013, 18:23
  2. WTS : FUEL PRESSURE + FILTER & FUEL PUMP MERCI TIGER + FUEL HOSE NYA
    By ARRE_G1 in forum Jual Beli Mesin Lainnya
    Last Post: 17th March 2012, 00:43
  3. WTA : Fuel Consumption Land Cruiser 80 series ?
    By toguraja in forum Diskusi Mesin
    Last Post: 28th November 2011, 08:49
  4. WTA: All New CRV 2.0 Fuel Consumption
    By gendutz in forum Automotive
    Last Post: 2nd July 2008, 13:52
  5. Replies: 4
    Last Post: 28th June 2008, 11:56
