05 GDB STi
Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
Thread: 05 GDB STi
  • Short URL:  http://modifika.si/187098
    05 GDB STi
    Modlist :
    Engine & "blings" :
    -Maxwell Power Service custom blueprinted shortblock
    -Maxwell Power Service ECU reflash
    -Maxwell Power Service fuel rails
    -Rotated intake manifold
    -Wiseco 100mm pistons
    -ACL race bearings
    -Blouch Dominator III 2.4" inlet turbo
    -Tial 44mm wastegate
    -Amuse Powerhouse R1 Titan Cat-back Exhaust
    -Invidia V2 catless Downpipe
    -Grimmspeed catless external wastegate uppipe
    -Cusco carbon carbon twin plate clutch w/ intergrated flywheel
    -Samco Turbo inlet hose
    -Samco throttle body hose
    -Samco radiator hoses
    -Injector Dynamics 1000cc top-feed injectors
    -Beatrush alternator pulley
    -Beatrush forged pitch-stopper mount
    -Zerosports intake pipe
    -Zerosports lightweight WRC crank pulley
    -Zerosports "cool-action" thermostat
    -Zerosports Super Direct Flow intake
    -KOYO racing radiator
    -TurboXS UTEC
    -NGK one step colder spark-plugs
    -HKS Racing Ver. 2 BOV
    -ARC front mount intercooler
    -ARC oil cap
    -ARC radiator cap
    -ARC radiator shroud
    -Polished alternator
    -A'pexi AVCR
    -A'pexi turbo timer
    -Hot Inazma type LR voltage system
    -Project Mu brake fluid tank cap
    -Project Mu brake fluid tank cover
    -Eifel/Prova clutch fluid tank cap
    -Eifel/Prova hood damper
    -TechnaFit stainless steel clutch line
    -Walbro 255LPH fuel pump
    -A/C delete
    Wheels, suspension & drivetrain
    -Volk Rays TE37 18"x10.5 +22 (Hellaflush Wheels)
    -Falken 512 245/40/18 (Hellaflush Tires)
    -Hankook V710 245/40/18 Slick tires (Time-attack tires)
    -Tein type Flex coilovers
    -Whiteline rear subframe lock kit
    -Whiteline front endlinks
    -Whiteline anti-lift kit (sport)
    -Perrin rear endlinks
    -Cusco 21mm front swaybar
    -Cusco adj. rear swaybar
    -Carbing front strutbar w/ build in master cylinder brace
    -Cusco CF rear strutbar w/ 3-point connecting bars
    -Cusco engine mounts
    -Cusco transmission mount
    -Kartboy shortshifter
    -Kartboy front shifter bushings
    -Kartboy rear shifter bushing
    -Kartboy transmission crossmember bushings
    -Turn in Concept klunk killer
    -Turn in Concept 6MT pivot bushings
    -Happi Motoring fender braces
    -Beatrush differential mount support brace
    -TechnaFit Stainless steel brakelines
    -Brembo 8-piston w/ 380mm rotors
    -Project Mu Level 900 front brakepads
    -Hawk HP Plus rear brakepads
    -Do-Luck floor support bar
    -Do-Luck 8-point subframe
    -Garage AutoHero custom 10-point rollcage
    Exterior :
    -Cusco GT front lip
    -Zerosports sidekisrts
    -Do-Luck CF trunk
    -Do-Luck CF wing
    -RE-Amemiya CF diffuser
    -Subaru Impreza 2.5RS hood
    -Subaru JDM rainguards
    -Subaru STi stem valve covers
    -Cleared headlights
    -Custom TSX projectors retrofitted headlights
    -Speed Architech CF door handles
    -Speed Architech CF sidemirrors
    -Speed Architech CF exhaust heat shield
    -APS lightweight bumper beam
    -Carbign Craft CF license plate cover
    Interior :
    -Speed Architech CF front doorpanels
    -Speed Architech CF rear doorpanels
    -Speed Architech CF speedocover
    -Speed Architech CF maplight
    -Speed Architech CF domelight
    -Speed Architech CF A-pillars
    -Speed Architech CF B-pillars
    -Speed Architech CF C-pillars
    -Speed Architech CF front & rear seatbelt covers
    -Speed Architech carbon kevlar center console
    -Speed Architech carbon kevlar armrest cover
    -Speed Architech carbon kevlar center AC vent
    -Speed Architech carbon kevlar HVAC trim
    -Speed Architech carbon kevlar shifter trim
    -Speed Architech CF side AC vents
    -Speed Architech CF sidemirror covers
    -Speed Architech CF front & rear window switch covers
    -Speed Architech CF trunk plastic cover
    -Speed Architech CF clockpod
    -Speed Architech carbon kevlar steering column
    -Bride Zeta III racing seats
    -TAKATA racing harnesses
    -Nardi Classic steering wheel
    -Worksbell RAPFIX 2 quick release kit
    -Subaru S203 red hazard button
    -Subaru STi floormats (with STi logo)
    -Subaru aluminium doorsills
    -Autospeed deadpedal
    Tuned by : Dominic Acia of Maxwell Power Service
    500whp/470tq
    Enjoy!
    BaKaJin
  2. Bandargua88
    [ ɐʎɐqɐɹns ]
    2 Wks 4 Days 23 Hrs 48 Mins 2 Secs
    mantab banget nih mbl, sadis banget spec'ny... :o
    5 Days 2 Hrs 26 Mins 31 Secs
    Bro abisin modifnya berapa duit?
    Wah gila, mupeng gw liat modifikasinya, pusing bacanya, tapi mantep gila parts2-nya!
    Cakep abis bos!
    3 Days 14 Hrs 10 Mins 57 Secs
    Wah, enak kalau di U.S.A, shopping barang untuk Subaru buaanyak, tidak seperti di Indonesia.
    Sedikit sedikit harus impor,...
    Weks, baru lihat.. turbonya Blouch Dom 3,... sudah tembus 350+ whp tuh. (itu yang normal atau XTR?)
    Bro, kamu anggota forum NASIOC atau IWSTI ?
    btw, Nice !
    Dust Town
    2 Wks 6 Days 12 Hrs 22 Mins 43 Secs
    two thumbs up...
    d US bahannya (mobil) murah...USD 29rb udah bisa dapet 370Z...bayangin aja deh sm d sini bedanya berapa...andai2... hehehe
    Quote Originally Posted by subby View Post
    Thank you gw suka GC lu juga, gw lagi coba cari2 GC di jakarta, ga ketemu2 sama sekali haha.
    Quote Originally Posted by Sw1ft Lamp View Post
    Cakep abis bos!
    Thanks! ga tau deh udah abis berapa hahaha...
    Quote Originally Posted by Pecosdude View Post
    btw, Nice !
    iyah, disini mumpung parts2 ada dimana2 Blouchnya Dom 3 yg biasa. gw belinya seminggu sebelum XTR keluar . sebelumnya gw pake FP Green, dapet 330WHP di mustang dyno (210WHP stock), skr hopefully bisa dapet antara 420 - 450whp. yup, screen name gw di NASIOC STi-JDM. di add jadi friend aja disana cheers!
    11 Hrs 35 Mins 23 Secs
    Thumbs up
    manteb banget very nice subaru...fotonya juga ok punya btw ni pake flash ato lampu nih ?? thanks
    Quote Originally Posted by ilovejdm View Post
    thanks! ini fotonya pake lampu alienbees 1600 2 biji
    34 Mins 50 Secs
    sadis bos mantap rex nya...
