Seas Lotus RS165/1 On Sale
Results 1 to 10 of 13
  • Short URL:  http://modifika.si/186523
    www.belanjaaudio.com
    8 Hrs 12 Secs
    The Reference set RS165/1 (now 7,5 juta , was 12 juta)
    is a High End mobile audio separate speaker kit with tremendous details and power.
    http://www.belanjaaudio.com/product/productdetail/312
    Woofer RW165/1
    * Heavy copper rings mounted above and below the T-shaped pole piece, to reduce non linear and modulation
    * distortion and to increase overload margin.
    * Precision cast and surface treated magnesium cone, acting like a piston. Worldwide, SEAS is the only manufacturer to
    * offer this technology.
    * Black anodised aluminium voice coil former for increased power handling.
    * H2 lead out wire for reduced resonances and roping problems.
    * A solid brass phase plug/satin chrome surface enhances the performance of the copper rings and improves heat
    * conduction away from the pole piece.
    * Extremely stiff and stable injection moulded metal basket to keep the critical components in perfect alignment.
    * Magnet system with bumped back plate makes room for extreme coil excursions.
    * Rubber cup around the magnet system for protection and reducing enclosure refl ections.
    * Gold plated terminals mounted on a stiff glass fi bre reinforced plate to reduce contact resistance and improve
    * reliability.
    Tweeter RT27F
    * An optimally shaped 27mm diaphragm which gives well-controlled behaviour through the entire high frequency band. This diaphragm is produced from SONOTEX, a proprietary material developed and manufactured only by SEAS.
    * The SONOTEX process pre-coats the fabric 4 times with a damping/sealing material, resulting in excellent acoustic performance and consistency.
    * New modern front plate with wider mounting diameter.
    * A substantial injection-moulded rear chamber, with complex internal shape and reinforcing ribs, which eliminate unwanted chamber resonances and refl ections and improve heat transfer.
    * Low viscosity magnetic fl uid which provides excellent cooling of the voice coil while maintaining a low resonance frequency. Efficient neodymium magnet system
    Crossover RX2,5L RX2,5H
    * Low crossover frequency for optimal stereo image.
    * Hand selected electronic parts with strict tolerances and highest quality.
    * 2 unit network for easy placement in cars.
    * Tweeter adjustable
    * Side open boxes for best cooling.
    * Boxes easy to disassemble for easy service and if desirable to use print boards without boxes
    * if limited space for placement.
    * Rugged terminals for use with high quality cables.
    * Air core inductors for low loss resistance.
    * True 6 dB plus notch fi lter and true 12dB high-pass with 3 step tweeter adjustment.
    Overall features:
    Grilles included
    250 watts max power, 100 watts nominal power.
    Frequency response 70Hz-25kHz.
    Sensitivity 89dB
    Online Shopping For Car Audio & Video
    Latest news on BelanjaAudio.Com , visit our thread
    http://www.modifikasi.com/forumdisplay.php?f=190
    Showroom : Jl. Mayjen Sungkono 176 - 178 , Ruko Grand Sungkono B-3 , Surabaya
    Call/SMS @ 081 856 0866, YM: infobelanja@yahoo.co.id, FB: www.facebook.com/belanja.audio
    Honoured Member
    Thumbs up
    Quote Originally Posted by belanjaaudio View Post
    Woofer RW165/1
    * reliability.
    Tweeter RT27F
    Overall features:
    Grilles included
    Sensitivity 89dB
    Mantabz.....SEAS REFERENCE SERIES dirancang khusus untuk Car Audio.
    5 Hrs 14 Mins 28 Secs
    Bantu up bos... barangnya mantab2 nih....
    pedalaman
    19 Hrs 3 Mins 19 Secs
    Borong dunk buat boil satunya................
    Quote Originally Posted by denkris View Post
    Boro2 borong buat yg skrg aja masih nyicil eazy pay buat beli paket 3 jtan...
    klaten
    Muantaps bener nih midbass nya...RW 165 gitu loh...
    pedalaman
    Quote Originally Posted by akaz View Post
    lho kabel speaker bisa easy pay ???
    Aq mau aahhhh nek gituuu.....
    Kiiikkkk.........kkkiiikkkk
    Bisa di bos belanja audio ada fasilitas cicilan... Jangankan kabel speaker, semua satu sistem bisa dicicil kaya gw... Hehe
    pedalaman
    Yang bisa dicicil itu barangnya blanja audio apa situ yang bisa dicicil .........
    Nubie binun soalnya
    klaten
    Nubie binun soalnya
    Wkwkwkw......... orang bisa di cicil juga toh di belanja audio...?
Venom 300x250 Tekiro
  1. [SALE] R7000 & SEAS LOTUS & SOLOBARIC
    By UDG in forum Speaker - SubWoofer
    Last Post: 2nd February 2014, 08:35
  2. Replies: 1
    Last Post: 29th July 2012, 22:00
  3. Sale Seas Lotus RM120
    By Liu in forum Speaker - SubWoofer
    Last Post: 24th March 2011, 17:00
  4. WTA speaker-nobelium 6.2 vs mp5 vs seas lotus rs165/1
    By tony10121986 in forum Diskusi Speaker
    Last Post: 19th January 2010, 19:57
  5. Seas Lotus RS165/1 just arrived
    By belanjaaudio in forum Diskusi Speaker
    Last Post: 23rd September 2008, 18:25
