DEI - TITANIUM TURBO HOUSING
  • Short URL:  http://modifika.si/185987
    NEW !!!
    "TITANIUM"
    ULTIMATE T3 and T4
    TURBO SHIELD
    • COOL CARBON FIBER LOOK
    • HANDLES DIRECT HEAT UP TO 1800 F
    • HI-TEMP RATED SILICA PADDING FOR ADDED HEAT PROTECTION
    TESTIMONIAL BY BUSCHUR RACING (ENOUGH SAID) :o
    This new product from DEI is just flat out BAD ASS! It is perfectly formed and sewn to fit the T3 or T4 housings. The material is actually made of Lava rock and there is an inner padding/insulation that is made of silica and has a temperature rating of 2,000 degrees F. The turbo blanket has three heavy duty metal bosses embedded in the material so you can safety wire the blanket to the turbo. The install, seriously took about 3 minutes, including twisting the SS wire with the safety wire pliers.
    This blanket will fit factory Evo turbo's as well as larger T3 style turbochargers.
    We did a dyno pull, with someone hitting the turbo with aTrent laser heat gun. Immediately following the pull we took a temperature reading of the turbine housing, 693 degrees F. The turbine housing, obviously at that temperature was so hot it instantly burns you. We worked on the car that hot. Right after it was installed I ran the car again, identical dyno run.
    We then took another temperature reading and at the end of the pull the outside of the blanket was only 260 degrees. That's a drop of 433 degrees. After a few minutes of we hit it again, the temp had already dropped to 130 degrees. If the reading was right we would be able to touch it. David took the plunge, it was correct. He could lay his hand on the blanket no problem.
    This is a VERY worthwhile upgrade!
    Here is the blanket shown on the Buschur Racing Evo RS.
    depok
    1 Wk 6 Days 6 Hrs 35 Mins 52 Secs
    buat td-o5 juga? pm price please....
    [ Gd3zone ]
    pak
    ada pertanyaan nich
    itu bungkus housing turbonya kan buat meredam panas biar ga menjalar ke ruang mesin
    nah turbo kan itu panas sekali
    trus kalo panas nya tertutup, buang panasnya kemana ya ?
    apa nga turbonya jadi cepet rusak krn hawa panas nya tertutupi ??
    maap pertanyaan nubie ni
    kepengen pasang tapi ragu..
Venom 300x250 MBtech
  1. Bro! Butuh Turbo titanium buat lancer 2001
    By pujanggacinta92 in forum Diskusi Mesin
    Last Post: 28th November 2009, 18:44
  2. HKS TITANIUM TURBO DESIGN (UPDATE PIC)
    By dnis in forum Jual Beli Mesin Lainnya
    Last Post: 19th September 2008, 21:55
  3. WTS HKS TITANIUM TURBO DESIGN
    Last Post: 4th September 2008, 18:07
  4. ask: Remus titanium vs turbo design (dual pipe)
    By v6xer in forum Diskusi Knalpot
    Last Post: 4th March 2008, 20:22
  5. cari knalpot titanium buat turbo .... HKS Or apa aja
    By rendra_19 in forum Diskusi Knalpot
    Last Post: 23rd June 2006, 01:19
