Cambridge Audio DAC Magic (new product)
  • Short URL:  http://modifika.si/185200
    16 Hrs 11 Mins 49 Secs
    Cambridge Audio DAC Magic - Enjoy Music Like Never Before
    What Hi Fi?, for what it's worth, called it "one of the best we've tested" in a recently posted review.
    5 star review by HIFI Choice
    Best buy award
    The Cambridge Audio DacMagic upsampling digital to analogue converter is the world's most affordable and effective way to upgrade any Compact Disc, PC, network music device, games console or standard DVD player to truly high end sound quality.
    Adaptive Time Filtering (ATF) upsampling technology - developed in conjunction with Anagram Technologies of Switzerland - converts 16-24 bit audio data to 24 bit/192kHz dramatically improving musical reproduction. When used with standard CDs for example, ATF enhances audio clarity, richness and dynamic range to a level normally associated with SACD or DVD-A discs "upgrading" the
    investment you have already made in your music. (1) USB and (2) S/PDIF or Toslink inputs.
    Cambridge Audio pulls another rabbit from the hat with DacMagic. This upsampling digital to analogue converter is the world's most affordable and effective way to upgrade any PC, network music device, games console or standard CD/DVD player to truly high end sound quality.
    DacMagic is also designed to link with today's most popular music storage devices - such as PCs or Media Center PCs - instantly bringing downloaded content to life. And by simply linking DacMagic between PlayStation and Xbox consoles and your hi-fi, gaming gets a new dimension thanks to dramatically improved soundtracks and special effects.
    The magic of ATF
    A 32 bit Digital Signal Processor (DSP) also eradicates jitter, a problem which blurs the timing information of reproduced audio signals resulting in degraded audio quality. This is especially effective with hard disk playback from PCs or media players connected over a network.
    Why do you need DacMagic from Cambridge Audio?
    Digital music like never before!
    Adapted Time Filtering (ATF) asynchronous upsampling technology might sound complicated but the benefits are instantly audible. Essentially it converts 16-24 bit audio to 24 bit/192kHz so you hear so much more from compressed material. Whether your digital
    music collection is stored on a PC or you use a network music client - SqueezeboxTM, SoundBridgeTM, SonosTM etc - the difference
    in audible quality is incredible.
    Games just explode into life
    Gaming isn't just about the moving image. By connecting your games console - PlayStations (PS2 and PS3), Xbox and Xbox 360s to your hi-fi via DacMagic, dramatically improved soundtracks and special effects are immediately apparent.
    Breathe new life into your DVD player
    DVD players can sound great with movies, but normally lack polish when playing back CDs. DacMagic is the simplest way to significantly eradicate jitter and markedly improve your DVD player's sonic performance.
    Resurrect your CD player
    Maybe your CD player is ageing gracefully and is in need of a boost. DacMagic adds a new lease of life into any CD player fitted with an S/PDIF or Toslink (optical) output.
    An audiophile tour de force!
    DacMagic sports a range of components you'd never dream could be crammed into such a compact case. These include a 32-bit Texas Instruments Digital Signal Processor (DSP), dual Differential Virtual Earth balanced filter topology and twin Wolfson WM8740 high quality DACs in dual differential mode for excellent stereo imaging. Other features include a choice of digital filters - linear
    phase/minimum phase/steep filter - and an incoming sampling rate indicator which shows the original source quality.
    Up to two digital sources - network music devices, games consoles, CD/DVD players etc. - can be connected concurrently using S/PDIF or Toslink inputs. Additionally, you can connect DacMagic directly to your PC using a USB connection (no drivers needed) and dramatically improve the quality of your digital music. Once upsampled, DacMagic offers both balanced XLR outputs and unbalanced RCA outputs for superior quality analogue transfer.
    DacMagic Performance Specifications
    * Inputs 2 x digital inputs (choice of either co-axial or optical connection for each)
    * 1 x USB PC digital input
    * Audio outputs 1 x pair gold plated RCA phono outputs
    * 1 x pair XLR balanced outputs
    * 1 x co-axial digital output (pass through)
    * 1 x optical digital output (pass through)
    * D/A converters Dual Wolfson WM8740 24 bit DACs
    * Digital filter Texas Instruments TMS 320VC5501 DSP upsampling to 24 bit 192kHz
    * Analogue filter 2-pole dual differential Bessel double virtual earth balanced
    * Frequency response 20Hz to 20KHz
    * THD @ 1kHz 0dBFs <0.001% 24 bit
    * Signal / noise ratio -112dBr
    * Supported digital input
    * upsampling frequencies
    * 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz
    * Audio output upsampling Fixed 24 bit 192kHz
    * Power consumption 18W
    * Dimensions (H x W x D) 52 x 215 x 191mm (2.0 x 8.6 x 7.6")
    * Weight (gross / net) 2kg / 1.3kg
    * Finishes Available: Silver and black
    Barang baru. Stock terbatas.
    Msrp 479 US
    http://www.hometheaterhifi.com/digit...-dacmagic.html
    Hrg 4jt
    Berminat hub 08161187408
  2. Hokinusa
    Up ......................
    22 Hrs 2 Mins 5 Secs
    bantu up yah bro
MBtech Venom 300x250
  1. Cambridge DAC Magic Murah!!
    By jlu_mike in forum Bursa Audio Lainnya
    Last Post: 13th January 2011, 05:58
  2. Cambridge Audio DAC Magic (new product)
    By rbtrzl in forum Bursa Audio Lainnya
    Last Post: 3rd May 2010, 23:26
  3. All in ONE, Cambridge Audio
    Last Post: 3rd November 2009, 21:16
  4. Cambridge Audio 'One' micro hi-fi (new product)
    Last Post: 20th October 2009, 22:17
