(((HOME AUDIO))) Onkyo TX-SR506 Audio AV Receiver kondisi BARU......3.75jt
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/184533
    Talking (((HOME AUDIO))) Onkyo TX-SR506 Audio AV Receiver kondisi BARU......3.75jt
    (((HOME AUDIO)))
    Onkyo TX-SR506 Audio AV Receiver kondisi BARU (Garansi Resmi 1 tahun)..........3.75jt
    Features:
    In the case of Onkyo A/V receivers, entry level means a whole lot more than just affordability and standard functionality. You would not find a better example than the TX-SR506, which also offers high-definition media capability and advanced sound correction technologies. With an HDMI platform handling 1080p video from three sources, the TX-SR506 brings polish and peak performance to high-definition displays and sources. Legendary Onkyo amplification drive and power set the foundation for delivering bass crunch and vocal clarity. And, thanks to the latest Audyssey technologies, you get to enjoy a sweeping soundstage even at low volumes. Easily holding its own among higher-priced A/V receivers, the TX-SR506 adds serious impetus to entry-level home theater.
    ADVANCED FEATURES
    * HDMI Pass-Thru (1080p Compatible; 3 Inputs and 1 Output)
    * HDTV-Capable HDMI Video Switching
    * Audyssey 2EQ to Correct Room Acoustic Problems and to Calibrate Speakers
    * Audyssey Dynamic EQ for Loudness Correction
    * Powered Zone 2 and Zone 2 Line-Out for Playback in Another Room (Separate Source)
    * Bi-Amping Capability for Music and Movie Sound Effects
    Spec:
    7 chΧ160 W at 6 ohms, 1kHz, 1 ch driven (JEITA)
    Dynamic Power 180 W (3Ω, Front)
    160 W (4Ω, Front)
    100 W (8Ω, Front)
    THD (Total Harmonic Distortion) 0.08% (Power Rated)
    Damping Factor 60 (Front, 1kHz, 8Ω)
    Input Sensitivity and Impedance 200 mV/ 47 kΩ (LINE)
    Output Level and Impedance 200 mV/ 2.2 k Ω(REC OUT)
    Frequency Response 5Hz–100kHz/ +1 dB–3 dB
    Tone Control ±10 dB, 50Hz (BASS)
    ±10 dB, 20kHz (TREBLE)
    Signal to Noise Ratio 100 dB (LINE, IHF-A)
    Speaker Impedance: 4Ω–16Ω
    Feature:
    • WRAT-Wide Range Amplifier Technology
    (5Hz–100kHz bandwidth)
    • High-Current Low-Impedance Drive (TX-SR506)
    • Optimum Gain Volume Circuitry
    • H.C.P.S. (High Current Power Supply) Massive High Power Transformer Processing
    • Dolby Digital Plus
    • Dolby Digital EX and Pro Logic IIx
    • DTS and DTS-ES, DTS 96/24 and DTS Neo:6 Processing
    • Pure Audio Mode
    • Direct Mode
    • Music Optimizer for Compressed Music
    • CinemaFILTER
    • Non-Scaling Configuration
    • A-Form Listening Mode Memory
    • 24-bit/192kHz D/A Converters
    • Powerful and Highly Accurate 32-bit DSP Processing Connections
    • 3 HDMI Inputs and 1 Output
    • HDTV-Ready Component Video Switching (2 Inputs/1 Output)
    • 4 Digital Inputs (2 Optical/2 Coaxial/4 Assignable)
    • 3 S-Video Inputs/2 Outputs
    • Powered Zone 2
    • Color-Coded 7.1 Multichannel Inputs (Ready for
    Dolby Digital and DTS Formats for High-Definition
    Discs)
    • Subwoofer Pre Outs
    Miscellaneous
    • 40 AM/FM Presets
    • Audyssey 2EQ Room Correction and Speaker Calibration
    • Audyssey Dynamic EQ Loudness Correction
    • Crossover Adjustment
    (40/50/60/80/100/120/150/200Hz)
    • A/V Sync Control Function (up to 100 ms)
    • Theater Dimensional Virtual Surround Function
    • Compatible with RI Dock for the iPod
    • Preprogrammed -Compatible Remote
    picture asli segera dipuload yach boss,sementara lihat di link ini dulu yach,thanks..
    http://www.glodokshop.com/detail_bar...pe=barang+baru
  2. Hokinusa
    up...................
    up................
    3 Wks 39 Mins 15 Secs
    merknya itu loh.. kayak produk buat masak... hehehehehe......
    bantu UP yaa.....
    he..he..he..,berarti cocok buat nonton film panas yach bos andry,he..he..he..
  1. Home audio atau car audio yang juga main Head Fi masuk sini!
    By Detailling_addict in forum Diskusi Audio Lainnya
    Last Post: 24th February 2012, 11:51
  2. Onkyo 7.1 HDMI Receiver DTS HD Master
    By jlu_mike in forum Bursa Audio Lainnya
    Last Post: 6th June 2011, 08:33
  3. Replies: 19
    Last Post: 21st April 2010, 12:59
