MEGAN HEADER YARIS - Page 10
Page 10 of 10 FirstFirst ... 678910
Results 91 to 98 of 98
  • Short URL:  http://modifika.si/184242
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    ++++PROMO BIG BRAKE KIT AP RACING AND BREMBO++++++
    WE BRING GENUINE BIG BRAKE KIT BREMBO AND AP RACING,WE SUPPLY FOR INDONESIA AND MALAYSIA MARKET AND MANY INSTALLATION IN CUSTOMER CAR.
    ************* AP RACING MADE IN UNITED KINGDOM ***********
    *****NEW RADI-CAL(NEW DESIGN)**********
    -CP 8520 NEW RADI-CAL CALIPER 6 POT ,AP DISCBRAKE 355MM FLOATING SLOTTED ,AP BRAKE PAD APF 404,AP BRAKE HOSE HARGA 39 JT (BLACK) DAN HARGA 40,5 JT (RED)
    **AP DISCBRAKE 362 MM FLOATING SLOTTED 42 JT.
    **AP DISCBRAKE 380MM FLOATING SLOTTED 45 JT.
    -CP 8530 NEW RADI-CAL CALIPER 4 POT,AP DISCBRAKE 330MM FLOATING SLOTTED , AP BRAKE PAD APF 404. AP BRAKE HOSE HARGA 32JT (BLACK ) DAN HARGA 33,5 JT(RED)
    **AP DISCBRAKE 345MM FLOATING SLOTTED HARGA 35JT.
    **AP DISCBRAKE 355MM FLOATING SLOTTED HARGA 38 JT.
    -CP7600 BLACK CALIPER 4 POT , AP DISCBRAKE 295MM FLOATING SLOTTED .AP BRAKE PAD APF 404 .BRAKE HOSE HARGA 24 JT.
    -CP 5200 BLACK CALIPER 4 POT , AP DISCBRAKE FLOATING SLOTTED 330MM, AP BRAKE PAD APF 404, BRAKE HOSE DENGAN HARGA 27 JT DAN 28,5 JT APABILA RED CALIPER.
    -CP 5040 RACE CALIPER 4 POT, AP DISCBRAKE FLOATING SLOTTED 330MM, AP BRAKE PAD APF 402, BRAKE HOSE HARGA 34 JT.
    -CP 9040 BLACK CALIPER 6 POT , AP DISCBRAKE 355MM FLOATING SLOTTED , AP BRAKE PAD APF 404, BRAKE HOSE HARGA 34 JT DAN 35,5 JT APABILA RED CALIPER.
    **DENGAN DISCBRAKE FLOATING SLOTTED 362MM HARGA 36 JT.
    ********** BREMBO MADE IN ITALY **************
    -BREMBO GT 4 POT,BREMBO BRAKE PAD,BRAKE HOSE WITH CENTER BELL PLUG & PLAY ALUMUNIUM AND ADAPTOR.
    **DENGAN DISCBRAKE FLOATING DRILLED 330MM HARGA 34 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 345MM HARGA 36 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 355MM HARGA 37 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 380MM HARGA 39 JT.
    -BREMBO 17Z 6 POT,BREMBO BRAKE PAD,WITH CENTER BELL PLUG & PLAY ALUMUNIUM AND ADAPTOR DENGAN DISCBRAKE FLOATING DRILLED 355MM HARGA 37 JT.
    -BREMBO 19Z 6 POT ,BREMBO BRAKE PAD WITH CENTER BELL PLUG & PLAY ALUMUNIUM , AND ADAPTOR DENGAN DISCBRAKE 380MM FLOATING DRILLED HARGA 43 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 380MM HARGA 45 JT.
    -BREMBO GT 6 POT.BREMBO BRAKE PAD GT,BRAKE HOSE WITH CENTER BELL PLUG N PLAY ALUMUNIUM DAN ADAPTOR.
    **DENGAN DISCBRAKE FLOATING DRILLED 355MM(BUAT VELG MINIMAL 18 INCH) HARGA 45 JT.
    **DENGAN DISCBRAKE FLOATING DRILLED 380 MM(BUAT VELG MINIMAL 19 INCH ) HARGA 47 JT.
    **DENGAN DISCBRAKE FLOATING DRILLED 405MM(BUAT VELG MINIMAL 20 INCH) HARGA 49 JT.
    -BREMBO REAR PORSCHE NEW CAYENNE CALIPER (FOR REAR USE ONLY),BREMBO BRAKE PAD WITH DISCBRAKE 345MM FLOATING DRILLED HARGA 34 JT.
    **DISCBRAKE 380MM FLOATING DRILLED HARGA 37 JT.
    -BREMBO 4POT MODEL 7L6 (FOR REAR USE ONLY ),BREMBO BRAKE PAD WITH DISCBRAKE 345MM FLOATING DRILLED HARGA 32 JT.
    **DISCBRAKE 380MM FLOATING DRILLED HARGA 35 JT.
    FOR ORDER CALL/WHATSAPP:081382077777/085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    JALAN BIAK NO 48-48A
    JAKARTA PUSAT 10150
  2. #92
    cipondoh-tangerang
    Auto Update Harga di bulan April 2016 for Big Brake Kit AP RACING and BREMBO.
    We bring genuine big brake kit BREMBO and AP RACING ,we supply for INDONESIA and MALAYSIA market, and many installation in customer car & dealer wanted.
    *****AP Racing made in UNITED KINGDOM*********
    -CP7600 caliper 4 pot ,AP disbrake 295mm floating slotted ,AP brake pad APF 404,HEL Brake hose harga 24 jt(black caliper) dan harga 25,5 jt (red caliper ) applikasi utk velg 15-16 inch.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad APF 404, HEL brake hose dengan harga 29 jt (black caliper) dan 30,5 jt (red caliper) applikasi utk velg 17 inch.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted 330mm, AP brake pad APF 402, HEL brake hose harga 36 jt. (applikasi utk velg 17 inch).
    -CP 9040 caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, HEL brake hose harga 36 jt (black caliper) dan 37,5 jt( red caliper) applikasi utk velg 18inch
    *dengan discbrake floating slotted 362mm harga 39 jt.(applikasi utk velg 19 inch).
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake 355mm floating slotted , AP brake pad APF 402, HEL brake hose harga 42 jt. (applikasi utk velg 18inch)
    *dengan discbrake floating slotted 362mm harga 45 jt.(applikasi utk velg 19 inch).
    **** BREMBO Made in ITALY ********
    -Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug & play alumunium and adaptor.
    *Dengan floating drilled discbrake 355mm harga 39 Jt.(velg minimal 18 inch)
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch)
    ---extra 4 jt apabila dipasang ke caliper belakang karena pembuatan center bell besar --------
    -BREMBO 17Z caliper 6 pot,BREMBO brake pad,with center bell plug & play alumunium and adaptor dengan discbrake floating drilled 355mm & brake hose harga 38 jt.(velg minimal 18 inch).
    -BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan discbrake 380mm floating drilled harga 44 jt.(velg minimal 19inch)
    **dengan floating drilled disbrake 405mm harga 46 jt. (velg minimal 20 inch).
    -BREMBO GT 6 pot.BREMBO brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    -BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad With Discbrake 345MM Floating Drilled Harga 35 JT.(velg minimal 18 inch)
    **Discbrake 380Mm Floating Drilled HARGA 38 JT.(velg minimal 19 inch).
    -BREMBO 4POT Model 7L6 (For Rear use only ),BREMBO Brake Pad With Discbrake 345MM Floating Discbrake Harga 33 JT.(velg minimal 18 inch)
    **Discbrake 380MM Floating Drilled Harga 36 JT.(velg minimal 19 inch).
    $$$$$---untuk pembelian big brake kit depan+belakang dapetkan potongan harga 3 jt-----$$$$$
    For Order Call/Whatsapp:
    081382077777-085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Tangerang 11750
  3. #93
    1 Wk 2 Days 12 Hrs 25 Mins 21 Secs
    brp harganya bro
  4. #94
    cipondoh-tangerang
    Quote Originally Posted by johnm00n View Post
    brp harganya bro
    harga 3.5jt bos
  5. #95
    cipondoh-tangerang
    harga 3.5 jt
  6. #96
    cipondoh-tangerang
    SPEEDZ PERFORMANCE Authroized for supply AP RACING world leader stock in huge quantity for stockiest so make the Stock in very good price.
    we always develop for the update AP Racing stock start from 15 inch wheels to 22 inch using World-Radical
    and for Brembo Grand tourismo start from wheels 17inch to 21 inch.
    we supply for INDONESIA Exclusive market, and many installation in customer car & dealer wanted for area not in Jakarta.
    Please come and see Stock and many application before buy and all is in stock.
    -CP7600 caliper 4 pot ,AP disbrake 285mm floating slotted ,AP brake pad APF 404,HEL Brake hose harga 22.5 jt (black caliper) dan harga 24 jt (red caliper ) applikasi utk velg 15-16 inch.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad APF 404, HEL brake hose dengan harga 27 jt (black caliper) dan 29 jt (red caliper) applikasi utk velg 17 inch.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted 330mm, AP brake pad APF 402, HEL brake hose harga 34 jt. (applikasi utk velg 17 inch).
    -CP 9040 caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, HEL brake hose harga 34 jt (black caliper) dan 35 jt( red caliper) applikasi utk velg 18inch
    *dengan discbrake floating slotted 362mm harga 37 jt.(applikasi utk velg 19 inch).
    *dengan discbrake floating slotted 362mm harga 44 jt.(applikasi utk velg 19 inch).
    NEW and ready stock AP RACING World RADI-CAL Caliper new design futuristic and with new model Floating J-Hook design .
    -CP 8520 caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose.
    **AP discbrake floating J-hook 370mm (velg minimal 18 inch) harga 45 jt
    **AP discbrake floating J-hook floating 380mm (velg minimal 19 inch)harga 47 jt
    **AP discbrake floating J-hook 390mm(velg minimal 20 inch) harga 49 jt.
    **AP discbrake floating J-hook 410mm (velg minimal 21-22inch)harga 52 jt.
    CP8530 caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose .
    **AP discbrake Floating J-hook 360 mm(velg minimal 19 inch)harga 42 jt.
    **AP discbrake floating J-hook 380 mm(velg minimal 20 inch) harga 43,5 jt.
    *Dengan discbrake floating drilled 330mm harga 34 Jt. (velg minimal 17 inch)
    *Dengan floating drilled discbrake 345mm harga 36 Jt.
    *Dengan floating drilled discbrake 355mm harga 37 Jt.(velg minimal 18 inch)
    *Dengan floating drilled discbrake 380mm harga 39 Jt.(velg minimal 19 inch).
    -BREMBO GT 6 pot,brembo brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan discbrake floating drilled 355mm(buat velg minimal 18 inch) harga 46 Jt.
    **Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 48 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 20 Inch) Harga 50 Jt.
    New and just coming in stock
    -BREMBO GT 8 pot.brembo brake pad .duralium center bell and adaptor plug and play of specific car
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 20 inch ) Harga 50 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 21-22 Inch) Harga 52 Jt.
    dapetkan potongan setiap pembelianbig brake kit depan + belakang dapetkan potongan harga 3 jt (extra pemotongan for customer).
    081382077777-082312077777 (HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Cipondoh-Tangerang 11750
  7. #97
    cipondoh-tangerang
    Hans Steven
    August 20 at 3:37am ·
    SPEEDZ PERFORMANCE
  8. #98
    cipondoh-tangerang
    PEED'Z PERFORMANCE by STZ ,It has over 17 years’ experience and specialized in distribution high end performance engine racing parts, bring high end brake system to providing the best brake system to consumers.It is for supply With the effort of SPEED’Z strong team, excellent sales , SPEED:Z has been successfully make pre-sales and after-sales value-added services to our business partners.for call/whatsapp 081382077777-082312077777(Hans SPEED'Z PERFORMANCE)
MBtech Datsun 300x250
  1. Replies: 6
    Last Post: 18th October 2012, 13:59
  2. Replies: 9
    Last Post: 19th May 2012, 11:32
  3. Replies: 6
    Last Post: 13th April 2012, 15:09
  4. FS: 2ND HEADER MEGAN FLOW 4-1 FOR 1 NZ/ YARIS
    By Ahongz23 in forum Jual Beli Knalpot
    Last Post: 29th January 2012, 12:20
  5. WTS: HEADER 4-1 MEGAN FLOW STAINLES FOR YARIS
    By HengkyAhongz in forum Jual Beli Knalpot
    Last Post: 29th January 2012, 11:29
