WTS Santai - Scanspeak 9800 -> Booked
Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
  • Short URL:  http://modifika.si/184143
    12 Hrs 34 Mins 55 Secs
    Foto2:
    Spek copas:
    ALU Tweeter 29mm Revelator ▪ Characteristic sensitivity (2.83V /1m): 90 dB ▪ Recommended frequency range:2 - 22 kHz ▪ Free air resonance frequency, fs :500Hz ▪ DC resistance, Re:3.5 ohm ▪ Voice coil inductance, Le :0.01 mH ▪ Effective piston area, Sd :8.5 cm� ▪ Moving mass incl. air, md :0.50 g ▪ Force factor, BL :2.8 Tm ▪ Excursion, lin./max. :�0.10 / �1.5 mm ▪ Voice coil diameter : 28 mm ▪ Rated power handling :160 W (12dB/oct.cross-over at 2.8 kHz) ▪ Net weight :0.7 kg
    Kelengkapan: Ada dus.
    BOOKED.
    Pembelian Nov/Des. 2009 dari Nexindo.
    klaten
    Mantap nih...bantu up aja boss
    Thank you bos Danny...sundul dulu pagi2
    Bandung - Jambi
    23 Hrs 56 Mins 15 Secs
    mantabb.....bantu up bro..
    @tempoyak: makasih byk sundulannya brother
    up dulu up dulu
    Selamat sore :-)
    Selamat malam modcommers
    24 Mins 14 Secs
    bantu up bro
    @H3ns: thank u Bro, ngga mau ngambil? Gw kasih harga bagus bgt :-D
    Up dulu Gaan :smt020
GT Radial
  1. JUAL SANTAI : KARBU WEBER DCNF40 (BOOKED)
    By yudha sby in forum Jual Beli Mesin Lainnya
    Last Post: 17th August 2011, 19:15
  2. Jual SANTAI BBS RC RING 18 (8,5-10)...BOOKED sampai SENIN
    By halimsatria in forum Ragam Ukuran
    Last Post: 5th August 2010, 21:02
  3. WTS: Scanspeak 9800
    By revvou in forum Speaker - SubWoofer
    Last Post: 1st October 2009, 09:21
