[MAZDA LOVERS] 323 white Lantis 95 =BW killer=
Results 1 to 10 of 103
  • Short URL:  http://modifika.si/182400
    bandungzzz
    6 Days 9 Hrs 10 Mins 15 Secs
    Exclamation [MAZDA LOVERS] 323 white Lantis 95 =BW killer=
    numang show off juragan2...
    mazda lantis 95 tua gw.... dipinang dari tangan pertama, putih asli, nomer rangka dan mesin 000004, menandakan lantis ke 4 yg d produksi di indonesia... banyak suka duka nya sama ni mobil, pertama belajar setir pake ni mobil, pertama kebut2an pake ne mobil, pertama nembak cw gw jg d dalem ne mobil.. wkwkwwkwkkk
    taun 95-2003 dibiarkan standart apa adanya, 2003-2005, fokus di audio mobil dah full peredam, mulai 2005 mulai gatel karena nemu piston high comp merek TODA bekas familia salah 1 sponsor modcom... mulai deh pembangunan mazda lantis ini, bermain di spek NA saja...
    spek skarang :
    MESIN :
    - Piston High comp TODA, 1:11 compression (aslinya punya miata)
    http://www.todaracingusa.com/products/mazda_miata/piston_kit.html
    - Bore up 85.00 mm, displacement : 1,928 cc.
    - Polish and porting, bigger throttle body.
    - Hotbits 4-2-1 header + customized free flow pipe by RKK..
    - customized intake pipe & splitter by SS performance shop
    - K&N xtreme air filter
    - NGK power cable
    - NGK iriway 7
    - HD racing fuel pump 250L/hour
    - SARD fuel pressure regulator + braided hose
    - ACT extreme clutch
    - Oil cooler (lupa mereknya) by pojok modifikasi
    - Dastek Unichip Q series, tuned by Sigma Speed
    - pivot Volt Stabilizer
    - pivot Raizin Spark
    - Jacobs OMNI PAK coil
    * target selanjutnya : high duration camshaft + MSD 6AL ignition + retune
    ROLLER & SUSPENSION :
    - SSR type C R15 flat black rims + Yokohama advan neova 195/55 R15 tires
    - intrax lowering kit + OEM shock absorber
    - valen sport damper
    - project miu brake pad
    - custom front strutbar
    - sparco rear strutbar
    * target selanjutnya : cari coil over, ga ada yg jual buat mazda lantis.. susah carinya..
    INTERIOR :
    - OEM seats + OEM seats cover
    - OEM in car entertainment + Dragster speaker and tweeter
    - Momo steering wheel
    - sparco steering button for launch control
    - sparco shift knob
    - customized short shifter
    - Auto gauge Oil pressure level
    - Pivot security engine stater button + neuvo keyless entry intelligent alarm
    BODY WORKS :
    - OEM body paint arctic white
    - custom fiber hood
    - sparco hood pin
    - OEM fog lamp
    - smoke rear turning lamp
    - billion air funnel
    - H4 forch all season bulb + IPF relay
    * rencana selanjutnya : mazdaspeed full body kit
    PICT :
    tolong komentar2 nya yah, tp jangan pedes2, ampun mobil butut gini... hwhwwh
    komen jg mobil ane yg lain yaa
    http://www.modifikasi.com/showthread...81#post8616781
    Mazda 323 lantis '95 JDM, Mercedes W124 E320 '94 USDM, Daihatsu fourtrak '97 UK-Euro
    Dieburg, Germany
    13 Hrs 33 Mins 57 Secs
    wow super duper kereennnnnnnnnnnnnnnnnnnnnnnnnnnn
    simple, tapi BLEDARR.... *menggigit mksdnya*
    kenceng banget nih kyknya..... lam kenal gan dari nubie...
    1 Wk 11 Hrs 22 Mins 28 Secs
    mantab boss mobilnya.
    bos nanya kalo header hotbittsnya belinya dimana dimana?
    ane minat nih? thanks
    MOC-MOC
    02198025064
    081317579954
    bandungzzz
    @frb :thx bro.. ga kenceng2 jg koq... hehehe salam kenal sesama nyubi...
    @EVOLIAR2 : thx bro... hotbitts bli di singapore via SS performance shop bro... contact aja tu, sponsor modcom jg kan......
    4 Hrs 14 Mins 33 Secs
    mana lantisnyaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaaaaa
    ayolah ton plisssssssss
    MLG - KWB
    9 Hrs 18 Mins 42 Secs
    wahh kuenceng nih lantisnya ... keren bangeet ... *ampe ngiler nih * hehehe ...
    dapet intrax lowering kit dmana nih gan ... bagi2 dong infonya ...
    bandung
    5 Days 19 Hrs 43 Mins 27 Secs
    betooonn.. nih mobil dr jaman sd ampe skrg msh terawat aja.. manteb daah...
    20 Hrs 23 Mins 35 Secs
    beuh ajip boss cat mulus!!!
    ane sur tuh ma ban yg boss pke hehehe....
    bdg dmana nya boss???
    bro,, kok ada abs n airbag???
    bandungzzz
    @ flow : kan dah d omong, not for sale, kenangan nya tll banyak... :p
    @ oom wahid : biasa aja ah oom, mobil tuwir.. Wkwk, lowering kit dapet dr SS performance bandung, ga taw ms ada stok gak..
    @ buchi dapid : yoi, dr jaman gw kelas 4 SD.. Mobil kesayangan..
    @ ibamoctria : thx boss.. Bandungnya d jalan riau boss..
    @ cherrio29 : ne lantis special edition bro, with ABS and air bag... :p :p
    J/K bro, tu cuma iseng2 aja gw sambungin, biar nyala kalo lg ON..
Venom 300x250 Datsun 300x250
  1. Mazda Lovers- Pengguna MAZDA, GABUNNGG !!
    By astina_ijo in forum Auto Club
    Last Post: 3rd July 2018, 23:17
  2. Replies: 199
    Last Post: 4th April 2017, 01:07
  3. Replies: 311
    Last Post: 15th April 2013, 22:15
  4. Replies: 308
    Last Post: 6th September 2012, 10:30
  5. Mazda Lantis 95 White
    By cyclone2005 in forum Mazda
    Last Post: 31st August 2012, 23:25
