potensi mesin 1NZ-FE VS L15A
Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
  • Short URL:  http://modifika.si/181908
    Talking potensi mesin 1NZ-FE VS L15A
    bagi yg menggunakan, apa kelemahan dan kelebihan dari kedua mesin tsb?
    bisa tlg share dnk kelemahan dan kelebihan 2 mesin tersebut,
    menurut ente2 enk yg mana kalau di buat modif?
    VVT-i is only variable cam timing. There is no variable valve lift control. Valve lift control enabled VVT-i are normally termed VVTL-i. VVTL-i engines are normally available to exclusive models for the likes of MR-S, Celica etc. Those engines have their output optimised for medium to high rev operations.
    All Toyota VVT-i/VVTL-i enabled motors run on DOHC configurations.
    VTEC usually is associated with valve lift control with many variations available. It is only when they released the i-VTEC version on the DOHC motor where they have both cam timing and valve lift control together. SOHC also have the i-VTEC version but it does not have cam timing as it is not possible on a single cam.
    To compare engine of similar displacements, lets look at the newest Vios VVT (1NZ-FE), current City VTEC (L15A) & newest Jazz i-VTEC (L15A). Have not come across VVTL-i enabled 1.5 liter engines nor 1.5 liter DOHC i-VTEC though.
    Engine Code: 1NZ-FE VVT-i L15A VTEC L15A i-VTEC
    Displacement CC: 1497 1496 1496
    Valve train: DOHC SOHC SOHC
    Valve timing control: Yes No No
    Valve lift control: No Yes Yes
    Transmission: 4AT CVT 5MT (5AT believed to be somewhere similar)
    Peak Torque: 14.4kgm@4200 14.6kgm@4800 14.8kgm@4800
    Peak HP: 109ps@6000 110ps@5800 120ps@6600
    FC based on Japan's 10-15 mode: unknown 19km/l 17.2km/l
    Have not come across the 10-15 mode for 1NZ-FE mileage wise but should be around the region.
    As VVT-i has no "VTEC" per say, VVT-i changes cam timing throughout the whole powerband giving optimum output at all rpm ranges. that is the main design goal and their biggest strength.
    SOHC VTEC/i-VTEC however does not have the luxury of variable cam timing, their strength rely on valve lift control to attain high specific output.
    katanya sich gt, tp gmn menurut saudara2 yg sudah berpengalaman sama mesin
    1 Day 23 Hrs 11 Mins 2 Secs
    Tarikan bwh enak vvti,tarikan atas enak vtec.
    3 Days 14 Hrs 19 Mins 1 Sec
    Quote Originally Posted by pegasus View Post
    dari sini, maka bergantung kita main di RPM tinggi apa rendah..kl rendah saya pilih VTI..sementara kl high rev, saya pilih L15A i-VTEC SOHC..btw..kl 2JZFE udah VTI atau belum ya?..
    Melbourne, Australia and DKI Jakarta, Indonesia
    1 Day 9 Hrs 58 Mins 18 Secs
    sya setuju ama bro damar..hehe
    dulu saya pake vios vvti dan new city vtec
    tarikan bawah enakan vios, tapi klo tarikan atas enakan vtec
    Quote Originally Posted by spoon honda View Post
    coba bisa kita gabungin yak..antara VVT-i sama vtec..
    1 Day 7 Hrs 49 Mins 26 Secs
    overall bagusan 1NZ-FE...selain irit jg powerfull..
    power di rpm atas (di atas 5.000rpm) ga beda jauh...sama2 110hp...
    sy pernah pake 2 2 nya
    Quote Originally Posted by rpamung View Post
    pake header 4-1 pendek ya bro?..
    Jakarta Bandung
    3 Hrs 55 Mins 29 Secs
    Power 1NZFE di rpm atas ga beda jauh ama vtec krn vtecnya sohc, vvti nya dohc. Intinya tarikan bwh enak vvti, atas enak vtec.
    J_TOWN
    1 Day 9 Hrs 18 Mins 44 Secs
    Wah bagus nih artikel nya jadi tau perbedaan VTi dan Vtec
    tp overal saya lebih suka Vtec
    INLINE BODYWORKS
    5 Days 14 Hrs 59 Mins 2 Secs
    gw koreksi dikit ya. ga ada yg namanya 2jzfe.
    di toyota ga ada VTi. yg ada itu VVT-i
    silakan dilanjut diskusinya
  1. Potensi Mesin 7A-FE
    By ancb10 in forum Diskusi Mesin
    Last Post: 25th June 2014, 12:28
  2. WTS : ENGINE COVER K20 FOR GE8 / MESIN L15A
    By blinkz in forum Jual Beli Mesin Lainnya
    Last Post: 20th May 2012, 11:18
  3. Potensi mesin SOHC dan A/T
    By Gran Turismo in forum Diskusi Mesin
    Last Post: 11th December 2011, 19:04
  4. Potensi mesin mazda lantis BP1800cc??
    By Lantis17 in forum Diskusi Mesin
    Last Post: 13th July 2011, 19:46
  5. mesin l15A
    By 200692 in forum Honda
    Last Post: 26th November 2010, 05:16
