Nakamichi PA-4100 4 Ch 800 Watt SQ Amplifier --> Booked
Results 1 to 10 of 28
  • Short URL:  http://modifika.si/181802
    12 Hrs 34 Mins 55 Secs
    Bro semua mau jual nih Ampli SQ kesayangan.
    Berikut kutipan spek dan deskripsinya:
    Building on Nakamichi's tradition of pure audio sonic excellence, innovative engineering and commitment to advancing the state of automotive audio fidelity, PA-4100 (4-Channel) sets new standards of performance and features to meet the needs of audiophiles. Audiophiles today expect their in-car audio entertainment to match the same level of performance as their home audio system. This is now made possible through the combination of cutting edge technologies and designs such as : High Current MOSFET Devices - An enormous power is available in reserve headroom to reproduce accurately the most demanding of your musical selections. The amplifier's ability to respond to music peaks is enhanced. MOSFET powered amplifiers also ensure minimal sound distortion and maximize sound amplification, even at great outputs. Gold-Plated Power and Speakers Connectors - It provides a softer and more reliable contact with lower impedance as compared to other materials. Most importantly, it ensures durability and a steady flow of current without interference, hence lowers impedance. Aluminum Printed Circuit Board (PCB) for All Transistors - This provides consistent thermal stability so as to achieve optimal audio performance.
    MOSFET Power Supply - Increase The Amplifier's Ability To Respond To Music Peaks Quickly And Efficiently, With Excellent Sound Quality
    Stereo & Bridges Mode Application
    Continuous Phase Control (0 - 180 deg)
    Terminal Layout At Bottom Of Amplifier
    4 Way Protection : Output Short, DC Offset, Thermal & Battery > 18 V
    Dual LED Indicators (Power & Protect)
    Double Power Output When Using A 2 ohms Speaker
    Aluminium PCB For All Transistors - Provide Consistent Thermal Stability
    Gold-Plated Power And Speaker Connectors
    Power Output RMS @ 4 ohms: 100 W x 4
    Power Output RMS @ 2 ohms: 200 W x 4
    Bridged Output RMS @ 4 ohms: 350 W x 2
    Frequency Response: 20 Hz - 20,000 Hz
    Crossover (Butterworth): HP 15 - 400 Hz LP 40 - 400 Hz
    Bass EQ @ 45 Hz: 0 - 12 dB
    S/N Ratio: >90 dB
    Total Harmonic Distortion: <0.05%
    Dimensions: 535 (W) x 63 (H) x 268 (D) mm 21.06 (W) x 2.48 (H) x 10.55 (D) inches # Weight: 6.61 kg / 14.57 lbs
    Kelengkapan: Ampli doang.
    [BOOKED]
    Maaf hanya Cash and Carry/COD.
    Kalo Bandung/Bogor di kotanya weekend bisa gw samperin asal dah pasti deal.
    Thank you.
    Enjoy the pics:
    Sundul dulu
    16 Hrs 28 Mins 8 Secs
    up...........
    @rin_dix: Thank you bos Rin_dix.
    Up up up :smt064
    Up dulu pagi2
    Sory Bro, apa bisa TT sama powerku? Audison LRX 2.250
    @Jazzcorner: thanks offeringnya bos. Minat sih, tp lg BU, jadi mau diduitin aja dulu. Selamat pagi semuanya.
    up dulu :smt026
    Up dulu Gan...power bagus :smt026
  1. WTA perbandingan nakamichi PA 4100 vs ARC audio 4050xxk
    By hanlex in forum Diskusi Power Amplifier
    Last Post: 7th August 2012, 12:43
  2. WTS Power Nakamichi PA 4100
    By DAV05 in forum Power Amplifier
    Last Post: 21st July 2012, 20:44
  3. Replies: 5
    Last Post: 6th January 2010, 15:15
  4. WTS Power Amplifier LM Cooper CP 4100.4
    By shdt38 in forum Power Amplifier
    Last Post: 22nd December 2009, 19:42
  5. WTA: Vox research MK II vs Nakamichi PA 4100
    By dani1012 in forum Diskusi Power Amplifier
    Last Post: 15th November 2009, 07:57
