harga head unit JVC KD AVX11
Results 1 to 10 of 25
  • Short URL:  http://modifika.si/18158
    medan
    4 Hrs 50 Mins 17 Secs
    harga baru dan bekas nya brp-an yaa...utk head unit JVC KD AVX11
    thx sob...
    5 Mins 24 Secs
    Re: harga head unit JVC KD AVX11
    Quote Originally Posted by yoyox
    thx sob...
    AVX11 masih bagu brooo....kalau cari bekas gw kira sulit deh masihan. harga avx11 baru kurang lebih 3.6 an
    5 Mins 24 Secs
    nih gambar-nya avx 11. model hampir sama persis ama AVX 33 yang sudah iinclude BT.
    spec-nya :
    Highlights
    • Power Output: 50W x 4 Max.
    • MOS-FET Power Amp
    • Built-in Widescreen Monitor
    • Ready for Bluetooth Adapter*
    • GIGA MP3 MULTI
    • WAV/MP3/WMA Compatible (DVD/CD)
    • DivX®/JPEG/MPEG1,2 Compatible (DVD/CD)
    • Ready for iPod**
    • 108MHz/12-bit Video DAC
    • 192kHz/24-bit Audio DAC
    • DTS Digital Out/Dolby Digital/ MPEG Audio
    • 7-Band iEQ
    • J-BUS Terminal
    • AV Output Terminals (Front/Rear/Subwoofer/Video)
    • AV Input Terminals
    • Motorized Slide-Out Face
    • Shock Proof Memory
    • Wall Paper Setting
    • Amp Defeat Switch
    • Tel. Muting
    • Rear-View Camera Ready
    * KS-BTA200 required, not available in some countries
    ** KS-PD100 required
    DVD/VCD Section
    • DVD-R/-RW, +R/+RW, VCD Compatible
    • Multi-Border DVD Compatible
    • Video Format: NTSC/PAL
    • Zoom (for DVD)*
    • Direct Chapter/Track Access*
    • Pause/Step/Slow*
    • VCD Playback Control
    * Remote control only
    Monitor Section
    • 2.7-inch Wide Color TFT Monitor
    • 16:9 Aspect Ratio (Selectable 4:3)
    • Selectable Angle
    • Aspect Select
    J-BUS Section
    • Bluetooth Adapter (KS-BTA200, not available in some countries)
    • Interface Adapter for iPod (KS-PD100)
    • Digital Player Interface Adapter (KS-PD500)
    • CD Changer
    • Line-In Adapter (KS-U57)
    • AUX-In Adapter (KS-U58)
    Bluetooth Wireless Technology Section*
    • Hands-free Call
    • Voice Recognition Dialing**
    • Audio Streaming and Control
    • SMS (Short Message Service) Display
    • Phonebook Transfer
    • Call Record List (Dialled/Received/Missed)
    • Auto Answer (On/Off/Reject)
    • Mic Gain Control (with Automatic Echo-canceller and Noise Reduction)
    ** In conjunction with voice recognition compatible mobile phone
    iPod Control Section*
    • Play/Pause
    • Skip/Search
    • Random/Repeat
    • Text Display
    * KS-PD100 required
    CD Section
    • CD/CD-R/CD-RW Compatible
    • CD Text
    • Direct Track Access*
    • Random/Repeat Play
    • Intro Scan
    Tuner Section
    • HS-IV Tuner
    • IF Filter
    • 18 FM and 6 AM Presets
    • Station Name Registration
    • SSM (for FM)
    • Seek (Up/Down)
    • AFNS/PNC
    • Stereo/Mono Switch (for FM)
    • Auto Antenna
    Amplifier Section
    • High-Pass Filter ON/OFF
    • Source-Specific Volume Control
    • Balance/Fader Control
    • Volume Attenuator
    • Max. Amp Gain Switcher
    General Section
    • Detachable Control Panel with Carrying Case
    • Beep Tone Support
    • COMPU PLAY
    • Power-Off Mode Eject
    • Multi-Function Wireless Remote Control
    • Power Switch Standby Illumination
    medan
    Quote Originally Posted by gio
    spec-nya :
    Highlights
    • MOS-FET Power Amp
    • GIGA MP3 MULTI
    • Ready for iPod**
    • 7-Band iEQ
    • J-BUS Terminal
    • Amp Defeat Switch
    • Tel. Muting
    DVD/VCD Section
    • Zoom (for DVD)*
    • Pause/Step/Slow*
    Monitor Section
    • Selectable Angle
    • Aspect Select
    J-BUS Section
    • CD Changer
    • Hands-free Call
    • Play/Pause
    • Skip/Search
    • Random/Repeat
    • Text Display
    * KS-PD100 required
    CD Section
    • CD Text
    • Intro Scan
    Tuner Section
    • HS-IV Tuner
    • IF Filter
    • SSM (for FM)
    • Seek (Up/Down)
    • AFNS/PNC
    • Auto Antenna
    Amplifier Section
    • Volume Attenuator
    General Section
    • Beep Tone Support
    • COMPU PLAY
    thx bro..
    btw, teknologinya mana nih yg paling tinggi antara AVX 11 dgn AVX 33..
    klo AVX 33...harga baru dan harga bekasnya brp-an ya..bro
    thx bro..
    yoyo (medan)
    semarang
    yg versi indonesia blututnya ad ga niy?
    semarang
    yg 33 layarnya 3,5 inch bro..
    yg laen ampir sama specnye
    semarang
    semarang
    yg ni ud msk lom ya d indo..kd nx5000..ni lbh canggih bs gps..hrg sekitar 5jtan...
    @ruli_ruli: speknya lumayan jaoh bro:
    avx-33 ada USB, Bluetooth, external microphone, A2DP ready, Time Alignment, 5.1 RCA Out:
    bluetooth module jvc kalo beli sendiri harga dikisaran 1,9jutaan ...
    padahal selisih avx11 ama avx33 cuman sekitar 1jt,
    belon usb nya ama SQ nya beda level.
    apa engga mending AVX-2 daripada AVX-11??
    di avx-2 ada time-correction, 5.1 RCA Out, layar 3,5inch
    di avx-11 engga ada semua diatas, layar lebih kecil
    harga beda dikitttttt ... under 600k
    semarang
    Quote Originally Posted by nut581
    avx11 ma avx 33 itu import ap ckd bro? blututnya bknnya sama2 a2dp yah?
GT Radial NGK Busi
  1. [ASK] Tanya harga head unit n monitor ini
    By shikimori in forum Diskusi Head Unit & Processor
    Last Post: 1st January 2011, 09:37
  2. WTS: HEAD UNIT DVD AVT IM-8810-TN 98%(update Harga)
    By g0lf in forum Head Unit & Processor
    Last Post: 29th January 2010, 14:20
  3. head unit apa harga ekonomis, kualitas oke!!
    By Lucky_777 in forum Diskusi Head Unit & Processor
    Last Post: 1st February 2009, 21:59
  4. harga head unit+fitur2nya
    By prakarsa89 in forum Diskusi Head Unit & Processor
    Last Post: 12th August 2008, 20:28
  5. head unit harga max 2jt
    By jungkiwenas in forum Diskusi Head Unit & Processor
    Last Post: 16th July 2007, 23:10
