WTS: Mcintosh MCC 602 - Turun Harga!!
Results 1 to 10 of 28
  • Short URL:  http://modifika.si/181212
    Jakarta 14240
    1 Hr 25 Mins 59 Secs
    Dijual:
    Mcintosh MCC 602
    Barang mulus sekali seperti baru, pakai hanya 4 bulan
    Tidak ada dus & buku
    Harga Nett Rp. 20 Juta
    Call / SMS: 0811887117 - 0817887117 - 0816888661
    Lokasi Kelapa Gading
    No PM please
    Spesifikasi:
    High Performance 2 Channel Power Amplifier
    # 300 watts x 2, 20-20kHz, (8/4/2) ohms, 0.005%THD
    # Bridged Mono: 600 Watts (4/2/1 ohms), 20-20kHz, 0.005%THD
    # Dual Pulse Width Modulated Power Supplies
    # Balanced Push-Pull Design
    # High Current Output (1 Ohm Stable)
    # Balanced Noise Canceling Inputs
    # Glass Top Plate w/Illuminated Wattmeters that measure both the current and voltage, and Visible Autoformers
    Gambar2nya:
    Quick Facts
    You know the electronics business has come a long way when you encounter a product like the McIntosh MCC602TM. Back in the Golden Days of home audio you might run into a massive stereo amplifier, built like a tank, gorgeous glass face plate with huge glowing blue meters, fully discrete, fully balanced, a classic push-pull capable of 300 watts per channel across 20 Hz to 20,000 Hz with virtually no distortion (0.005%THD). But in car stereo?
    It\'s a fact. The MCC602TM is just such a beast. Dual MOSFET PWM Regulated power supplies can pull that power from a battery rated at just 12-volts without shutting down everything else in your car or requiring a second deep cycle battery or alternator. You can even bridge this monster to produce 600 watts at the same bandwidth and distortion levels. With this kind of power you probably don\'t even need speakers. Just tape the speaker leads to your car door and the amp can shake the whole car. Current output is equally awesome and the system is stable even into 1 ohm.
    Balanced noise-canceling inputs are used to eliminate distortion caused by other sources in the car. McIntosh technology allows you to hook these inputs up even if your head unit lacks balanced outputs - these balanced inputs can be directly connected to the bridged speaker outputs of any head unit. An In/Out Pass Through provides easy hookup for multi amp systems. Each input has an individual level control and the inputs are summed for use on the subwoofer output. You can control the sub output through a remote sub level control - a nice feature.
    With all this power, you can\'t neglect protection - nobody likes car fires or smoked speakers. Here again McIntosh technology comes into play. Power Guard keeps you from over driving the amps. Actually, your ears will probably do this long before the Power Guard does but it\'s there as a back up. Sentry Monitor watches the power output stages on all channels. In the unlikely event that power surges dangerous enough to threaten the massive high current output devices suddenly appear, Sentry Monitor will shut down the power supplies and save your amp. Of course, a current surge that massive probably means your car has been struck by lightning, so the amp might be the only thing not cooked. Multi-stage Thermal protection uses temperature monitors mounted in the extruded aluminum cooling tunnel to control a variable-speed cooling fan. Although normally off, this fan will automatically turn on and will increase its speed as additional cooling is needed.
    On the short list of Amps-O-The Gods, the mighty McIntosh MCC602TM is a prominent resident. Incredible build, sophisticated power supplies, huge power and current output, attention to detail in both construction and performance, and - superficial though it is - those incredible glowing blue meters and visible Autoformers gleaming through that famous glass top panel - the MCC602TM is the stuff car audio dreams are made of
    Thanks for looking......
    klaten
    Pertamaxxxx....power mantabh
    Bandung - Jambi
    23 Hrs 56 Mins 15 Secs
    Mantaabbb!!!!
    Bantu up ya boss..
    4 Days 22 Hrs 57 Mins 5 Secs
    Bantu up bos, power mantab
    16 Hrs 28 Mins 8 Secs
    mantep bro....kok ud lama gak muncul???? muncul2 dagangan-nya dasyat
    2 Days 13 Hrs 1 Min 59 Secs
    Quote Originally Posted by jas View Post
    hajar bosss.......
    Bantu sondol bosss....
    surabaya
    4 Hrs 59 Mins 25 Secs
    Quote Originally Posted by davids88 View Post
    sondol apanya..
    sikat donk...
    hehehehe:p:p:p:p:p:p:p:p
    surabaya
    sondol dulu bosss....
    SuRoBoYo
    3 Days 18 Hrs 29 Mins 34 Secs
    bantuin sondol aja gan...
Venom 300x250 MBtech
  1. -- TURUN HARGA -- SALE: Sarung jok original Honda Jazz RS 2010.. -- TURUN HARGA --
    By byf_1225 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 17th January 2013, 21:12
  2. Replies: 67
    Last Post: 7th March 2011, 11:48
  3. Wts Hi End Mcintosh Mcc 444- 4ch- Turun harga, cuman 8,25jt
    By ric_signature in forum Power Amplifier
    Last Post: 2nd November 2010, 19:55
  4. Replies: 73
    Last Post: 18th September 2009, 19:42
  5. Replies: 1
    Last Post: 10th June 2009, 21:15
