J'S racing parts for Honda Jazz GE8
Tritala
RS Speed
Scuto Laminating Graha Indosound Venture CS II - Dua Lima Autowork
Results 1 to 10 of 71
  • Short URL:  http://modifika.si/179916
    Giro Point
    3 Days 9 Hrs 24 Mins 34 Secs
    Kami jUga menjual beberapa parts JS RACING untuk HONDA NEW JAZZ GE8
    J's Racing Carbon Steering wheel
    J 'SRACING steering wheel series was assumed to be shape to prioritize operativeness and the gripping feeling by the data cultivated by a lot of motor sports and the street test repeated on countless occasions.
    To improve the weakness of gripping feeling = grasp feelings seen by a pure steering wheel, the best grip feeling with the sense of security is pursued in the sports steering wheel.
    The result demonstrates the effect based on shape the suppression of driver's tiredness level for a long time like the endurance race etc. even if it is driving ..street.. greatly even if it is long and it is driving.
    The steering wheel externals set the street and the race scene, etc. from the pure diameter 365φ to acknowledged first diameter size in operativeness 350φ.
    The paddle shifter of purity used now to say nothing of the SRS module (air backing) and all accessories such as the audio navigation switches can be used as it is.
    Compactible with:
    Civic FD1/2
    Stream RN6-9
    FIT GE6-9
    By davinelika at 2009-08-29
    Carbon steering PANEL nya dijual terpisah
    J's Racing Front Strut bar
    [size=large]J 'S RACING fit GE6-9 SPL rear pillar bar[/size]
    J 'S RACING a fit GE6-9 SPL floor bar
    PM / CALL /SMS for PRICING!!![hr]
    J 'S RACING fit Stainless GE8 304-R rear tail 50R
    The slip-on muffler of a possible bolt on finally appears in the pure middle pipe.
    Security standard agreement SUS304 exhaust system rear tail
    - 1.9kg per purity 5.2 weight 3.3kg made of SUS304 *kg can be lightened.
    - The main pipe 50φ
    - Silencer body 130φ(dolphin tail 75φ)
    - Design according to complete model
    - Exclusive use inner silencer standard equipment
    The pipe secures lightening durability well by using the SUS304(1.2mm) tube.
    It is a security standard agreement model by whom it takes a sight to the street scene, the inside low-speed rotation region is not sacrificed, and best power and the volume achieve it.
    "304-R" The series achieves a further lightening compared with a stainless muffler of old goods, and constructs a special dyeing that is unlimited and near the specular processing and the titanium grilling gradation with which feeling of luxury overflows.
    The clear sound without a peculiar upper register mixing disregarding to the power feeling and SUS304 materials that value the feeling felt comfortable is obtained.
    The exclusive use inner silencer has been equipped normally.
    When doing sports running in the circuit etc. , it can enjoy power-up & sports sound by detaching the inner silencer.
    J 'S RACING a fit GE8 titanium exhaust system FX rear tail 50R blue
    Security standard agreement full titanium exhaust system rear tail
    2.4kg in weight made of super-light all titanium
    - 2.8g every purity 5.2kg can be lightened.
    The pipe is lightened by using the titanium 1mm tube.
    It is "RS" security standard agreement model by whom it takes a sight to the street scene and best power and the volume are achieved.
    "FX" The series achieved a further lightening compared with the titanium muffler of old goods and constructed the specular processing where feeling of luxury overflowed to the silencer part.
    The sound without the power feeling felt comfortable in which the feeling is valued and the mixing disregarding is obtained.
    ada 2 tipe, BLUE/POLISHED
    BLUE
    POLISH
    J 'S RACING fit GE8 titanium exhaust system FX central pipe 50C
    By davinelika at 2009-08-30
    J 'S RACING fit GE8 titanium exhaust system FX FRONT pipe 50F
    J's Racing Thermostat
    By davinelika at 2009-09-02
    It has the water temperature and the engine power in implications in the HONDA car of the high-power engine. ECU starts when the water temperature rises and a rapid down of power starts by measures of the crisis evasion like the fuel increase and the lag of the tide at the ignition timing, etc. (correction MAP).
    This product sets the temperature of an open valve (The main valve (sluice) is "Begin to open" temperature) from the thermostat of normality low, and cooling water's circulating to [rajieta-] ahead of time and always setting the water temperature around ideal 75℃-85℃ become possible.
    As a result, it becomes possible to control, to prevent the down of power, heat Darre, and the knock, and to draw out original engine power.
    JS racing GOLD emblem
    By davinelika at 2009-09-29
    JS RACING OIL CAP
    By davinelika at 2009-10-21
    J'S Racing SUS BRAKE LINE
    By davinelika at 2010-04-02
    JKT - LA - SEATTLE
    Giro Point
    1 Day 22 Hrs 47 Mins 44 Secs
    J'S Racing mang gak ada matinya, ntar d kl g beli jazz, g selon semua neh barang
    JL.MT HARYONO 904, BANGKONG, SEMARANG
    Giro Point
    50 Mins 9 Secs
    pm nett stirnya ya bos.... sm carbon steering panellnya...
    Giro Point
    Quote Originally Posted by dodolz_15 View Post
    hehehe... siapppppppppp... tar gabung genji juga skalian bro
    Giro Point
    Quote Originally Posted by CT View Post
    cek pm ye... utk stir gak ready stock, jadi harus inden ya
    Giro Point
    1 Mth 2 Wks 3 Days 22 Hrs 23 Mins 16 Secs
    wuih mantep2 da barang JS..... tunggu gw da ambil jazz d pas pertengahan taon ini.... bos klo boleh tau hrg tuh semua satu set brp duit???jd bs siapin dananya dr skrg.... hehehe thx
    Giro Point
    Quote Originally Posted by Aliongz View Post
    waduh.. yang mana aja bos yg u minat.. masa semuanya mau ditulisin??
    barang js yang pasti , 1 kata: MAHAL.. hahaha..
    kalo murah bukan J's Racing namanya
    Giro Point
    iya so pasti mahal...... 1 set semua bos... dr setir karbonnya ampek knalpot.... cukup ga bos 15jt??thx
    Giro Point
    mana dapet bos kl 1 set full.. knalpotnya aja 8 jt an.. stirnya 6.6 jt .. front pipe + center pipe js titan aja harganya uda kyk knalpotnya.. he he..
    Giro Point
    front pipenya kenak brp bro?
  1. Replies: 39
    Last Post: 10th November 2013, 10:56
  2. Replies: 1
    Last Post: 8th October 2012, 17:54
Silikon Motorsport
Street Race Rajawali
