WTA : Brax, Phass, Genesis, Tru ato Abyss??
Page 1 of 13 12345 ... LastLast
Results 1 to 10 of 130
  • Short URL:  http://modifika.si/178485
    17 Hrs 13 Mins 28 Secs
    Permisi para suhu2 sekalian, ane mao minta saran... Ane rencana mao pake Midbass Seas Excel, Midrange Seas Excel ma Twet Focal Be, klo menurut suhu2 sekalian bgsan pake power apa ya?? Pgnnya sehh rada dinamis,biar bisa dipake buat SQL jg
    Kmrn seh liat2 dpt saran bbrp merk n seri,menurut suhu2 sekalian mendingan yg mana yg value for money (rencana sehh beli 2nd maklum budget terbatas) :
    1. Brax X2400 (4 ch)
    2. Brax X2400.2 graphic ed. (4 ch)
    3. Phass TP 4.100 (4 ch)
    4. Phass HP 100 (2 ch)
    5. Abyss C 7.4, 4 x 175 W (4 ch)
    6. Abyss Mini AA (4 ch)
    7. Genesis DM, 2 x 100 W (2 ch)
    8. Genesis DM extreme (2 ch)
    9. Tru Tech C 7.4 (4 ch)
    10. Tru Tech T03. 4 x 150 W (4 ch)
    Sori pilihannya byk,abis bingung takut tar salah beli nyesel
    Rencana pakenya 1 power 4 ch ma 1 power 2 ch. Trus power2 yg ane sebut diatas char nya dinamis smua pa ga ya suhu??? Tq bgt sblmnya....
    Bali
    1 Hr 24 Mins 45 Secs
    waahh ini kelas berat semua neehh... ARC SE gak masuk itungan bos..?
    www.cliport-audio.com
    1 Wk 3 Days 18 Hrs 34 Mins 35 Secs
    kasih daftar pilihan yang lain yah bos AUDIOSYSTEM F4 600 lll amplifier made in italy karakternya powerfull & dinamis paling TOP :smt023:smt023
    High power in compact dimensions… The F4 are complete amplifiers, with an array of practical integrated-devices to manage the most sophisticated types of audio system. Made in two sections, they feature separate inputs to be used either together or on their own; each section is fitted with ultra-flexible electronic crossovers, designed to interpret the configuration requirements of both multi-channel systems as well as multi-amplified ones.
    F4 600 allows bridged mono connection as well as all Twister amplifiers, it supplies 2x460 Watt RMS @ 4ohm.
    INTEGRATED TECHNOLOGIES
    | GPS | Global Protection System
    The GPS includes a series of devices dedicated to the global protection of the amplifier and loudspeakers. Short-circuits and overheating, DC output and turn-on transient “Bump” are monitored constantly. This system controls the rotation of the cooling fan, adjusting its speed according to the temperature of the heat sink. Linked directly to the GPS, it guarantees a more effective disposal of the heat generated.
    | THERMOSPEED | Active Forced-cooling System
    This system controls the rotation of the cooling fan, adjusting its speed according to the temperature of the heat-sink. Linked directly to the GPS, it guarantees a more effective disposal of the heat generated.
    | E.NO.DE. | Electromagnetics Noise Destroyer
    The input circuiting of the Twisters is immune to noise generated by the vehicle’s electrical system. ENODE eliminates any ground-loops, enhancing the speed of installation and guaranteeing impeccable sound reproduction.
    RMS Stereo power @4ohm Watt 145 x4
    RMS Stereo power @2ohm Watt 230 x4
    Dynamic Stereo power @2ohm Watt 320 x4
    RMS Mono bridged power @4ohm Watt 460 x2
    Min. Stereo impedance load Ohm 2
    Min. Mono bridged impedance load Ohm 4
    Damping factor @4ohm - >300
    Input sensitivity range mV 0,174,3
    Input impedance Kohm >11
    Crossover [quantity] type - [2] HP or LP
    Crossover cut frequency range Hz 45300
    Crossover slope dB/oct. 12
    Frequency response -3dB Hz 10165.000
    THD distortion @1KHz - 90% 4ohm nom. power % <0,03
    DIM distortion - 90% 4ohm nom. power % <0,015
    Signal/Noise ratio - 10Hz22KHz - 90% nom. power dB 104
    Signal/Noise ratio "A" weighted - 10Hz22KHz - 90% nom. power dB 106
    Power supply range Volt 10,516
    Minimum cable size for 5 mt. long - Metric sq. mm 35
    Minimum cable size for 5 mt. long - US AWG 2
    Max current requirement Stereo @4ohm A 63
    Max current requirement Mono bridged @4ohm A 110
    Idle current A 1,32
    Standby current mA 2
    Fuses A 3x 40A
    Weight Kgs 4,6
    Dimensions L x W x H mm 220x550x50
    1 Day 16 Hrs 53 Mins 28 Secs
    waduh g perna pake power ginian..
    tp kayaknya plg oke brax deh..
    hehe maap klo salah..
    1 Mth 2 Wks 5 Days 4 Hrs 25 Mins 22 Secs
    ikut memantau ah...... barang hid end semua euy incaran nya hehhee
    Quote Originally Posted by bomber View Post
    Bukan ga masuk itungan suhu... Cm ane lom pernah dgr test drivenya
    Maklum msh nubie
    Suaranya bgs ya suhu?? Character nya gmn suhu???
    @ Cliport : Wahh dari spec-nya bgs tuhh suhu... Coba nti saya cari inpo2 dl,makasih suhu....
    @ 1501VT : Ahhhh suhu suka merendah neh, jgn2 powernya lbh dahsyat lg dari list saya,hehehee... Tq inpo na suhu....
    @ Aliongz : Namanya jg cita2 boss... Biar semanget nabung,hahahhaaaa.....
    Honoured Member
    Quote Originally Posted by cliport View Post
    Ini power mantab dengan tenaga Badaxz he he he
    jkt
    2 Wks 2 Hrs 18 Mins 48 Secs
    mobil nya apa yaaa,
    Bali
    Quote Originally Posted by blegug_sia View Post
    Maklum msh nubie
    Saya bukan suhu bos, hanya newbie yg suka baca2 trus utak atik sendiri audio di mobil dan pastinya belum sanggup bos pake power ginian, cuman demen baca2 reviewnya aja..
Vkool Venom 300x250
  1. (wta) phass at58 vs venture v26 vs brax ht1 vs phass at28
    By mingz92 in forum Diskusi Speaker
    Last Post: 12th April 2011, 02:25
  2. brax ge VS abyss mini VS celestra VA210
    By veild in forum Diskusi Power Amplifier
    Last Post: 11th December 2009, 22:17
  3. WTB BRAX-TRU-ABYSS
    By jeffooi in forum Power Amplifier
    Last Post: 1st November 2009, 23:58
  4. Apa Beda n Karakter dr amp ini: GENESIS, ABYSS, BRAX
    By gajah-nungging in forum Diskusi Power Amplifier
    Last Post: 18th January 2008, 23:59
  5. Pilih : Brax/Tru tech/Abyss/Genesis/Zelos
    By virtual_insanity in forum Diskusi Power Amplifier
    Last Post: 13th December 2006, 21:14
