*** FS : POWER CLIF DESIGN CD 700A & 600 A ***
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/178156
    1 Day 3 Hrs 5 Mins 42 Secs
    Dijual Power Clif Desig CD 700A & 600A , Kondisi barang masih sangat bagus
    Hub : 0813-101.45670
    Power CD 700A (Gambar atas)--> Rp 2jt
    Specification:
    Total Peak Power 525W
    RMS Pwr per CH @ 4 Ohm 350W
    RMS Pwr per CH @ 2 0hm 475W
    RMS Pwr Mono @ 4 0hm N/A
    THD @ 4 0hm <0.07%
    @ 2 0hm <0.14%
    S/N Ratio >95dB
    Channel Separation >60dB
    Frequency Response 0.5dB 10Hz-20kHz
    Crossover Frequency LPF 35Hz-250Hz
    Crossover Frequency HPF N/A
    Bass Boost 40Hz @ 6dB
    Low Level Input Range 200mV - 4V
    High Level Input Range 0.5V-4V
    Input Impedance 47k Ohms
    Damping Factor 337 Ohms
    Fuse 20 Amp x 3
    Dimensions (H x W x L) 12.1" x 2.5" x 13.7"
    Power 600 A (Gambar bawah) --> 2jt
    90W RMS Pwr x 4 CH @ 4 Ohms
    120W RMS Pwr x 2 CH @ 2 Ohms
    240W RMS Pwr x 2 CH Bridged @ 4 Ohms
    THD @ 4 Ohms <0.06%
    @ 2 Ohms <0.13%
    S/N Ratio >91dB
    Crossover Frequency HPF 35Hz-250Hz
    Damping Factor 180 Ohms
    Fuse 30 Amp x 2
    Dimensions (H x W x L) 12.1" x 2.5" x 21.6"
    17 Hrs 26 Mins 3 Secs
    up.........
    Upup.........
    thx bos..Uppp
    uppp...dulu
  1. FS : POWER ROCKFORD FOSGATE PBR300X4 DAN CLIF DESIGN CD600A
    By Trian.deni.nugraha in forum Power Amplifier
    Last Post: 9th September 2012, 04:42
  2. Replies: 1
    Last Post: 16th April 2012, 14:34
  3. Replies: 1
  4. WTS 12 IN CLIF DESIGN
    By KEKEPOPPY in forum Speaker - SubWoofer
    Last Post: 26th January 2011, 20:33
  5. wta clif design cd 600 a
    By mavz in forum Diskusi Power Amplifier
    Last Post: 29th December 2008, 22:45
