Mazda Premacy 2002 AT CBU muluuus- TURUN Harga
Results 1 to 10 of 39
  • Short URL:  http://modifika.si/178005
    Turun Harga
    Asli CBU Japan
    Tahun 2002 Bulan 7
    Tangan kedua
    Automatic Transmission
    7 Seater
    Pajak 2,2 jt
    Surat2 lengkap
    Buku Manual ada
    Buku Service ada
    MAZDA PREMACY SPECIFICATIONS
    ENGINE:
    Type ............ Four cylinder, DOHC, 16 valves
    Capacity in litres..................................... 1.839
    Induction ..................Multipoint fuel injection
    Fuel recommendation............................ PULP
    Claimed max. power ........ 91 kW at 6000 rpm
    Claimed max. torque ...... 163 Nm at 4500 rpm
    Specific power output.................49.2 kW/litre
    TRANSMISSION:
    Type ..............................Four speed automatic
    Driving wheels ....................................... Front
    Speed per 1000 rpm in top gear.......39.6 km/h
    WHEELS: ..........................Alloy, 6.0 JJ x 15
    TYRES:....................................... 195/55 R15
    Spare: ...................................... Steel full size
    STEERING:
    Type ...............Power assisted rack and pinion
    Turns lock to lock....................................... 2.8
    Turning circle (measured) .............11.3 metres
    DIMENSIONS:
    Mass .................................................. . 1336 kg
    Length ..............................................4315 mm
    Width (incl. mirrors 1925 mm) ........1705 mm
    Height............................................ ...1600 mm
    Ground clearance (measured).............131 mm
    Seating capacity ............................................ 5
    Fuel tank capacity............................... 58 litres
    TOWING:
    Max. towed mass (trailer plus load).......... 720 kg
    Max. towball download.......................... 75 kg
    MANUFACTURED IN:........................ Japan
    TEST RESULTS
    ACCELERATION:
    50 - 80 km/h (in Drive)......................... 5.1 sec
    60 -100 km/h (in Drive)........................7.2 sec
    0 - 80 km/h ........................................... 8.4 sec
    0 - 100 km/h ....................................... 12.3 sec
    0 - 400 metres..................................... 18.5 sec
    FUEL CONSUMPTION:
    Litres/100 km in city ................................ 10.0
    Litres/100 km on highway.......................... 7.8
    Litres/100 km overall ................................. 8.9
    BRAKING:
    Distance to stop from 80 km/h ......27.6 metres
    NOISE:
    Interior at constant 80 km/h..............69 dB(A)
    Info Tambahan
    Yang baru di ganti < 3 bulan :
    sensor pengapian
    koil 2 pcs
    pulley cruckas
    kompresor
    dryer
    timming belt dan printilannya
    engine mounting deket timming belt
    Yang baru diganti < 1 tahun :
    suspensi depan belakang
    karet2 boot
    laher kanan kiri
    tie rood kanan kiri
    matic set + body valve + kopling matic
    evap AC
    Bonus
    packing timming belt
    support suspension kiri belakang
    Tune Up tiap 50rb km (engine cleaner,fuel injection cleaner)
    ganti oli matic tiap 10rb km
    kuras matic tiap 30 rb km
    Diskon 2 jt kalo pake velg ini
    Bonus yang dimaksud
    blum pernah dipakai jadi tinggal pasang aja nih jok belakang
    Balik nama bulan 7 bisa pinjem ktp
    Kekurangan :
    -km tinggi tapi tenang dirawat dengan baik dan benar. sekitar 220.000
    -power stering perlu di servis
    -ga ada alarm
    Rp. 100.000.000 nego ---> Rp. 86.500.000
    Lokasi : Jakarta Timur
    Contact yang punya: 021 92574812, 0813 104 97216
    Contact ane klo yg punya lambat respon : 021 93115185, bisa jg PM
    numpang sundul
    yang minat family car CBU..
    17.55 WIB
    Depok - Sukabumi - Jakarta
    1 Hr 5 Mins 8 Secs
    sunduuuulll buat mobil keluarga CBU. . :smt026:smt026:smt026
    Quote Originally Posted by Die_Z View Post
    Makasih gan..
    Up Up
    18.02 WIB
    2 Wks 4 Days 18 Hrs 53 Mins 35 Secs
    Up..Up..Up..
    jakarta-seoul
    1 Wk 6 Days 4 Hrs 54 Secs
    cakep nih mobil..ehehe
    think 1st before u post something
    Quote Originally Posted by gia View Post
    Dibeli atuh gan... ntar tanggal 4 langsung deal ya di tmii?? hehehe
    up up
    13.06 WIB
    7 Mins 1 Sec
    mobil bagus nih...
    up up
    11.46 WIB
  1. Dijual Mazda Premacy Built Up A/T 2002
    By ichsanfirm in forum Mazda
    Last Post: 5th December 2011, 16:01
  2. Replies: 6
    Last Post: 20th February 2011, 01:15
  3. Mazda Premacy 2002 dijual
    By luck_ind in forum Mazda
    Last Post: 25th April 2010, 00:27
  4. [WTB] Mazda premacy 2002 - 2003
    By sideaway in forum Mazda
    Last Post: 20th October 2009, 13:52
  5. Mazda Premacy 2002 standard with 136hp asli mau dijual
    By sealand_11 in forum Merk Lainnya
    Last Post: 19th February 2008, 13:01
