******FS MSD AUTOMATIC DUAL COIL SELECTOR******
Results 1 to 10 of 25
  • Short URL:  http://modifika.si/177641
    Banten
    Features
    * Perfect for running dual MSD Ignitions
    * Must run 2 Ignitions and 2 coils
    Running redundant ignition systems gives you piece of mind during long races, but how do you swap the coil wire to the back up ignition? The MSD Automatic Coil Selector solves this problem.The Coil Selector has two posts that connect to the high voltage coil towers of the ignition coils while a third post connects to the distributor cap. When a racer switches from their primary ignition to the backup ignition, the Coil Selector automatically switches to the backup coil. You you must have two ignition controls, two coils and a single-pole, double throw transfer switch. All it takes is a flip of the switch to run a completely new ignition system.
    http://www.msdignition.com/product.a...+Coil+Selector
    MSD Automatic dual coil selector. Kondisi slightly used.
    Harga slightly used = 400 ribu rupiah.
    peminat telp aja 0254-9101666/021-93586661 (kalo di luar kota)
    Banten
    Suzuki G13B + Wiring + ECU + Girbok + TD04
    3SGTE, 7AFE, 1NZFE, 4EFTE, F20B, K20, D17,R18, K24 dll
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupupupupupupupupupup
    upupupupupupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    call 0254-9101666/021-93586661
    kasih komen dan cendolnya yah
    http://www.modifikasi.com/showthread.php?t=115929
    West Jakarta
    1 Day 9 Hrs 1 Min 54 Secs
    bantuuu upp bosss
    Banten
    makasih
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Jakarta Timur
    4 Wks 1 Day 7 Hrs 25 Mins 10 Secs
    Dagangannya mantab2 nih si Om...
    Banten
    ah biasa aja pak
    mantap kalo byk yg beli neh pak anung...
    gimana solunce makin kuenceng???
    Jakarta Timur
    Hehe bisa aja si Om....
    Solunce blm kenceng Om... blm ada modal PNP...
    Banten
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Jakarta Timur
    Yg dagang lg gak ada... bantu up ahh...
    Banten
    thx pak
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
  1. (For Sale) MSD Dual Coil Selector
    By jafarr in forum Jual Beli Mesin Lainnya
    Last Post: 1st February 2011, 08:13
  2. Sub dual coil
    By gemblunk in forum Diskusi Subwoofer
    Last Post: 15th December 2010, 23:21
  3. Sub. Dual coil dipasang 1 coil
    By smitel in forum Diskusi Subwoofer
    Last Post: 25th September 2007, 16:28
  4. dual coil & single coil
    By KampunG in forum Diskusi Subwoofer
    Last Post: 7th September 2006, 17:47
  5. Bikin Box Sub 12" dual coil
    By Cozy in forum Diskusi Instalasi
    Last Post: 19th July 2006, 01:38
