WORKS ENGINEERING - ADJUSTABLE CAM GEAR
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/177367
    CAM PULLEY / CAM GEAR
    DESCRIPTION
    Each gear is adjustable in 1 degree increments to a maximum +/- 10 degrees. Our Engraved timing marks are ACCURATE to within 1 minute of degree! With the simpler design our gears end up being LIGHTER than the stock gears they replace.
    Our tooth profile matches the OEM spec exactly for each gear we make. The outer cog section of our gears is black hard-anodized to prevent on/wear from the timing belt. We use black coat because of the great contrast it gives against our engraved timing marks. The 5-BOLT locking pattern is plenty secure and we use only stainless steel hardware to ensure durability. This design provides a lifetime of worry-free adjustments.
    Machining for optimum component fit is critical with adjustable cam gears. Any free play between the inner and the outer sections will cause the hardware to come loose no matter how much is tightened. Our extra care in the machining process guarantees you our gears will not come loose when you follow the torque specifications in our instructions.
    HORSEPOWER GAINS can be vary widely depending on whaet has been doe to the vehicle and how it is used. Gains from 5-20 horsepower can be realized.
    WHY USE ADJUSTABLE CAMGEAR ???
    HERE IS THE ANSWER ………… check this out :
    Adjustable Cam Gears increase horsepower and torque without having to change the camshaft(s) and are must-have items for engines that are milled, forced induction, high compression and/or utilizing aftermarket competition cams. The gears enable users to match cam timing with their vehicle's tuning state by advancing or retarding the cam profile in one-degree increments via true laser-etched markings. Precision-cut gear teeth ensure no premature wearing of the belt surface and AEM's anodizing on the gear teeth is lab-test proven as the hardest anodizing process on the market.
    Enough with the shitty theory , let us see the real things now , check these sites below : :smt068
    http://www.turbomagazine.com/tech/0806_turp_camshaft_shoot_out/index.html
    http://www.turbomagazine.com/tech/tu...n_8/index.html
    APLLICATION LIST
    MITSUBISHI ETERNA 4G63
    MITSUBISHI 4G63T EVO 1-9
    MITSUBISHI 4G92/3 DOHC
    MITSUBISHI 4G92 SOHC
    MITSUBISHI GALANT 6A12
    HONDA B SERIES DOHC
    HONDA K SERIES DOHC
    HONDA H SERIES DOHC
    NISSAN SR20DET
    NISSAN RB20/25/26
    MAZDA MX5/BP6/BP/NB6/8
    BMW 318i/ E30 / E36
    TOYOTA SUPRA / LEXUS 2JZ
    TOYOTA 4AGE
    TOYOTA 3S-GTE MR2/CELICA/CALDINA
    DAIHATSU L200 12V/MIRA TURBO
    1 Mth 2 Wks 1 Day 16 Hrs 25 Mins 39 Secs
    Bos untuk lancer ck4 4G92 SOHC harganya berapa?
    solo - D'cellular
    2 Days 13 Hrs 4 Mins 37 Secs
    k'lo bwt all new jazz ???
    solo - D'cellular
    pm nya blm d blz oom . . . .
    Exclamation Cheap juicy couture
    Cheap Juicy Couture shoes is a contemporary line of casual and somewhat dressy apparel based in Arleta, California, founded by Gela Nash-Taylor and Pamela Skaist-Levy. juicy couture Wholesale
  7. 5th August 2010, 00:17
    Reason
    spam
  1. WTB: Header Works engineering FD1
    By ape-ape in forum Jual Beli Mesin Lainnya
    Last Post: 4th January 2009, 22:05
