(((((........SUBWOOFERS LIST........)))))
Results 1 to 10 of 95
  • Short URL:  http://modifika.si/177221
    Exclamation (((((........SUBWOOFERS LIST........)))))
    XTANT a1040a 10 inch subwoofer + box kondisi muluus..............800rb nett
    call
    081388575788
    Lightbulb hi-end subwoofer 13 inch FOCAL 33WX......(SALE 2,75 JT NETTO)
    hi-end subwoofer 13 inchFOCAL 33WX.....................SALE 2,75 JT NETTO
    * IT'S FIXED PRICE BOSS,THANKS...
    (13") subwoofer for bass reflex enclosure
    (3") v.coil multi-magnet 12x72mm (12x2-7/8")
    Max. power handling: 700W
    Nominal, power handling: 350W
    Sensitivity (2.8 V/1m): 94.4dB
    Frequency response: 30Hz*-1kHz
    Manufacturer: Focal
    Have you been to heaven? Have you experienced nirvana? Have you been touched by the hand of God? If you've heard the Utopia line of speakers from Focal, you know what we're talking about. One listen to these superb, handcrafted speakers and you'll know what Utopia means. The Utopia line brings the listener into a completely separate world: the domain of those privileged few who are searching for the absolute best. Bringing together the most advanced technologies, such as the W. sandwich cone, the ultra-high power Telar57 tweeter, and multi-ferrite magnets, the Utopia line is notable for its superb fabrication as well as its exceptional performance levels. Each Utopia model is developed and built to provide the same stelar qualities as Focal's Grande Utopia, a true worldwide reference home speaker.
    Product Details and Features of 33wx :
    Key Features
    Car Speaker Type Component
    Elements 1-Way
    Car Speaker Function Subwoofer
    Size 13"
    Nominal Power Handling
    What is "Nominal Power Handling"? 350 Watt RMS
    Powered What is "Powered"? Non-Powered
    Technical Features
    Peak Power Handling 700 Watt
    Frequency Response 30 Hz - 1 kHz
    Sensitivity 94.4 dB
    Components
    Magnet Material Strontium Ferrite
    Mounting
    Top Mounting Depth 5.91 In.
    call
    081388575788
    Lightbulb A pair of A/D/S AS10 subwoofers for collection (only 1 left).......
    call
    081388575788
    Lightbulb DIGITAL DESIGN 512b (newly launched from dd usa) kondisi BARU......(HANDMADE IN USA)
    DIGITAL DESIGN 512b (seri terbaru dari digital design USA) kondisi BARU..........@2,4jt
    price list : USD 449
    DD500b
    The newly upgraded 510b and 512b subwoofers bring DD impact and durability to the most affordable price ranges we've ever offered. You still get the hand built, high performance quality at a price within every budget. The 500b Series was designed to optimize performance from amplifiers in the 100-400 watt RMS range. Not everyone is going to try to crush their tonsils with the latest bass-jacked MP3, but that doesn't mean one should have to settle for lower quality parts or design.
    The 500b series woofers benefit from the highest quality parts available, close production tolerances, and hand built quality as do all DD woofers. The motor and moving systems have been designed to get higher efficiency from lower powered systems. We found ways to reduce mass from the cone, surround, spiders and voice coil which raises the efficiency on a given level of power. The suspension stiffness and excursion capability were carefully dialed in through many real world test samples. The result is a very fast woofer capable of delivering surprising output from modest power sources.
    The 500b Series feature multiple layers of durable cloth in the spider system, our exclusive laminated lead wires into the spider layers, double laminated half-roll surround, non-pressed cone and a motor system modeled after the 3500e Series woofers. The 510b and 512b are very easy to use in vented, TLs, and specialized band-pass boxes and are the perfect presents in gift boxes. Now there aren't any excuses to get anything less than a DD system in every car.
    We recommend to allow at least several weeks of playing time to break in DD Woofers, full break in may take many months. DO NOT play subwoofers at max amplifier power in the first couple of days, give the suspensions a chance to loosen up. As the suspension breaks in, the subs will play lower and louder.
    After you give the woofers a chance to break in (you'll know when this happens because the woofers will be playing lower and louder) you can start to look at port changes to alter the sound to your personal taste and your vehicles acoustic loading conditions
    Features
    * Optimized for 100-300 watt systems
    * Multi-layer spiders
    * Laminated surround
    * Double stack magnets
    * High-temp voice coil
    * Laminated tinsel leads
    * Hand-built quality
    * Rubber Magnet Boot
    SPECIFICATIONS
    Series 500b
    Voice Coil Diameter 2.0"
    Magnet Weight 90 oz
    Power Handling RMS/Peak 300/1200
    Suspension 50 mm
    Nominal Impedance 4.0 Ohm
    DC Resistance 3.4 Ohm
    Model 512b
    Rec Box (cubic ft) 2.5
    Port Area (sq in) 40
    Port Length (inches) 22
    Woofer Diameter 12"
    Free Air Resonance 36 Hz
    Qts 0.433
    Qes 0.499
    Qms 3.29
    Vas 60L
    Sensitivity 89dB
    Shipping Weight 14 lbs
    call
    081388575788
    Lightbulb MAC-AUDIO ALIANTE 12 Black LIMITED (made in Germany).................
    MAC-AUDIO ALIANTE 12 Black LIMITED (made in Germany)................4,75jt
    http://www.mac-audio.de/index.php?id=2532&L=1%27
    Prinzip / DIN-Ø 300 mm / 12" Subwoofer
    Belastbarkeit RMS / max. 500/1200 Watt
    Impedanz 4 Ohm
    Frequenzbereich 18-250 Hz
    Schalldruck 88 dB
    Aussendurchmesser 320
    Lochausschnitt 288 mm
    Einbautiefe 82
    Rdc 3,3 Ohm
    Fs 20 Hz
    Qms 2,19
    Qes 0,27
    Qts 0,24
    Vas 138 L
    Xmax 18
    Korb Mehrteiliger Alu Druckguss Stahl Korb
    Einbaudurchmesser 288
    Free Air nein
    Geschlossenes Gehaeuse / Q=0.7 24
    Bassreflexgehaeuse mittel 56
    Reflexrohre BR mittel Anzahl 1
    Reflexrohre BR mittel Durchmesser 10
    Reflexrohre BR mittel Laenge 34
    Besonderheiten
    * Mehrteiliger verschraubter Alu-Stahl-Korb mit spezieller Legierung
    * Neue Backplate mit 30 % mehr Luftdurchsatz zur Verringerung der Kompression
    * Flachmembran aus Aluminium-Glasfaser-Honeycomb für einen 100 % kolbenförmigen Membranhub
    * 125 mm High Power Schwingspule mit Ferrofluidkühlung
    * Schwarz eloxierter Aluminium-Schwingspulenträger für optimale thermische Stabilität
    * SYMADIS Magnetsystem, 3fach Magnetsystem für ein im Luftspalt exakt symmetrisches Magnetfeld
    * Vernickeltes Pushterminal für eine Kabelsaufnahme bis 6 mm_
    * Flache Bauform mit nur 82 mm Einbautiefe
    * Exklusive Holzverpackung
    * Gehäuse geschlossen: 24 Liter
    * Gehäuse Bassreflex: 56 Liter, Reflexrohr dxl: 10 cm x 34 cm
    * Ausgeliefert wird das Klangjuwel aus Aluminium, Stahl und Glasfaser in einer exklusiven Holzschatulle – Standesgemäß natürlich - wie es sich für derartige Schmuckstücke gehört!
    * Multi-section bolted aluminium-steel basket with special alloy
    * New back plate with 30 % more air throughput to reduce compression
    * Flat cone made of aluminium-fibre glass honeycomb for 100 % piston-type cone travel
    * 125 mm high-power voice coil with ferro fluid cooling
    * Black anodised aluminium voice coil support for optimum thermal stability
    * SYMADIS magnet system, triple magnet system for a precisely
    * symmetrical magnetic field in the air gap
    * Nickel-plated push terminal to accommodate cables up to 6 mm2
    * Flat design with just 82 mm depth for flush fitting
    * Exclusive wooden packaging
    * This sound jewel made from aluminium, steel and fibre glass is delivered in an exclusive wooden case as standard, of course, just as it should be for such gems!
    call
    081388575788
    SuRoBoYo
    3 Days 18 Hrs 29 Mins 34 Secs
    wah sub manteb ne...
    unik ya bentuknya...
    thanks yach bos sazuke........
    Tangerang
    2 Days 17 Hrs 40 Mins 48 Secs
    d
    boss impendansi 8 ohm ?
    nyari buat home nih
    bukan bos,ini 4 ohms bos,rencananya mau cari sub home merk apa bos?
    Lightbulb MMATS PRO P2 10 inch subwoofer........700rb
    features :
    * Chromed steel basket
    * Features of our other subwoofers but at moderate power handling
    * 350 Wrms power handling
    * 2.0" four layer Kapton dual voice coil
    * High excursion suspension with flat spider
    * Poly cone and foam surround with polymer sealant
    * All new machined and chromed back-plate!
    * P2.0 10" Subwoofer
    * Dual 4 Ohm Voice Coils
    * Fs (Hz) 26
    * Vas (Liters) 69.6
    * Qts .34
    * SPL (1W/1M) 87 dB
    * Power (Wrms) 350
    * Mounting Depth (inches) 5-5/8"
    * Hole Diameter(inches) 9-3/16"
    * Speaker Displacement (cuft.) .07
  1. LIST AIR FILTER REPLACEMENT SIMOTA (updated list)
    By SIMOTA in forum Simota Racing Sports
    Last Post: 14th May 2016, 06:02
  2. Assesoris corrolla ke 20 , 30 list talang , list cap mesin dll
    By atigabarpack in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 27th May 2012, 22:20
  3. [FS] SPEAKERS AND SUBWOOFERS (2ND)
    By dims_audio in forum Speaker - SubWoofer
    Last Post: 5th March 2011, 15:20
  4. ((((((......New & Used Subwoofers.......))))))
    Last Post: 9th February 2011, 23:12
