Silikon Motorsport
Kotamas Knalpot
Tritala Rajawali Autogallery Banner Available 242x90
Page 1 of 20 12345 ... LastLast
Results 1 to 15 of 286
    Colonel
    2 Wks 12 Hrs 26 Mins 6 Secs
    Exclamation (((((........****AMPLIFIERS LIST****........)))))
    power zapco competition z300slx kondisi muluuuus..................2,2jt
    2 x 100W @ 4 ohms (THD <.03%)
    2 x 150W @ 2 ohms (THD <.05%)
    2 x 235W @ 1 ohm (THD <.15%)
    1 x 300W @ 4 ohms bridged (THD <.04%)
    1 x 415W @ 1 ohms bridged (THD <.1%)
    bs stabil maen di 1ohm , made by robert zeff...
    ini seri zapco tertinggi di jaman nya..
    call
    081388575788
    Colonel
    Exclamation phoenix gold octane limited edition kondisi muluuuuus........
    phoenix gold octane limited edition kondisi muluuuuus............12,5jt
    spec :
    4 x 100 watt @ 4 ohms
    ONLY 250 of these amps were ever built!!!!!!!!
    This is not the new crap they are pumping out this the last of the quality made componants before everything went offshore. This amp is made of 2 zx600ti(v2) with rail stiffening capacitors and a basscube under one cove. I would call it an 9.5 out of 10 cosmetically but these went for $3100 new and the old PG stuff is still sought after by colletors so no low ball offers please. the amp was tested and put out almost 850watt RMS.
    call
    081388575788
    Colonel
    Exclamation Highest spec of "PHOENIX GOLD Titanium Series Line-up" Ti 1000.2..............
    Phoenix Gold Titanium series adalah seri tinggi dari Phoenix Gold
    Titanium Line ini masih asli diproduksi di USA,ketika seri Phoenix Gold lain sudah diproduksi di luar USA
    Phoenix Gold Ti1000.2
    Titanium line
    2 x 250W @ 4 ohms
    2 x 500W @ 2 ohms
    1 x 1000W @ 4 ohms bridged
    Fuse: External 80A
    call
    081388575788
    Colonel
    Exclamation 5ch SPL dynamics S-4005 kondisi NOS,lengkap..................
    5ch SPL dynamics S-4005 kondisi NOS,lengkap.................2,9jt
    SPL DYNAMICS is a registered Finnish car audio trademark owned by Flextron Oy. Our full line of
    high quality car audio components for domestic and international markets is developed
    and engineered in Finland.
    S - series amplifiers
    SPL Dynamics S-series amplifiers technical features and impressive design raise them
    to a new quality level. Our research & development team members loaded their best
    knowledge into this unique amplifier line.
    S-series amplifier line was designed to cover all the needs of car audio and tuning enthusiasts.
    Wide range of models ensures that enthusiasts can create installations with uniform look
    and feel covering all their needs.
    The technical features of S-series amplifiers don’t leave anyone cold. Each model has 24dB/oct
    fully variable active bandpass filters. 3- or 4-way active systems can be made with wide range
    filters. Highpass filters start from 15Hz, so it can also be usedas a subsonic filter for
    subwoofer. Input mode switch (4- & 6-channel models) allow to choose whether you
    use the whole amp with single RCA pair or each channel pair with separate RCA cables.
    Power and speaker terminals are gold plated. Amplifiers are also equipped with
    soft turn-on/turn-off circuit and effective multiple protection circuit.
    Specifications S-4005 :
    RMS Power 4 Ohm (channels 1-4) 4 x 50W
    RMS Power 2 Ohm (channels 1-4) 4 x 85W
    RMS Power 4 Ohm (channel 5) 1 x 200W
    RMS Power 2 Ohm (channel 5) 1 x 320W
    THD (A-weight) < 0,05%
    Input sensitivity 200mV - 4 V
    Low Pass (18dB/oct) (channels 1-4) 40 - 600 Hz
    High Pass (18dB/oct) (channels 1-4) 40 - 600 Hz
    Low Pass (18dB/oct) (channel 5) 40 - 600 Hz
    Dimensions (W x H x L) mm 248 x 51 x 430
    call
    081388575788
    Colonel
    PANASONIC M9004 4ch amplifier (sold,thanks modcom...)
    PANASONIC M9004 4ch amplifier (Made in Japan) kondisi muluuus.........sold
    4 x 90 wats RMS
    call
    081388575788
    Colonel
    Exclamation RARE DAVID HAFLER MA-1 DUAL MONO amps kondisi no ex service...........
    RARE DAVID HAFLER MA-1 DUAL MONO amps kondisi no ex service.........1,1jt
    cikal bakalnya rockford fosgate nich bos...
    spec @ 12 volts :
    2 x 100 watt rms @ 4 ohms
    underrated power output
    ini hasil googling dari otak suhu pemula audio dan reviewnya tentang hafler :
    In 1987, the Hafler product line was acquired by Rockford Corporation of Tempe, Arizona. This led to more advances in products and technology including the patented Trans-nova power amplifiers.
    Nahh... TransNOVA (Transductance NOdal Voltage Amplifier) ini nih yg dipake Rockford buat power seri 250x2, 250.2, 250m2 dkk. Sistem TransNOVA ini bisa menghasilkan suara lebih bagus dan lebih efisien. Hehehe... Sooo? De kesimpulan is... Cepetan deh sikat HAFLER-nya. Barang bagus ini.
    (thanks a lot ya bos pemula audio yang canggih n baik,he..he.he......)
    call
    081388575788
    Colonel
    KRONE RAMP-275x kondisi muluuus.......... (sold,thanks modcom..)
    KRONE RAMP-275x kondisi muluuus.......sold
    call
    081388575788
    Colonel
    Exclamation ADS PowerPlate 80 kondisi muluus n no service......
    ADS PowerPlate 80 kondisi muluus n no service.........700rb
    call
    081388575788
    Colonel
    Exclamation 6ch ADS Powerplate PH 15.2 kondisi muluus n no ex service.......
    specifications :
    6x50W RMS @ 4ohms
    call
    081388575788
    Colonel
    Exclamation ADS P850 8-ch Power Amplifier kondisi muluuuus.............
    a/d/s/ P850
    Key Features
    Amplifier Type Multi Channels
    Bridgable Bridgable
    RMS Power at 4 Ohms 50 W x 8
    RMS Power at 2 Ohms 75 W x 8
    RMS Power at 4 Ohms bridged 150 W x 4
    Fuse: 2 x 40A
    Performance
    Frequency Response 10 Hz - 30000 Hz
    Signal to Noise Ratio 90 dB
    THD at Rated RMS Power 0.1 %
    Dimensions
    Width 16.13 in.
    Depth 13 in.
    Height 2 in.
    Price Paid:
    $700.00 from ebay
    Strengths:
    pure clean power no need for multple RCAs one set does it all just a nice amp......
    Weaknesses:
    none
    Summary:
    more than what i expected 1 amp does it all even running a sub gona purchase a second one for the ultimate system
    call
    081388575788
  12. #11
    Colonel
    Exclamation Hi-end STEG MASTER STROKE MSK 3000 muluuuus........
    Hi-end STEG MASTER STROKE MSK 3000 kondisi muluuuus..............20jt
    2 x 400 watt @ 4 ohms
    2 x 800 watt @ 2 ohms
    1 x 1600 watt @ 4 ohms
    1 x 3000 watt @ 2 ohms
    call
    081388575788
  13. #12
    Colonel
    Exclamation "NEW" DIGITAL DESIGN C2b amplifier garansi full 1 tahun...........
    NEW DIGITAL DESIGN (DD) C2b amplifier garansi full 1 tahun......3,75jt
    class ab-1ohm technology amplifier..
    very clean and good transient bass!!
    $459.00 / €288.00
    SPECIFICATIONS
    120Wrms x 2 @ 4 ohm
    180 x 2 @ 2 ohm stereo
    230 x 2 @ 1 ohm stereo
    460 x 1 @ 2 ohm mono
    1 ohm stable
    Input Sensitivity 0.2V - 6V
    Variable High Pass Filter 30Hz - 1.2KHz
    Variable Low Pass Filter 30Hz - 500Hz
    Variable Sub-sonic Filter 24dB/Oct 10Hz - 100Hz
    Variable Bass Boost 0-12dB @ 45Hz
    Tested Voltage 14.4
    Tested THD 0.02%
    Model C2b
    Damping Factor >100
    Dynamic Power 960W
    Efficiency thru Output 65%
    Dimensions - mm 244.5W x 54.3H x 330L
    Dimensions - inches 13L x 9.63W x 2.14H
    Signal to Noise >100dB
    Shipping Weight 10 lbs
    Features
    * Murdered-Out power & speaker terminal blocks
    * Power & Protection indicator LEDs
    * Switchable crossover function LPF/FULL/HPF
    * Variable subsonic filter
    * Variable bass boost
    * 5-way protection circuit
    DDC2b - Amplifier
    The C Series amps are our Go-To amps for most daily driving applications. The C amps offer good sound quality, install friendly features and high-end cosmetics at price points normally associated with budget, entry level offerings. These high value amps feature stable and reliable class AB circuits which are ideal for driving either full range or subwoofer applications.
    System Design
    The preamp section gives flexible versatility to accommodate many installation needs. Each channel of the C amps can be set for low pass filtered operation; high pass filtered or full range operation. Single channel and 2 channel amps have sub-sonic filters added in order to band pass the subwoofer range. Two or three amps can be combined to run 2-way or 3-way setups. One amp can be band passed for the sub, a second amp to run mid/high speakers. More complex 3 way systems can be setup for band passing dedicated mid-bass drivers or midrange drivers.
    Each pair of channels also feature a 12dB bass boost at 40 Hz. Single channel and 2 channel amps add optional remote gain controls.
    Class AB Designs
    The C amps use high quality Class AB designs with parts chosen for smooth and reliable operation. The PCBs are double sided, high grade epoxy in order to move current efficiently with excellent thermal management. Properly sized power supplies matched to over-designed output sections deliver strong transient response and tight bass. The C amps are meant to be True To The Source, to make your music or vibratory experience as close to the source signal as possible, and perform like this for years to come.
    Thermal Management
    The heat sink design of the new DD amps yields maximum dissipation for a given amount of length. Horizontal and vertical fins allow convection cooling from multiple mounting angles. Extra heavy heat sink rails, built into the rail corners, are used to carry heat away from the Mosfets and transistors. The output devices are mounted on the upper rail, below the top surface where heat can expand to both top fins and side fins. The transistor bank is situated toward the center of the amp so heat can outflow equally to both sides. The end panels are also vented to allow heat buildup to escape the PCB cavity.
    Great All Purpose Amps
    Having to choose between good performance and good pricing is no longer a decision one has to make. The C amps are well designed, use high quality parts, deliver good performance and offer great system flexibility. The C amps were not designed by a marketing department, not designed to highlight LED research into non-operational cosmetic compulsive Vegas induced lightshows or to claim hydroelectric output capability from a handful of actual parts. These are amps designed for good performance, amps we are happy to use in our own cars, and amps that will serve you well for a long time.
    call
    081388575788
  14. #13
    Colonel
    Exclamation POWERAMPER XS 2.150 kondisi muluuus,lengkap dus n buku.....
    POWERAMPER XS 2.150 kondisi muluuus,lengkap dus n buku........... 1,25jt
    call
    081388575788
  15. #14
    Colonel
    Exclamation KICKER X100s Competition amplifier (800W RMS) kondisi muluuus..........
    This amp is very underrated. It is rated at 50x2 watts at 4ohms stereo and bridged at 1ohm it will put out 1400 watts or more.
    Kicker X100S competition amp
    50 watts x 2 @ 4 ohm
    100 Watts x 2 @2 ohm
    200 watts x 2 @1 ohm
    400 watts x 2 @1/2 Ohm
    200W Mono @ 4 ohm
    400W Mono @2 ohm
    800W Mono @1 Ohm
    Frequency response : 10Hz ~ 30Khz
    Signal to Noise Ratio : >100dB
    call
    081388575788
  16. #15
    Colonel
    Exclamation the monster "Fusion FCA-4000D" (only 100 pieces ever built).............
    titipan temen nich bos :
    Fusion FCA-4000D
    ADDITIONAL POWER RATINGS 12.6VDC
    1 x 1780W @ 4 Ohms
    1 x 3100W @ 2 Ohms
    1 x 3890W @ 1 Ohms
    Output power at 14.4VDC
    1 x 3160 @ 2 Ohms
    1 x 4120W @ 1 Ohm
    S/N ratio :> 65dba
    THD 0.05%Damping Factor >
    call
    081388575788
ACM 242x90 Hasta Otostereo
  1. LIST AIR FILTER REPLACEMENT SIMOTA (updated list)
    By SIMOTA in forum Simota Racing Sports
    Last Post: 11th May 2013, 06:38
  2. Assesoris corrolla ke 20 , 30 list talang , list cap mesin dll
    By atigabarpack in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 27th May 2012, 22:20
  3. ((((((.......Branded Amplifiers.......))))))
    By MR.GASOLINE in forum Power Amplifier
    Last Post: 23rd October 2010, 13:50
  4. ((((((.......NEW & New Old Stock Amplifiers.......))))))
    Last Post: 23rd October 2010, 13:49
  5. FS : LIST TALANG AIR DAN LIST KAP MESIN DX(NOS) + KACA DX DX
    By kevas in forum Bursa Eksterior Lainnya
    Last Post: 8th June 2009, 18:15
Velgvelg Rajawali Autogallery
