INTRODUCING OUR NEW SCANSPEAK TYMPHANY SUBWOOFER
Results 1 to 10 of 40
  • Short URL:  http://modifika.si/17704
    2 Wks 6 Days 20 Hrs 17 Mins 20 Secs
    NAMED TYMPHANY LAT
    FOR CAR type :LAT500
    Driver Highlights: The power of two 10 subwoofers in a sleek tube-shaped transducer only 5 wide.
    http://www.tymphany.com/products_Tymphany_LAT.html
    Electrical Data
    Nominal impedance Zn 4 ohm
    Minimum impedance Zmin 3.2 ohm
    Maximum impedance Zo 46 ohm
    DC resistance Re 3.1ohm
    Voice coil inductance Le 1.5 mH
    T-S Parameters
    Resonance Frequency fs 28 Hz
    Mechanical Q factor Qms 9
    Electrical Q factor Qes 0.5
    Total Q factor Qts 0.45
    Force factor Bl 13 Tm
    Mechanical resistance Rms 3 Kg/s
    Moving mass Mms 160 g
    Suspension compliance Cms 0.21 mm/N
    Effective cone diameter D 25.9 cm
    Effective piston area Sd 525 cm2
    Equivalent volume Vas 81 ltrs
    Sensitivity (2.83V/1m) 92dB
    Ratio BL/√(Re) 7.5
    Ratio fs/Qts F 61
    Power handling
    100h RMS noise test (IEC) 250 W
    Long-term Max Power (IEC 18.3) 750 W
    Voice Coil and Magnet Parameters
    Voice coil diameter 38 mm
    voice coil height 21.3 mm
    Voice coil layers 4
    Height of the gap 8 mm
    Linear excursion +/- 6.7 mm
    Max mech. excursion +/- 10 mm
    Diameter of magnet 115 mm
    Height of magnet 17.5 mm
    Weight of magnet 2.72 Kg
    REACH UNTIL 134 Db !!!!!!!!!!
    ALREADY USED BY ALPINE : PLV7
    Jakarta Selatan
    4 Mins 19 Secs
    Dah bisa didengerin bro?
    blm bikin boxnya.... nguikkk... susah... musti pake port... ama pake akrilik baru bagus... udah ditest langsung tanpa box... MANTAP !!!!
    Jakarta Selatan
    4 Mins 19 Secs
    o gto, brg udh ada dong? passive / active bro?
    udah ada... passive... aktif yg alpine plv7... tp ga masuk ke indo
    5 Hrs 21 Mins 25 Secs
    berapaan bro?
    Jakarta, Bandung
    4 Days 9 Hrs 1 Min 12 Secs
    Bos Jey,
    itu bendanya sebesar itu aja? Trus emang wajib pake box lagi atau bisa dipasang gitu aja?
    Menarik nih...
    Harganya berape duit?
    The Altair - HiFi Speaker
    B*TOWN
    1 Day 4 Hrs 53 Mins 35 Secs
    lucu yah bos bentuknya?
    harganya berapaan bos jey
    Quote Originally Posted by masswork
    Bos Jey,
    Menarik nih...
    yup sekitar panjang sekitar 50cm... wajib pake box, dengan port atau labirin
    info harga dunk bro
  1. WTS Subwoofer Scanspeak 23 W, seperti baru, lengkap dus
    By ric_signature in forum Speaker - SubWoofer
    Last Post: 29th December 2010, 12:34
  2. FS: SubWoofer ScanSpeak 23W Mulus sekali
    By LedZeppelin in forum Speaker - SubWoofer
    Last Post: 8th October 2009, 14:01
  3. hi-end scanspeak 23w revelator subwoofer.....(sold,thanks modcom....)
    Last Post: 17th September 2009, 07:05
  4. WTA Subwoofer scanspeak
    By saddam in forum Diskusi Subwoofer
    Last Post: 3rd September 2009, 10:56
