- Milbert BAM 235
upgraded tubes n coupling capacitor 1 unit 14.5jt
standard 1 unit 13jt
The patented, all-tube BaM-235 has ten tubes and zero transistors in its two audio signal paths. All tubes are operated conservatively, with proper, regulated voltages and enormous power reserves. Proven over decades of time, the BaM-235 design, with its high-end pedigree, numerous glowing reviews, repeat startling performances, and solid history of reliability and unmatched sound quality, remains the world's only all-tube car tube amp in continuous production since 1986.
Sound & Other Qualities
BaM-235 has 10 tubes, 100% pure tube signal path with no semiconductors.
Patented circuitry. High-end audio pedigree. Numerous glowing reviews.
Only real, all-tube car amp in the world made and sold worldwide since 1986.
Not much stays in production for two decades; we did it right to begin with.
20 years on, we think it still has unmatched sound quality.
25 pounds and shoebox size, it consistently delivers the best sound possible.
Impervious to microphonics (noise from vibration).
Any audible noise is extremely low, even on sensitive horns.
100% hand-made in USA, highest parts and build quality possible.
Proven 10+ year tube lifetimes. Proven stable, durable and road-worthy.
Power Consumption
Remote turn-on current draw is approximately 20mA, very small.
Idle current is approximately 5A, about the same as one headlight.
No special needs or requirements beyond any typical car amp.
Regulates and stores over 100 joules of energy internally at high voltage.
Mounting & Temperature
Shock resistant neoprene "well-nuts" are provided for mounting.
Can be mounted in all but the upside-down position.
Heat limiter shuts the amp down at about 100degC.
Sturdy, aircraft-aluminum chassis dissipates heat.
Inputs
Chassis fuse in negative line; positive line fuse is required near car's battery.
Undervoltage lockout shuts the amp down if input power drops below about 10-Volts.
Signal input connectors are gold/teflon RCA jacks. 100kOhm input impedance.
Full power output (input sensitivity) from 1- to 10-Volts, adjustable.
Outputs
Output connectors (and power connectors) are #8 barrier strips, easy to use.
Output impedance is selectable among 16-, 8-, 4-, 2-, 1-, and 1/2-Ohm.
The amp's two channels may be "paralleled" to double the output power.
30 watts, 2 channels. Can sustain direct shorts --the amp can not be "blown out" in any traditional sense.
- Phass RE50 amplifier
Made in japan
hi end non feedback amplifier
RE 50 Stereo amplifier
Out power:50W x 2 (1KHz / 10ohms)
Input sensitivity:0.22V
Input impedance:10K ohms
Load Impedance:4-8-16 ohms
Idling Current:
Idling time (On, No signal) 3A
Waiting time (Remote Off) 2mA
W280 x H74 x D329mm (without terminals)
RE50 is the unique amplifier which functions as the constant current driving amplifier. RE 50 uses Mos-Fets instead of semiconductors used in the circuit of RE 2 & 20 in the standard type power supply stage, which draws a clear line between this type and S.E.P.P circuit layout amplifiers that are mainstream today.
RE 50 has a exceptional ability to continue to put the power into speakers under the difficult situation that the speaker impedance is increasing. While S.E.P.P. amplifiers can not put the power constantly to speakers.
RE 50 simply shows its extraordinary musicality and surprising differences on the combination of the difficult load speakers.
ada 1unit @9jt
hubungin: 0819 088 6 9999
mau ganti mainan baru![]()
