WTS : Power Monoblock JL Audio 1000.1 Mulus - SOLD !!!
Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
  • Short URL:  http://modifika.si/175870
    Jakarta Selatan
    4 Hrs 15 Mins 25 Secs
    Sesuai judul, mau lepas power monoblock JL Audio 1000.1. Barang mulus abis. Power kelas D, tapi serasa kelas AB.
    Barang ada di NeuSounds - MGK Lantai 6.
    Descriptions:
    1 pair of Differential-Balanced Inputs
    Fully variable on-board crossover: (40Hz - 200Hz), selectable-slope LP (12 or 24 dB per octave)
    2-channel Preamp Outputs: independent active filter, parallel with amp filter or full-range
    Bass EQ that is parametric with variable bass boost up to 15dB and you can use a Remote Bass Control (optional RBC-1)
    Fully variable Infrasonic Filter: 24dB/octave from 15-60Hz
    Output Polarity Reversal switch allows instant output polarity reversal
    Dual mono speaker output connections that accepts up to 8 gauge wire
    12 volt and Ground connections accept 4 gauge wire or 2 gauge or 1/0 gauge
    Specifications:
    Rated Power: 1000 watts RMS at 1.5 ohm - 4 ohms (at 11V-14.5V)
    THD at RMS Power: <0.05% @ 4 ohm
    S/N Ratio: >95dB below rated power
    Frequency Response: 5Hz - 500 Hz
    Damping Factor: >500 at 4 ohms /50Hz
    Input Range switchable from 200mV-2V RMS
    to 800mV-8V RMS
    Dimensions: 19.7"L x 9.25"W x 2.36"H
    Amplifier Details Specifications
    Amplifier Class D
    Number of Channels 1 - Mono
    RMS Power (4 ohms) 1000 watts x 1 channel
    RMS Power (2 ohms) 1000 watts x 1 channel
    RMS Power (1 ohm) (at 1.5 ohms) 1000 watts x 1 channel
    Bridged RMS Power N/A
    Total RMS Power Output 1000 watts
    Peak Power Output N/A
    Minimum Impedance Unbridged 1.5 ohms
    Minimum Impedance Bridged N/A
    THD at Rated RMS Power 0.05%
    Speaker Level Inputs No
    Preamp Outputs 1 pair
    Built-in Crossover Low-pass (LP)
    High-pass (HP)
    High-Pass Crossover Frequency 40 - 200 Hz
    Low-Pass Crossover Frequency 40 - 200 Hz
    Subsonic Filter N/A
    Signal-to-Noise Ratio 95 dB
    Channel Separation N/A
    Bass Boost 0 - 15 dB
    Bass/Gain Remote Optional (Accessory required and sold separately)
    JL Audio RBC-1
    Fan Cooled No
    Fuse Rating 100AA x 1
    Kalau yang butuh manual-nya : hxxp://mobile.jlaudio.com/pdfs/Slash_amps/1000_1_MAN.pdf
    Harga : SOLD
    SMS only : 08567 0 08567
    Waaaaw.... barang keyeen.
    mau maen 4ohm kek atau 1ohm kek teteeep 1000Watt. Bentaran juga ilank niy power. :lol:
    Jakarta Selatan
    Sebelomnya, gw jual JL 1000.1 - ilang dalam 3 hari ... He he he ...
    Makashi udah bantu up negh ...
    Quote Originally Posted by PondokIndah View Post
    Yg ini pasti ilank dalam waktu singkat juga kok. Barang idaman gitu lhooww.... :lol: Hehehehehe...
    BTW, byk amit boss JL 1000.1 -nya?
    Jakarta Selatan
    Cuamn punya 2 biji ... Ini yang terakhir, Bos ...
    Jakarta Selatan
    Sundul lagi ke atas ... :smt026
    1 Day 9 Hrs 19 Mins 31 Secs
    pm super nettnya gan...
    Jakarta Selatan
    Sundul ke atas, sms only ke nomer di atas ... :smt070
    Jakarta Selatan
    Sundul ke atas ... Minggu malam ... :smt109
    Jakarta Pusat
    1 Wk 1 Day 23 Hrs 37 Mins 1 Sec
    berapa duit neh om? pm yah ^^
  1. WTS> power monoblock JL.1000 + sub aliante
    By mybiem in forum Power Amplifier
    Last Post: 28th November 2013, 17:43
  2. WTB Monoblock JL Audio 1000.1
    By razor_91 in forum Power Amplifier
    Last Post: 27th August 2012, 18:42
  3. power monoblock u-s-a amp ax-1000 mantap
    By carloramses in forum Power Amplifier
    Last Post: 16th April 2012, 23:00
  4. WTS: POWER MONOBLOCK ADX 1000 WATT
    By Mr.D1 in forum Power Amplifier
    Last Post: 21st December 2011, 16:01
  5. WTS : 2nd power monoblock audioquarts da-1000
    By sicap in forum Power Amplifier
    Last Post: 15th December 2011, 06:04
