Jual santai.. Toyota Crown 2.0 SS
Results 1 to 10 of 28
  • Short URL:  http://modifika.si/173947
    14 Hrs 25 Mins 23 Secs
    Gan mau jual santai ni..khusus penggemar yang paham banget kenyamanan..
    Sedan bongsor dari toyota..
    Toyota Crown Super Saloon 2.0i th92
    Info nya:
    - Mesin Standart (lulus uji emisi CO 1%)
    - Ban baru 1bln (4pc)
    - Interior original
    - Ruang mesin full baut L stainless..
    - Deck plastik bawah mesin masih lengkap & original
    - Knalpot original dr th92
    - Kaca film V kool
    - Alarm ProTech
    - TV skeleton 2din touch screen
    - Dashboard mulus & berfungsi normal senormal2nya..
    - Antena radio otomatis berfungsi normal & original
    - Velg original Toyota Crown Royal Saloon lengkap dengan dop2nya..
    - Konsumsi BBM dalam kota 1:7,5 luar kota 1:10
    - Full anti karat (gak ada karat/keropok sama sekali)
    - AC baru service rutin (dingin kaya di frezer)
    - Coil catronic 50.000volt baru 1bln..
    baru ganti:
    - Ball Joint u/l RH/LH baru original
    - Tieroad end RH/LH baru original
    - Bearing roda depan RH/LH baru (merk timken)
    - Idle arm baru original
    - Pitman arm baru original
    - Shock Absorber F/R Kayaba import (silver)
    - Bushing arm depan belakang u/l RH/LH baru original
    - Engine mounting semua baru original
    - Brake pad depan belakang baru original
    - Karet + piston rem depan belakang baru original
    - Kopel + gantungan tengah asli (sudah di balance)
    - Timing belt
    - Radiator
    - Kopling set
    - Kabel busi baru original
    - Shock kap mesin baru original
    Monggo diliat penampakannya..
    Minat??cukup siapin aja dana 60jt buat nebus si putih..
    call Me..08161925908
    Trims..no pol mau dipakai lagi........
  2. Hokinusa
    up..
    up..up..
    up..up..up..
    up..up..up..up..
    up..up..up..up..up..
    up..up..up..
    up..up..up..
    up..up..up..
    up..up..up..
    up..up..up..
    up..up..up..
    up..up..up..
    2 Wks 4 Days 7 Hrs 56 Mins 59 Secs
    Bantu up bos....
    1 Mth 2 Wks 5 Days 6 Hrs 33 Mins 33 Secs
    super nett berapa bos?
    no pol mau dipakai lagi jadi gimana bos? ane pastinya dapet nopol apa aja ga masalah.
    1 Day 5 Hrs 56 Mins 36 Secs
    30 jt ane bungkus bro
    Quote Originally Posted by usepsyaipudin View Post
    hahaha.,bcanda aja si boss...
    up..up..up..
Mega Glodok Kemayoran MBtech
  1. Replies: 0
    Last Post: 2nd October 2012, 13:56
  2. Replies: 0
    Last Post: 23rd May 2012, 08:14
  3. Replies: 41
    Last Post: 14th July 2011, 08:53
  4. JUAL TOYOTA CROWN 95 MANUAL 2000CC
    By randukuning in forum Merk Lainnya
    Last Post: 8th June 2010, 18:21
