4A-GE 20v PARTS NUMBER
  • Short URL:  http://modifika.si/17384
    JOGJA
    1 Day 21 Hrs 10 Mins 23 Secs
    Buat yg punya dan akan punya semoga berguna. :smt003
    20 VALVE (20v) 4AGE PART NUMBERS
    For Sale, Working 20v manual STARTER, tested at parts store, $53 shipped.
    Part Name Part Number Cross Reference
    Timing Belt 13568-19035 Gates T081, Goodyear 40081, Beck Arnley 0260254
    Timing Belt 13568-19185
    Distributor Cap 19101-16010
    Distributor 19100-16270
    Distributor O ring All 4A
    Igniter 89621-12050 SW20
    Ignition Coil 90919-02197 3SFE, 2JZGE
    Ignition Rotor 19102-74040 Beck Arnley 1737967, Kem W2052, Wells JA995
    Spark Plugs 90919-01178 or 01179 PK20R11 or BKR6EP11, Nipondenso 3128, NGK 2978
    Spark Plug Wires 90919-15207, 90919-15206, 90919-15205, 90919-15204 Magnecor
    Coil Wire 90919-13418
    Spark Plug 5 Wire Set 90919-21520
    Spark Plug Valve Cover 11212-16060
    Air Filter 17801-15070 4AFE or 7AFE
    Oil Filter 90915-10002 1989 Supra fits
    Oil Filler Cap 12180-46010 Supra 2JZ, Stant 10113
    Outer CV Boots 04438-12260 Repco 200-037
    Inner CV Boots 04438-12420 Repco 100-051
    Head Gasket 11115-16111 TRD, Toda
    Engine Gasket Kit Valve Grind 04112-16210
    Engine Gasket Kit Valve Grind 04112-16330
    Camshaft Intake Seal 90311-40016
    VVT camshaft valve 15330-16010
    Intake Valve Guide Bush 11122-16030 std, 11122-16040 sub, 11123-16030 o/s 0.05
    Exhaust Valve Guide Bush 11126-16010, 11127-16010 o/s 0.05
    Intake Valve Seat 11132-16030 o/s 0.03, 11147-16030 std
    Exhaust Valve Seat 11135-16030 std, 11136-16030 o/s 0.03
    Valve Stem Oil Sear or O Ring Exhaust 90913-02092 Echo, Prius
    Valve Stem Oil Sear or O Ring Intake 90913-02093 Echo, Prius
    Valve Adjusting Shim (Lifter Valve) 13751-16020
    Valve Cover Gasket 11213-16020, 11213-16021 sub
    Cylinder Head Cover Nut, Washer 90176-08047, 90210-09016
    Rear Main Seal Felpro BS40409, Beck Arnley 052-3258, Corteco 17199
    PCV Valve 12204-11050 Standard V330, Napa 2-9405
    PCV Valve Grommet 90480-18001 HELP 491036
    Catalytic Converter Gasket FELPRO 23591
    Spark Plug Tube Gasket 11193-16010
    Brake Booster 44610-1A420
    Brake Booster 44610-1A430
    Idle Speed Control Valve 22270-16030
    Fuel Pressure Regulator 23280-16140
    automatic Starter 28100-16170 4AFE auto starter fits
    automatic Starter 28100-16140
    Alternator Belt 99365-80840
    Alternator 27060-16330 4AFE alternator fits
    Alternator 27060-16360
    Air Flow Meter 22250-16110
    MAP Sensor 89420-12070
    Intake Cam Sprocket 13050-16010
    Exhaust Cam Sprocket 13050-16040
    VVT Cam Valve 15330-16020 blacktop
    Engine Bay Wire Harness 82111-1E220 (91-94), IE771 (93-94)
    Thermostat 90916-03090 All 4A
    Accessory Belt AC & PS 99365-21060
    Water Pump 16100-19245
    Water Pump O Ring all 4A
    Water Pump Gasket 16124-16040
    AC Compressor same as 7AFE?
    Power Steering Pump 04454-12010
    PS Belt Adjusting Bracket 16381-16070
    Idler Pulley 13505-16021
    Idler Pulley 13505-16030
    Spring Tensioner for Idler 90507-19003
    Bolt Flange for Idler 90105-10334 4AFE, 7AFE, blacktop
    Pin for Idler Spring Tensioner 90249-06006 4AFE, 7AFE, blacktop
    Coolant Temperature Sensor 89422-35010 WELLS SU4007, BECK ARNLEY 158-0421
    Oil Pressure Switch (with gauge) 83520-35030 NIEHOFF OPT24821, BECK ARNLEY 2011130
    Blacktop ECU 89661-1A360 95+
    black = blacktop only silver = silvertop only blue = both
    Jkt
    3 Mths 2 Wks 1 Day 3 Hrs 35 Mins 46 Secs
    nice info hehe
    Banten
    very very nice info
Venom 300x250 MBtech
  1. 2NDGARAGE WTS:INTERIOR PARTS MERCY/dan bbrp parts Japanese cars 2nd imported
    By 2ndGarage in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 1st October 2012, 10:16
  2. Replies: 5
    Last Post: 23rd August 2011, 19:09
  3. ask number
    By ssracing in forum Delapan Satu
    Last Post: 8th October 2009, 21:36
  4. FS: TURBO PARTS, ENGINE PARTS, BRAKES For 7th Gen Civic (banyak barang)
    By guyverias in forum Jual Beli Mesin Lainnya
    Last Post: 30th August 2009, 15:37
