[WTS]DVD Touchscreen JVC KW AVX-810 EXAD
Results 1 to 10 of 101
  • Short URL:  http://modifika.si/173393
    1 Day 20 Hrs 6 Mins 48 Secs
    mo jual tv/dvd touch screen avx 810 mint condition,mulus,segel,kondisi normal..gak ada dos book dah dicari gak ketemu ntar diganti dus jvc yang lain
    spec:
    If you have been thinking of upgrading your sound system but havenít had enough time to research all of the options that are out there, you can stop looking because the JVC KW-AVX810 is just the right head unit for you! It is a Double DIN In-Dash receiver with DVD, DivX, JPEG, CD and MP3 Playback and a full 7" touchscreen monitor. You will never have to worry about converting your DVDís or DivX files again. You can enjoy music and movies from a variety of different options and still have enough space for more. Not only do you have a great selection of playback features to choose from, the 7-band parametric equalizer will enhance all your sounds with amazing customization.
    This car stereo offers numerous expandability options for adding different formats of music. The list includes a front SD Card slot to view pictures and a rear USB Input to play music. Did I mention you can control everything with the touchscreen? No more fumbling around with a remote control with buttons that are too small to see while driving. Not only are there multiple options for playback, there are also ways to expand your head unit to get the most out of it. Bluetooth, HD, Sirius and XM, and iPod are just a few of the possibilities that can be added to the JVC KW-AVX810. The list doesnít end there. You can even add a steering wheel remote control adapter to the unit and control all your favorite features with the buttons on your steering wheel.
    The 7Ē TFT Active Matrix, 16:9 Widescreen monitor has adjustable viewing angles and is very responsive when switching tracks, playlists and radio stations. The wallpaper colors on the screen can even be changed to 7 different colors. The LCD screen serves as a video monitor, system information display and control panel for your music and movies. If the screen needs to be adjusted, you can use the brightness, contrast, color and tint to help you achieve your goal for an optimum picture. The touchscreen is unique because instead of pressing the arrows to move to the next selection you can slide your finger from the left to the right to change tracks. Itís not every day that you see a double DIN receiver that has proximity sensors. The proximity sensors allow the screen to be dimmed when not in use, but when your hand approaches the screen the menu will then display. If the unit has been idle for an extended period of time, the unit will hide the menu unless a video or other media is being played. And donít be nervous about leaving your new head unit in your vehicle, the faceplate actually detaches so you can take it with you wherever you go with the included case.
    General Features:
    * In-dash DVD, DivX, CD, MP3 Multimedia Receiver with USB, SD Card Slot, and Remote
    * Proximity sensor: a feature that allows menus to be dimmed or hide when your hand is not near the unit
    * iPod USB direct connectivity via your standard iPod-to-USB connection cable allows you to charge, control, and playback your iPod through the receiver and stereo system
    * Motorized, detachable face
    * 7" Wide touchscreen display
    * Four background wallpapers
    * Wireless remote control included
    * Switchable blue and red button lighting
    * CEA-2006 compliant amplifier
    * Power Output:
    o Peak: 50 watts x 4 channels
    o RMS: 20 watts x 4 channels
    * MP3 ID3 Tag Display (Title/Artist/Album)
    * Authorized Internet Dealer
    * 1-year Manufacturer's Warranty
    Playback and Audio Features:
    * Playback of DVD, DivX, CD, CD-R, CD-RW, JPEG, MPEG 1, MPEG 2, AAC, MP3, and WMA
    * HS-IVi tuner with 18FM/6AM presets
    * 192kHz / 24-Bit D/A audio converter
    * 108MHz / 12-Bit D/A video converter
    * 7-Band parametric equalizer with 8 EQ presets
    * Dolby Digital sound capable
    Expandability Options:
    * 2 Sets of 5V preamp outputs (front and rear) and 1 5V Preamp mono-subwoofer output
    * Gold plated preamp and video outputs
    * Gold plated inputs
    * SIRIUS or XM Satellite Radio Ready: A subscription is required for service as well as either the JVC SIRIUS Satellite Radio Package or JVC XM Radio Package
    * HD Radio Ready: JVC KT-HD300 HD Radio add-on module is required and sold separately
    * Bluetooth Ready: JVC KS-BTA200 module is required and sold separately
    * iPod/iPhone Ready: USB-to-iPod cable will work with most iPods. The following adapters may be required for select iPods or if you want video playback:
    o Audio/Video Playback: JVC KS-U30
    o Audio Playback for Select iPods: JVC KS-PD100 (View the JVC compatibility list for details)
    * Steering Wheel Control Ready: PAC SWI-JACKv1 required and sold separately
    * CD Changer controls (compatible with the JVC CH-X1500 CD/MP3 changer)
    * Front-panel auxiliary input: SD Card
    * Rear auxiliary input: USB and RCA Audio/Video Inputs
    * Steering wheel remote ready
    * Rear view camera input
    pic:
    price : 4jt/nego
    contact 08123171317 / COD Surabaya
  2. Ysbjaya88
    up..up..
    up..up..up..
    up..up..up..up..
    up..
    up..up..
    20 Hrs 52 Mins 42 Secs
    2 jt bungkus daaaaaa
    yang Dulunya Hutan Kal_ Tim
    15 Hrs 25 Mins 14 Secs
    Quote Originally Posted by no_user View Post
    ________ :mad::mad::mad:
    up aja bro..........................
    Angry
    masih jauh gan.....
    Quote Originally Posted by jues View Post
    thanks gan sundulan nya....
    6 Hrs 39 Mins 27 Secs
    uuy
    nett brp tp neh gsds usb y hehe n gsds time correction y pak?
    Quote Originally Posted by BELEDUG View Post
    cek pm gan....
    48 Mins 35 Secs
    nett nya berapa? ini second kan?
  1. Wts : Jvc exad kd-avx1
    By tesna in forum Head Unit & Processor
    Last Post: 18th October 2012, 10:15
  2. fs jvc kw-avx 805 exad
    By aidil_syawal88 in forum Head Unit & Processor
    Last Post: 5th August 2012, 19:03
  3. [WTS] JVC KD-LHX551 EXAD (2ND)
    By dimsaudio in forum Head Unit & Processor
    Last Post: 23rd February 2012, 05:51
  4. WTS HU DVD JVC EXAD solddddd
    Last Post: 9th September 2009, 15:23
  5. JVC EXAD AVX 1
    By mrolza in forum Diskusi Head Unit & Processor
    Last Post: 24th March 2008, 17:58
