#PORTFOLIO# BOOSTED Honda Civic ES D17 2001 407HP @1.3 Bar
Results 1 to 10 of 82
  • Short URL:  http://modifika.si/173219
    BOOSTED HONDA CIVIC ES D17A 2001
    Engine Spec :
    - Honda D17A Engine Block
    - WISECO Piston Kit Bore 75,50mm & Comp 8,8:1
    - EAGLE Connecting Rods
    - ACL Main Bearings - Race Series
    - ACL Rod Bearings - Duraglide
    - SUPERTECH Engine Block Guard
    - COMECTIC MLS Engine Head Gasket Bore 76mm & .030 inch Thick
    - ARP Head Stud Kit
    - SUPERTECH Valve Seals Viton & Polyacrylic
    - CROWER Camshaft Stage 2 Turbo
    - CROWER Valve Springs
    - GARRETT GT2860RS Ball Bearing Turbo 0.48 A/R & T3 Flange (Custom Order)
    - DEI Titanium Turbo Blanket
    - DEI Titanium Exhaust Wrap
    - CUSTOM Stainless Turbo Manifold (Tubular Style)
    - TiAL MV-S 38mm External Wastegate 0.8 Bar Spring
    - TiAL Type-Q Blow off Valve
    - CUSTOM Stainless Intake Manifold
    - SUPER90 Honda K-Series Throttle Body 70mm (Modified)
    - JR PROJECT Aluminum Intercooler 510x240x70mm - Inlet 2,5inch
    - CUSTOM Stainless Intercooler Piping Kit
    - JR PROJECT Silicone Hoses
    - JR PROJECT Oil Cooler Kit with Relocation Kit
    - MIZU Aluminum Race Radiator (2 Row)
    - SKUNK2 RACING Radiator Cap 1.3 Bar
    - SKUNK2 RACING Billet Oil Cap Limited Edition - Black Series
    - JR PROJECT Silicone Radiator Hose 3 Layer
    - HKS Silicone Vacuum Hose 4mm
    - HKS Silicone Vacuum Hose 6mm
    - CUSCO Oil Catch Tank
    - INGALLS Stiffy Engine Damper
    - AEM Tru-Time Adjustable Cam Gear
    - GATES RACING Timing Belt
    - AEM Lightweight Pulley Alternator Motor & Power Steering
    - NGK Iriway 8
    - TOMEI Fuel Pressure Regulator
    - WALBRO Fuel Pump 255 LPH
    - CUSTOM Alumunium Extra Injector Adapter Block
    - RC ENGINEERING Injector 680cc Extra (2pcs)
    - CUSTOM Aluminum Fuel Block 4 Port
    - ACT Heavy Duty with 6-Puck Race Disc
    - HKS Super Mega Flow Air Filter 200/100mm - Red Plate
    - APEXi NOIR Turbo Muffler Inlet 3,00 inch (Matte Black)
    - VIBRANT UltraQuite Center Resonator 3,00 inch
    - DC SPORTS Carbon Steel (CS-2) Front Strutbar 2 Points
    - ULTRA RACING Fender Bar 3 Points
    - ULTRA RACING Front Lower Bar 4 Points
    - ULTRA RACING Rear Lower Bar 4 Points
    - ULTRA RACING Side Lower Bar 6 Points
    - ULTRA RACING Rear Sway/Anti Roll Bar 19mm
    - STIFF RING Rigid Collar - Front Arm
    - KSPORT Coilover Kit Suspension - Street
    - KSPORT Rear Lower Control Arm
    - KSPORT Front Big Brake Kit (Street Series) 4 Pot Black Caliper & 286mm Slotted Rotor
    - KSPORT Rear Oversize Disc Rotor 286mm Slotted
    - PRO-RS Stainless Brake Line Hose Kit
    - FIDANZA Short Shifter
    - SPARCO Champion Steering Wheel
    - SPARCO Settana Pedal
    - RECARO SR3 Seat
    - NRG 4 Point Safety Belt
    - STRI DSD-SLM II Boost Meter 60mm Gauge
    - STRI DSD-SLM II Exhaust Gas Temperature Meter 60mm Gauge
    - STRI DSD-SLM II Oil Pressure Meter 60mm Gauge
    - STRI Turbo Timer
    - PIVOT Rev Lamp-Z Sequential Shift Lamp
    - AEM Water Methanol Injection
    - HKS Circle Earth Ground Wire
    - PIVOT Ignition Earth
    - PIVOT Mega Raizin Volt Stabilizer
    - APEX'i AVC-R Electrical Boost Controller
    - DASTEK UNICHIP Type Q+
    undershot of Ultra Racing Chassis Bar
    Engine Bay
    Exterior Look
    Dyno Result @RS Tuning Dastek Dyno
    Boost 1,3 Bar
    BBM : Pertamax Plus RON95
    Power : 399,1 HP @7000rpm
    Torque : 431,9 Nm @6500rpm
    BBM : Bensol
    Power : 406,6 HP @7000rpm
    Torque : 433,6 Nm @6500rpm
    Dyno Run Graph
    Dyno Entry - Power
    Dyno Report - Power
    Dyno Report - Torque
    Drag Race 402m @Sentul June 2012
    in BOOST we trust..!
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    Jakarte
    2 Wks 4 Days 6 Hrs 51 Mins 18 Secs
    MANTAPPP.....!!!!
    Quote Originally Posted by si_cuplis View Post
    MANTAPPP.....!!!!
    ferio item giniin juga yu har..
    CP : Coki Siboro
    Phone: 08179845168 - Klender Jakarta
    4 Days 23 Hrs 46 Mins 8 Secs
    Kayak-nya kenal nih...
    (kenal sama engine block-nya)....
    wakakakakakakakakak
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Jakarte
    Quote Originally Posted by coki.de auto View Post
    hayuukkk.....bayarnya di cicil yak....
    Quote Originally Posted by Hydra Performance View Post
    wakakakakakakakakak
    wuakakakkaakakak
    jadi malu nih kakak...
    CP : Coki Siboro
    buat elo sih atur aja lah har..
    CP : Coki Siboro
    PUSING PALA BAPA'
    2 Wks 6 Days 17 Hrs 42 Mins 32 Secs
    widih dipamerin jg akhirnya...da kelar bang?
    Suzii Baleno sangat amat setandar bang ---> KLIK
    "Anda Puas, Kami Lemas..."
    Quote Originally Posted by Daniel Sirait View Post
    blm nih, masih kerjain turbo manifold..
    ya buat lucu2an aja niel
    CP : Coki Siboro
    Bekation...Jtbng
    1 Hr 29 Mins 19 Secs
    ayo bang coki....maskot nya de auto dijadiin....juni bs turun deh....hhe
