ΩΩΩΩ<WTS> Paket hemat DUAL SUB EXPLODE 10" with POWER AMP" ΩΩΩΩ
Results 1 to 10 of 57
  • Short URL:  http://modifika.si/172276
    1 Wk 2 Days 22 Hrs 3 Mins 51 Secs
    Permisi om modcomers,
    1. Sony XS-L101P5 10" Car Subwoofer ......SOLD
    2. Kenwood KDC-CMP21V 10 Disc VCD/MP3/WMA/CD Changer ......Rp. 800k
    Kenwood KDC-CMP21V
    Kondisi Play All CD/MP3 normal, changer and optic juga gak masalah
    Specification :
    Disc
    Laser Diode GaAlAs (λ = 795nm)
    Digital Filter (D/A) 8 Times Over Sampling
    Spindle Speed 500 - 200 (CLV)
    Wow & Flutter Below Measurable Limit
    Frequency Response 5 - 20kHz (1dB)
    Total Harmonic Distortion 0.007% (1kHz)
    Signal to Noise Ratio 95dB
    Dynamic Range 95dB
    Channel Separation 85dB
    MP3 Decode Compliant with MPEG - 1.0/2.0
    Audio Layer - 3
    WMA Decode Compliant with WINDOWS MEDIA AUDIO
    VCD
    Video CD Format Version 1.1
    Video Output Color System NTSC/PAL
    Video Output Level 1Vp-p/75Ω
    General
    Operating Voltage 14.4V (11V - 16V)
    Current Consumption 0.65A at Rated Power
    Japan Capacitor HI-Grade for All CAR or HOME amplifier .......
    10,000uF/63V ESMH630VSN103MR50S..........Rp.50,000
    SPECIFICATIONS
    Items Characteristics
    Part No. ESMH630VSN103MR50S
    Series SMH
    Category Temperature Range -40 to 85 (oC)
    Rated Voltage Range 63 (Vdc)
    Capacitance Range 10000 (㎌)
    Capacitance Torelance -20 to 20%(M) (at 20oC, 120Hz)
    Dimensions (ΦD) 30 (mm)
    Dimensions (L) 50 (mm)
    Rated Ripple Current / Temp / Hertz 5490 (mArms) / 85 (oC) / 120 (Hz)
    Leakage Current 3000㎂ max. (at 20oC, 5minutes)
    Dissipation Facter (tanδ) 0.15 max. (at 20oC, 120Hz)
    Endurance : Temp/Time/Load 85 (oC) / 2000 (hrs) / DC volt & rated ripple current
    Shelf Life : Temp/Time 85 (oC) / 1000 (hrs)
    4700uF/50V ELXG500VSN472MR35S..........Rp. 35,000
    SPECIFICATIONS
    Part No. ELXG500VSN472MR35S
    Series LXG
    Category Temperature Range -40 to 105 (oC)
    Rated Voltage Range 50 (Vdc)
    Capacitance Range 4700 (㎌)
    Dimensions (L) 35 (mm)
    Rated Ripple Current / Temp / Hertz 2110 (mArms) / 105 (oC) / 120 (Hz)
    Impedance / Temp / Hertz 40 (Ωmax) / 20 (oC) / 30k (Hz)
    Dissipation Facter (tanδ) 0.20 max. (at 20oC, 120Hz)
    Endurance : Temp/Time/Load 105 (oC) / 5000 (hrs) / DC volt & rated ripple current
    Shelf Life : Temp/Time 105 (oC) / 500 (hrs)
    2200uF/50V YXA series..........Rp. 25,000
    SPECIFICATIONS
    Series YXA
    Capacitance Range 2200 (㎌)
    Datasheet :
    http://www.rubycon.co.jp/en/catalog/e_pdfs/aluminum/e_YXA.pdf
    PM / SMS ke 08571-70-30-80-5]
    16 Hrs 28 Mins 8 Secs
    up............
    Monggo gan........upupupupupupupup
    Monggo gan ditawar <ketengan boleh aja........>upupupupupupupup
    Monggo gan........
    Power aja 600rb....
    upupupupupupupup
    SEARCHautofamily
    1 Day 9 Hrs 21 Mins 40 Secs
    net sepaket..
    pm ya..
    22 Hrs 2 Mins 5 Secs
    naik!!!!!!!!!!!!
    Monggo gan yg butuh GPS MIOnya ...udah Unlock MIO Pocket all Feature sudah fungsi
    http://www.kaskus.us/showthread.php?t=4110575
    upupupupupupupup
    upupupupupupupup
  1. SALE PAKET HEMAT VELG 17" + BAN, SIAPA CEPAT DIA DAPAT.
    By warnawarniban in forum Ragam Ukuran
    Last Post: 22nd July 2011, 10:23
  2. PAKET HEMAT INTERIOR! JAMIN MURAH DAN HEMAT!
    By Honda in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 21st March 2009, 18:19
