ask dominations
Results 1 to 10 of 17
Thread: ask dominations
  • Short URL:  http://modifika.si/170866
    bandung
    1 Wk 5 Days 3 Hrs 43 Mins 4 Secs
    ask dominations
    bos tweeter dominations furuta harga brp?
    trus midbass yg cocok buat tweeter tsb apa?and harganya?
    thank you
  2. Jaya Bet
    1 Hr 24 Secs
    Quote Originally Posted by nney View Post
    thank you
    Domination MId Bass D53 neo 1,8 jt
    Kemudian utk Tweeternya Domination F50 1,1 jt boss thx
    6 Days 20 Hrs 44 Mins 20 Secs
    Bos bukannya dominaton F50 speaker full range ya bos??kok tweeter??
    1 Hr 24 Secs
    Quote Originally Posted by zeph View Post
    iya betul full range boss...tetapi bisa kita pakai sbg fungsi tweeter juga boss...
    specially made for people who seeking a "3 way" sound in compact "2 way design". Can be crossed as low as 500 hz/6db high pass.
    F50 Spec
    Freq Resonance 127 hz
    Freq Response Fo-20 khz
    sensitivity 83db/w/m
    impedance 4 ohm
    DC Resistance 3,6 ohm
    Power RMS 15 Watts
    Power Max 30 watts
    X max 1,75mm
    Flux density 9200 gauss
    Vas 425 um
    Sd 2,12 mh
    Bl 3,113 Tm
    Qms 1,75
    Qes 0,72
    Qts 0,51
    3 Wks 6 Days 1 Hr 57 Mins 43 Secs
    Bos mau nanya speknya d53 neo donk??tq..
    1 Mth 5 Days 20 Hrs 7 Mins 59 Secs
    klo F50 Digabung ama midbass CFS3 gimana soalnya gk mau pake 3way pke FUll range lebih enak!...hehe
    1 Hr 24 Secs
    Quote Originally Posted by Steve65 View Post
    betul boss gitu racikan menunya.........:smt050
    Depok ...
    7 Hrs 51 Mins 29 Secs
    Quote Originally Posted by Audioworkshop View Post
    F50 Spec
    impedance 4 ohm
    Power RMS 15 Watts
    Power Max 30 watts
    X max 1,75mm
    Vas 425 um
    Sd 2,12 mh
    Bl 3,113 Tm
    Qms 1,75
    Qes 0,72
    Qts 0,51
    boss nanya ya masih newbie nih, beberapa installer sering mengatakan speaker bagus karena sensitivity-nya 92-95db itu gimana bos? kalau ini speknya kok hanya 83db ya? :confused:
    1 Hr 24 Secs
    Quote Originally Posted by i0n3i0n3 View Post
    begini,
    untuk midbass, kita harus cari antara 86-89, sedangkan 92 kebanyakan speaker standar mobil (high efficiency tetapi mudah clipping/sember, ada juga yang 92db tetapi speaker proffesional (6in hanya midrange saja, no bass)
    nah untuk midrange-tweeter 83-85 sudah cukup, karena memang midrange akan dibuat lebih rendah 3-6dB daripada midbass. sebagai acuan saja,
    ambang dengar manusia (kita berbicara tiap hari) 80-90dB
    kalau 1 watt 83dB
    2 watt 86dB
    4 watt 89dB
    8 watt 92dB
    16watt 95dB (rata2 power tape 15watt, hasil suara sudah 95dB di midrange, ini sudah kenceng banget
    32watt 98dB
    64watt 101dB (batas maksimal power F50 kisaran 60watt) 101dB di midrange artinya bass dan midbassnya
    sudah 108-115dB, ini sudah kencang sekali untuk versi dengar harian
    harap diingat angka diatas dimaksudkan untuk continuous loudness (jadi sudah pasti bisa dan aman dimainkan 95dB), kalau cuma impuls atau sesaat saja tentu bisa lebih kencang lagi.
    Dan seharusnya speaker didengar dulu pak jangan terlalu memusingkan masalah dB, nanti malah keblinger.... idealnya speaker harus high spl (sensitivitas tinggi), frekuensi response lebar, tetapi bassnya harus kencang, tidak mudah klipping.
    speaker pro, high sensitivity, high power, tetapi no bass untuk ukuran yang sama dengan speaker mobil 6in di mobil midbass 6 in di pro midrange
    speaker original mobil high sensitivity, low power, gampang sember, bass enteng
    speaker upgrader speperti dominations CFS4/3 kita buat bassnya kenceng, otomatis ada yang dikorbankan, yaitu sensitivity
    Depok ...
    Terima kasih atas tambahan ilmunya bos ....
Venom 300x250 MBtech
  1. WTS : MIDRANGE DOMINATIONS D53
    By aik.frezh in forum Speaker - SubWoofer
    Last Post: 23rd September 2012, 09:48
  2. WTS : Power Dominations
    By frezh in forum Power Amplifier
    Last Post: 27th January 2012, 17:53
  3. WTS Mid Range DOMINATIONS D53
    By carbonic15 in forum Speaker - SubWoofer
    Last Post: 16th September 2010, 00:15
  4. Dominations 8"
    By Flanker in forum Diskusi Power Amplifier
    Last Post: 8th May 2008, 13:59
  5. Mid range dominations
    By rOeLez in forum Diskusi Speaker
    Last Post: 8th July 2007, 08:27
