<WTS> ECLIPSE CD 3100 (Revised Price) Redefining just how advanced entry level can be
Results 1 to 8 of 8
  • Short URL:  http://modifika.si/170279
    9 Hrs 11 Mins 20 Secs
    Permisi Bos bos mod com, numpang jualan yah
    Eclipse CD 3100 beli dari baru des 2007,masih segel belum pernah service, lengkap dus, buku, remote, box front panel. optic masih ok, mobilnya cuma keluar pas weekend doang.
    Features
    MP3/WMA Playback: The CD3100 can play MP3 and WMA files recorded onto CD-R and CD-RW discs in ISO 9660 Level 1 and 2. Recommended bit rates are 64-320 kbps for MP3 and 48-320 kbps for WMA. Variable bit rates from 64 to 320 kbps for MP3 and 48 to 192 kbps for WMA can be used, however there may be a discrepancy in the time display. The receiver can recognize a total of 256 files, 191 folders, and 8 directory layers on a single disc. The receiver can show the names of albums and artists from and ID3 and WMA tags.
    CD Text: If a CD Text disc is inserted, the receiver will display the artist name, disc title, and track title information.
    Area Shot: Using the special Eclipse E-iSERV website, you can download turn-by-turn text directions to a destination using NAVTEQ map data for the U.S. and Canada. The directions are burned to a CD-R and imported into the CD3100. The Area Shot feature allows you to display the driving instructions to your destination on the receiver, you manually flip through the pages as you follow the route. Text information includes intersection street names and turn directions.
    Radio Band Switching: If you wish to take the receiver out of the country, the tuner frequencies and interval can be switched on any of four possible regions:
    * USA:
    o FM: 87.75-107.9 MHz (0.2 MHz step)
    o AM: 530-1710 kHz (10 kHz step)
    * Asia (includes Europe):
    o FM: 87.5-108.0 MHz (0.05 MHz step)
    o AM: 522-1629 kHz (9 kHz step)
    * Australia:
    o FM: 87.5-108.0 MHz (0.1 MHz step)
    o AM: 522-1710 kHz (9 kHz step)
    * Latin America:
    o FM: 87.75-107.9 MHz (0.1 MHz step)
    High-volt Preamp Outputs: The CD3100 features three sets of 5-volt, low-impedance (55Ω) preamp outputs, including a non-fading output for a subwoofer. The outputs are affected by the crossover settings (see below).
    Sound Adjustment Modes: The CD3100 is equipped with several sound adjustment features:
    * Parametric EQ: The 3 band parametric EQ allows more accurate tonal adjustment than typical bass and treble controls or a graphic equalizer:
    o Bass:
    + Q (Width of adjusted band): Wide, Midwide, Normal, or Narrow
    + Center frequency: 60Hz, 80Hz, 100Hz, or 120Hz
    o Middle:
    + Q: Normal or Wide
    + Center frequency: 700Hz (fixed)
    o Treble:
    + Q: Normal (fixed)
    + Center frequency: 7.5kHz, 10kHz, 12.5kHz, or 15kHz
    * Crossover: The crossover allows you to independently apply a low pass filter to the non-fading (subwoofer) outputs and a high pass filter to the front and rear outputs. The slope of both is 12 dB/octave.
    * Non-fader: The phase and output level of the non-fading (subwoofer) output can be adjusted.
    * Loudness: The loudness control may be turned on to emphasize low and high frequencies at low volume levels. When selected, the loudness contour provides a +10dB boost at 100Hz and a +6dB boost at 10kHz.
    Source Volume Controls (SVC): Because the level of each source can vary greatly, the Source Volume Controls allow you to raise or lower the volume of AM radio and CD audio compared to the FM radio signal. The volume differences can be set within a range of -10 to +20.
    Illumination: The front panel buttons are backlit in green and red; the large buttons and rotary knob are green and the presets, EQ, mode, and mute buttons are red. If the accessory power is on and the unit is turned off, most of the LED display turns off (the clock stays on) but the buttons and rotary knob stay backlit. When the unit is on and 12 volts is applied to the illumination wire the LED dims, but the button backlighting remains unchanged.
    Remote Control: The CD3100 is controlled by the supplied RMC105 remote control. With the remote you can access the following functions: Power, Mode, Volume Up/Dn, Source select (Disc/Tuner/Aux), Band select, Mute, Preset Channel Up/Dn, Disc Up/Dn, Track Up/Dn, and Tune/Seek Up/Dn.
    Steering Wheel Remote: Through the special E-iSERV website from Eclipse, you can download software that enables factory steering wheel remote operation of the CD3100. This software is burned to a CD-R and imported into the receiver. Two wires (brown/black and brown) in the supplied wiring harness need to be connected to factory wiring in order for steering wheel remote commands can operate. Note: Depending upon the vehicle's make and model, not all downloaded material may be compatible with steering wheel remote functions.
    Open price : Rp 1,150,000 Negotiable
    Biar sama sama enak COD aja yah, preferably daerah jakbar.
    Contact : 085716987682
    Thank you
    sip, gambarnya dah di post.
    up dulu hari ini
    uppppppppppp hari ini............
    up again.............
    up.......................
    up lagiiiiiii
Venom 300x250 GT Radial
  1. WTB (URGENT!!!!!!) CONNECTOR AUX FOR ECLIPSE 3100 (New or 2ND)
    By handy86 in forum Head Unit & Processor
    Last Post: 11th July 2012, 16:46
  2. WTS: ECLIPSE CD 3100 KOMPLIT MULUS SEGEL.....solddddddddd
    Last Post: 19th December 2009, 00:13
  3. HU entry level
    By hilma in forum Diskusi Head Unit & Processor
    Last Post: 29th November 2009, 00:09
  4. eclipse 3100 (wta : ext cable)
    By evo in forum Diskusi Head Unit & Processor
    Last Post: 28th February 2008, 22:09
  5. WTA: Monoblok entry level...
    By somay in forum Diskusi Power Amplifier
    Last Post: 13th December 2007, 01:37
