MSD MAIN DEALER IN INDONESIA
Page 1 of 26 12345 ... LastLast
Results 1 to 10 of 252
  • Short URL:  http://modifika.si/169769
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    Post MSD MAIN DEALER IN INDONESIA
    MSD PRODUCT NOW AVAILABLE
    NOW IN STOCK!!!
    MSD 6AL
    MSD DISTRIBUTOR CAP
    HONDA
    -D16A
    -B16A
    -B18C
    -H22
    COIL
    -SS BLASTER COIL
    ROTOR DISTRIBUTOR
    -D16A
    -B16A
    -B18C
    -H22
    SPEED'Z PERFORMANCE IS AUTHORIZED DEALER EXCLUSIVE IN INDONESIA,SINGAPORE AND MALAYSIA FOR SUPPLY MSD PART NUMBER IN BELOW JUST COMING THE STOCK:
    *MSD 34635 LONG BRASS CLIP FOR
    *MSD 31179 SUPERCONDUCTOR,6CYL MULTI ANGLE SOCKET HEII
    *MSD 8516 PRO BILLET DISTRIBUTOR 6 CYL AMC JEEP 232.258 4.0 LITER
    *MSD 8222 HIGH VIBRATION BLASTER COIL
    *MSD 34059 SUPER CONDUCTOR WIRE RED 300 BULK
    *MSD 34525 90 DEGREE DIDTRIBUTOR BOOTYS ,GRAY SILICONE,100 EACH
    *MSD 34565 STRAIGHT.GRAY.SILICONE ,100 EACH
    *MSD 84049 COIL WIRE .BLASTER COIL/SOCKET CAP
    *MSD 34615 90 DEGREE SPARK PLUGTERMINAL S.100EACH
    *MSD 34605 MULTI ANGLE SPSRTKS TERMINAL 100 EAH
    POPULAR STOCK MSD IN BELOW:
    *MSD 6425 6AL DIGITAL WITH REV CONTROL
    *MSD 6421 6AL-2 WITH 2 STEP LIMITER
    *MSD 7AL-3 PRO DRAG RACE IGNITION
    *MSD 6304 DISC CPC SIGNAL CONVERTER 4 CHANEL
    *MSD 6305 SC COIL DRIVE IGNITION FOR SC DISTRIBUTOR
    *MSD 8235 COIL BLASTER FOR 6305 OR CDI IGNITION
    *MSD 8864 DIST ADPTR CAB HONDA/ACURA OBD 2 TO OBD 1
    *MSD 8488 DISTRIBUTOR 96-01 HONDA 1.6/1.8L B DOHC VTEC
    *MSD 8910 TACH ADAPTOR
    *MSD 8910EIS TACH ADAPTOR
    *MSD 8920 TACH ADAPTOR
    *MSD 62112 MSD DIS-2 PLUS
    *MSD 62113 MSD DIS -2 PLUS HIGH OUTPUT
    *MSD 62152 MSD DIS-4 PLUS
    *MSD 62152 MSD DIS-4 PLUS HIGH OUTPUT
    *MSD 6520 DIGITAL 6-PLUS IGN.CONTROL MICROPROCESSOR
    *MSD 6302 DIS DUAL COIL IGNITOR 2 CHANEL
    *MSD 8207 MSD SS BLASTER COIL
    *MSD 8202 MSD COIL BLASTER 2 HIGH PERFORMANCE
    *MSD 5528 MSD COIL PACK STREET FIRE FORD 6 TOWER DIS 94-00
    *MSD 8241 MSD COIL FORD DIS COIL PACK 4 TOWER
    *MSD 8251 MSD HVC COIL WITH MSD 7 SERIES
    *MSD 8252 MSD HVC COIL WITH MSD 6 SERIES
    *MSD 8253 MSD HVC2 COIL WITH MSD 6 SERIES
    *MSD 84049 COIL WIRE BLASTER COIL/SOCKET CAP
    *MSD 8735 LAUNCH CONTROL MODULE SELECTOR
    *MSD 82903 MSD DISTRIBUTOR CAP AND ROTOR FOR HONDA D-SERIES ENGINE
    *MSD 82923 MSD DISITRIBUTOR CAP AND ROTOR FOR HONDA B-SERIES ENGINE
    *MSD 82933 MSD DISTRIBUTOR CAP AND ROTOR FOR HONDA B18C
    *MSD 82913 MSD DISTRIBUTOR CAP AND ROTOR FOR HONDA F-H SERIES ENGINE
    *MSD 8672 SELECTOR SWITCH 6.0-8.2K
    *MSD 8673 SELECTOR SWITCH 7.6-9.8K
    *MSD 8674 SELECTOR SWITCH 9.0-11.2K
    *MSD 8732 2 STEP LAUNCH CONTROL FOR 6425 IGNITION
    *MSD 8737 MODULE SELECTOR ,THREE STEP
    *MSD 8912 TACH ADAPTER DIS-2 N DIS-4 IGNITIONS
    *MSD 32319 WIRE SET FOR HONDA CIVIC 1.6 LITER
    *MSD 32359 WIRE SET FOR HONDA CIVIC 1.6 LITER VTEC
    *MSD 32369 WIRE SET FOR HONDA ACCORD 2.2 LITER
    *MSD 8239 COIL,MITSUBISHI,DODGE 96-ON
    *MSD 8883 HARNESS DIS-2 TO DODGE/MITSUBISHI COIL PACK
    *MSD 8843 PRO-CLAMP WIRE SEPARATORS
    *MSD 8841 PLUG WIRE SPACER KIT 16/SET
    *MSD 8842 PLUG WIRE SPACER KIT 16/SET WIRE SLEEVES
    *MSD 8812 SWITCH UNIVERSAL PUSH BUTTON ALT ACTION
    *MSD 34615 90 DEG SPARK PLUG TERMINALS
    *MSD 34515 90 DEG SPARK PLUG BOOT GRAY SILICONE
    *MSD 3510 CRIMP JAWS DEUTSCH CONNEECTOR
    *MSD 350051 PRO CRIMP TOOL RATCHET ACTION
    *MSD 4217 IGN 1CYL PROGRAMMABLE BATT POWERED
    *MSD 42181 YAMAHA YZ250 PROGRAMMABLE IGNITION
    *MSD 8232 COIL SINGLE TOWER CPC IGNITION
    *MSD 8204 COIL BLASTER MC MOTORCYCLE LARGE CASE
    *ASY30160 HARNESS DODGE/MITSUBISHI COIL PACK ASSY
    CHECK OUT THIS WEBSITE TO SEE ONLY SPEED'Z PERFORMANCE MAIN DEALER IN INDONESIA
    http://www.msdignition.com/page.aspx?id=6442451987
    Bandung, Indonesia
    26 Mins 29 Secs
    Msd 6AL ny brp bos?
    cipondoh-tangerang
    [QUOTE=D 1364;6192352]Msd 6AL ny brp bos?[/QUOTE
    stocknya lagi masuk bro
    APOLLO MOTOR
    1 Day 12 Hrs 51 Mins 4 Secs
    Brp bro 6al?
    cipondoh-tangerang
    Quote Originally Posted by invisible_boy View Post
    Brp bro 6al?
    syocknya kosong bro msd ada stocknya tinggal ss blaster coilnya nich ....
    shipment nya lagi masuk bro
    cipondoh-tangerang
    Talking
    up!!!!!!!!!
    4 Hrs 38 Mins 38 Secs
    Harga MSD blaster SS berapa bos? PM ya...
    cipondoh-tangerang
    Talking
    Quote Originally Posted by royalstd View Post
    800 ribu bro
    bos,boleh tanya buat upgrade performance estilo saya,,maklum msh newbie
    kalo pake MSD Distributor cap+MSD6AL+MSD coil+cable busi msd,habis berapa y bos?
    bisa naikkin hp berapa jg?
    thanx,pm jg gpp bos
    cipondoh-tangerang
    Smile
    Quote Originally Posted by paulorafael28 View Post
    thanx,pm jg gpp bos
    g pm bro ke u
Datsun 300x250 NGK Busi
  1. AEM PRODUCT MAIN DEALER IN INDONESIA
    By [speed'Z] in forum Speed'Z Performance
    Last Post: 31st October 2016, 02:32
  2. FUEL INJECTOR CLINIC MAIN DEALER IN INDONESIA
  3. EXEDY CLUTCH MAIN DEALER IN INDONESIA
    Last Post: 30th October 2016, 04:32
  4. SARD PRODUCT MAIN DEALER IN INDONESIA
    Last Post: 5th October 2016, 16:33
  5. WELD RACING MAIN DEALER IN INDONESIA
    Last Post: 25th August 2016, 05:22
