Dijual: MB W202 C240 th 2000 (STEPTRONIC)... Travertin beige BOOKED!!!
Results 1 to 10 of 34
  • Short URL:  http://modifika.si/169743
    1 Mth 2 Wks 2 Days 21 Hrs 7 Mins 48 Secs
    ... cuma mau liat2 pasaran dulu aja seh...
    Kebetulan gw punya W202 C240, dengan keadaan ok bgt deh,, seperti yg sebagian tau deh,, kalau gw jual mobil pasti kondisinya harus perfect shape gt deh, baik engine, eksterior, interior......nah cuma gw mau liat dulu deh berapa seh harga yg pantesnya gt dehh.....
    kondisinya:
    - Exterior :
    1) ada sedikit dent di dkt2 pintu.. (akan segera ke PDR utk di sedot DENTnya).
    2) KF V-kool VIP samping2nya
    3) VR 16 Tenhole OEM W210.
    4) Grill S Class (originalnya gw jg masih ada)
    5) Others standard deh
    - Interior :
    1) Black OEM leather seat
    2) Wood panel
    Additional in interior : cm chrome ring AC + shifter ring chrome
    - Engine :
    1) Standard M114 V6 engine 12 busi..>> 2600cc > >178HP STEPTRONIC/ 5 G-TRONIC
    2) Semua dalam kedaan sgt baik deh, dan gak ada oil leak sama sekali
    Other details:
    1) Km 82.214 on going
    2) Sound system :HU Pioneer 5650MP + PIoneer speakers OEM for W202 + Power Velocity 6 channel + Subwoofer Kicker free air.
    3) 6 airbag
    4) ABS+ESP
    5) Cruise Control
    6) 2nd owner with good license number 8448...
    Yang baru saja di repair / revise;
    1) New tie rod set
    2) New Ball joint set
    3) New Shockabsorber F+R
    4) New Engine mounting
    5) New Transmission mounting
    6) New New A/T filter + oil longlife MB 533
    7) New spark plug
    8) New Air filter
    9) New Fuel filter
    10) New Radiator
    11) New Rear differential mounting
    12) New engine mounting
    13) New AIR MASS
    14) New engine oil replacement + filter +/- 1000km
    15) New spark plug Iridium type OEM Mercedes
    16) New Spark plug Cable
    17) New Coil pack
    18) New internal temp sensor
    Repair worth more than Rp 28.mio alias Rp 28.000.000,-
    Minus dan masih jadi tanggung jawabku;
    1) Ganti bushing arm
    2) Tune up + CO revision
    Spek googling yah:
    - 2,597 cc 2.6 liters V6 front engine with 89.9 mm bore, 68.2 mm stroke, 10.5 compression ratio, overhead cam and three valves per cylinder
    - Premium unleaded fuel
    - Power: SAE and 125 kW , 178 HP @ 5,700 rpm; 177 ft lb , 240 Nm @ 4,700 rpm
    - ABS
    - Brake assist system
    - Four disc brakes including two ventilated discs
    - Electronic traction control via ABS & engine management
    - Immobilizer
    - Fullsize steel rim internal spare wheel
    - Stability control
    - Strut front suspension with stabilizer bar independent with coil springs , multi-link rear suspension with stabilizer bar independent with coil springs
    Alasan dijual;;; krn dah gak garasi buat nyimpen lagi ..krn gw mau pertahankan GOLF Mk1 + mini cooper gw....
    Price: Rp 180.000.000,- gak laku gak apa deh
    Pict : gw upload nanti deh yg saat ini....tp waktu gw beli msh ky gini neh... bedanya skr pakai velg OEM W210 krn gwe maunya in std condition.......
    Pict lkp kondisi saat ini:
    http://img31.imageshack.us/g/cimg1460i.jpg/
    http://img11.imageshack.us/g/cimg6969p.jpg/
    2001 Black BMW M3 E46 S54, 2003 Grey green BMW 325i E46,2007 W211 E280 7G AMG Package Avantgarde, 2011 GOLF TSi Shark Blue, 1983 KE 70 GT RALLY Look w 3SGE BEAMS 7 Speed M/T
    6 Mins 26 Secs
    upp... uuppp... uuuppp...
    foto interiornya donk
    Pondok Pinang, Jaksel.
    1 Mth 1 Wk 1 Day 9 Hrs 41 Mins 14 Secs
    mantab bos, hrg nya jg mantab hehe
    Quote Originally Posted by fielder View Post
    nanti deh di update setelah selesai dari GLARE
    Quote Originally Posted by jeki vendetta View Post
    heheheh,, ada yg lebih mantab lagi..tp tungggu deh minggu depan... W210 Advantgarde 57.000km
    Quote Originally Posted by rendy76 View Post
    wew di tunggu bos..
    6 Mins 26 Secs
    ditunggu interiornya bos
    besok sabtu bakal diupdate
    1 Hr 22 Mins 51 Secs
    mana fotonya bro Rendy
    ini W 202 C Class lama ya, belum lampu kacang dong????
    harganya kayaknya tinngi banget ya untuk yang model lama bro....jadi ngga enak juga mao nawarnya....
    Quote Originally Posted by Stevi View Post
    hahahaaha,,, makanya kan gw bilang diatas, yg beli tinggal ngegas doang, kalau mau beli pusing seh beli ajah di poskota atau di WTC tuh minta 155jt warna item, tp yah begitulah.... liat sendiri aja lah...
    and kalau W203 240 harga segini seh busettt.... kmrn temen gwe beli depannya bekas nyundul ajah 210jt th 2001... and gw ejual C240sport 2005 di harga 320jt
MBtech Venom 300x250
  1. MERCY W202 C240 2000
    By Bunet in forum Mercedes-Benz
    Last Post: 1st September 2012, 05:16
  2. DIJUAL C240 W202 TH 2000
    By kacapiring11 in forum Mercedes-Benz
    Last Post: 8th May 2012, 08:34
  3. DIJUAL C240 W202 TH 2000
    Last Post: 27th April 2012, 05:16
  4. WTS C240 (W202) AT tn 2000 Elg tgn 1 biru tua...
    By 236CC in forum Mercedes-Benz
    Last Post: 21st February 2012, 14:53
  5. for sale mercy c240 2000 AT w202
    By abbymanyu in forum Merk Lainnya
    Last Post: 7th July 2010, 06:38
