PROJECT MU BRAKE PAD DEALER IN INDONESIA - Page 14
Page 14 of 14 FirstFirst ... 1011121314
Results 131 to 135 of 135
  • Short URL:  http://modifika.si/169659
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    Auto Update promo Februari 2016 for Big Brake Kit AP RACING and BREMBO.
    We bring genuine big brake kit BREMBO and AP RACING ,we supply for INDONESIA and MALAYSIA market, many installation in customer car and dealer wanted.
    __-AP Racing made in UNITED KINGDOM -__
    -CP7600 caliper 4 pot ,AP disbrake 295mm floating slotted ,AP brake pad APF 404,HEL Brake hose harga 24 jt(black caliper) dan harga 25,5 jt (red caliper ) applikasi utk velg 15-16 inch.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad APF 404, HEL brake hose dengan harga 29 jt (black caliper) dan 30,5 jt (red caliper)applikasi utk velg 17 inch.
    -CP 5040 race caliper 4 pot, AP discbrake floating slotted 330mm, AP brake pad APF 402, HEL brake hose harga 36 jt. (applikasi utk velg 17 inch).
    -CP 9040 caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, HEL brake hose harga 36 jt (black caliper) dan 37,5 jt( red caliper) applikasi utk velg 18inch
    *dengan discbrake floating slotted 362mm harga 39 jt.(applikasi utk velg 19 inch).
    **** BREMBO Made in ITALY ****
    -Brembo GT 4 pot,brembo brake pad,brake hose with center bell plug & play alumunium and adaptor.
    *Dengan floating drilled discbrake 355mm harga 39 Jt.(velg minimal 18 inch)
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch)
    ---extra 4 jt apabila dipasang ke caliper belakang --------
    -BREMBO 17Z 6 pot,BREMBO brake pad,with center bell plug & play alumunium and adaptor dengan discbrake floating drilled 355mm harga 38 jt.(velg minimal 18 inch)
    -BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan discbrake 380mm floating drilled harga 44 jt.(velg minimal 19inch)
    **dengan floating drilled disbrake 405mm harga 46 jt. (velg minimal 20 inch)
    -BREMBO GT 6 pot.BREMBO brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    -BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad With Discbrake 345MM Floating Drilled Harga 35 JT.(velg minimal 18 inch)
    **Discbrake 380Mm Floating Drilled HARGA 38 JT.(velg minimal 19 inch).
    -BREMBO 4POT Model 6 (For Rear use only ),BREMBO Brake Pad With Discbrake 345MM Floating Discbrake Harga 33 JT.(velg minimal 18 inch)
    **Discbrake 380MM Floating Drilled Harga 36 JT.(velg minimal 19 inch).
    For Order Call/Whatsapp:
    081382077777-085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    JALAN BIAK NO 48-48A
    JAKARTA PUSAT 10150
  2. #132
    cipondoh-tangerang
    -BREMBO 17Z 6 pot,BREMBO brake pad,with center bell plug & play alumunium and adaptor dengan discbrake floating drilled 355mm harga 38 jt.(velg minimal 18 inch).
    **dengan floating drilled disbrake 405mm harga 46 jt. (velg minimal 20 inch).
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
  3. #133
    cipondoh-tangerang
    Auto Update promo Maret 2016 for Big Brake Kit AP RACING and BREMBO.
    SPEEDZ PERFORMANCE
    Tangerang 11750
  4. #134
    cipondoh-tangerang
    PEED'Z PERFORMANCE by STZ ,It has over 17 years’ experience and specialized in distribution high end performance engine racing parts, bring high end brake system to providing the best brake system to consumers.It is for supply With the effort of SPEED’Z strong team, excellent sales , SPEED:Z has been successfully make pre-sales and after-sales value-added services to our business partners.for call/whatsapp 081382077777-082312077777(Hans SPEED'Z PERFORMANCE)
  5. #135
    cipondoh-tangerang
    Update price BBK oktober
    AP RACING MADE IN UNITED KINGDOM
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404,HEL Brake hose,Cnter hub +adaptor.
    *dengan discbrake 285mm(min velg 15 inch) harga 24 jt
    *dengan discbrake 295mm(min velg 16 inch) harga 25.5 jt
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min 17 inch) harga 29 jt.
    -CP9200 caliper 4 pot (new model caliper), AP discbrake floating slotted, AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min 17 inch) harga 30 jt.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min17 inch) harga 36 jt.
    -CP 9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 355mm(min velg 18 inch) harga 36jt.
    *dengan discbrake 362mm(min velg 18-19 inch) harga 38 jt.
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, HEL brake ,Center hub+adptor.
    *dengan discbrake 355mm (velg min 18 inch) harga 43jt.
    *dengan discbrake 362mm (velg min 18-19 inch)harga 45 jt.
    NEW and ready stock AP RACING World RADI-CAL Caliper new design futuristic and with new model Floating J-Hook design .
    -CP 8520 caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose.
    ** AP discbrake floating Curved Groove 370mm (velg minimal 18 inch) harga 47 jt
    **AP discbrake floating J-hook 370mm (velg minimal 18 inch) harga 47 jt
    **AP discbrake floating J-hook floating 380mm (velg minimal 19 inch)harga 48 jt
    **AP discbrake floating J-hook 390mm(velg minimal 20 inch) harga 49 jt.
    **AP discbrake floating J-hook 410mm (velg minimal 21-22inch)harga 52 jt.
    CP8530 caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose .
    **AP discbrake Floating J-hook 360 mm(velg minimal 19 inch)harga 42 jt.
    **AP discbrake floating J-hook 380 mm(velg minimal 20 inch) harga 43,5 jt.
    Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug & play alumunium and adaptor.
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch).
    -BREMBO GT 6 pot,brembo brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    New and just coming in stock
    -BREMBO GT 8 pot.brembo brake pad .duralium center bell and adaptor plug and play of specific car
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 20 inch ) Harga 50 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 21-22 Inch) Harga 52 Jt.
    dapetkan potongan setiap pembelianbig brake kit depan + belakang dapetkan potongan harga 3 jt (extra pemotongan for customer).
    081382077777-082312077777 (HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Cipondoh-Tangerang 11750
Venom 300x250 Wuling
  1. WTS : Brake Pad Project MU for BBK Project MU mini 4pot
    By kto in forum Bursa Kaki Lainnya
    Last Post: 7th November 2012, 11:06
  2. WTS Disc Brake : J'S Racing + Brake pad project mu
    By Oi Oz in forum Per & Shockbreaker
    Last Post: 9th April 2011, 09:33
  3. WTS 2ND BRAKE KIT PROJECT MU
    By Pedagang_SBY in forum Per & Shockbreaker
    Last Post: 24th December 2010, 06:51
