CUSCO MAIN DISTRUTOR IN INDONESIA - Page 22
Page 22 of 22 FirstFirst ... 1819202122
Results 211 to 213 of 213
  • Short URL:  http://modifika.si/169658
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    ++++PROMO BIG BRAKE KIT AP RACING AND BREMBO++++++
    WE BRING GENUINE BIG BRAKE KIT BREMBO AND AP RACING,WE SUPPLY FOR INDONESIA AND MALAYSIA MARKET AND MANY INSTALLATION IN CUSTOMER CAR.
    ************* AP RACING MADE IN UNITED KINGDOM ***********
    *****NEW RADI-CAL(NEW DESIGN)**********
    -CP 8520 NEW RADI-CAL CALIPER 6 POT ,AP DISCBRAKE 355MM FLOATING SLOTTED ,AP BRAKE PAD APF 404,AP BRAKE HOSE HARGA 39 JT (BLACK) DAN HARGA 40,5 JT (RED)
    **AP DISCBRAKE 362 MM FLOATING SLOTTED 42 JT.
    **AP DISCBRAKE 380MM FLOATING SLOTTED 45 JT.
    -CP 8530 NEW RADI-CAL CALIPER 4 POT,AP DISCBRAKE 330MM FLOATING SLOTTED , AP BRAKE PAD APF 404. AP BRAKE HOSE HARGA 32JT (BLACK ) DAN HARGA 33,5 JT(RED)
    **AP DISCBRAKE 345MM FLOATING SLOTTED HARGA 35JT.
    **AP DISCBRAKE 355MM FLOATING SLOTTED HARGA 38 JT.
    -CP7600 BLACK CALIPER 4 POT , AP DISCBRAKE 295MM FLOATING SLOTTED .AP BRAKE PAD APF 404 .BRAKE HOSE HARGA 24 JT.
    -CP 5200 BLACK CALIPER 4 POT , AP DISCBRAKE FLOATING SLOTTED 330MM, AP BRAKE PAD APF 404, BRAKE HOSE DENGAN HARGA 27 JT DAN 28,5 JT APABILA RED CALIPER.
    -CP 5040 RACE CALIPER 4 POT, AP DISCBRAKE FLOATING SLOTTED 330MM, AP BRAKE PAD APF 402, BRAKE HOSE HARGA 34 JT.
    -CP 9040 BLACK CALIPER 6 POT , AP DISCBRAKE 355MM FLOATING SLOTTED , AP BRAKE PAD APF 404, BRAKE HOSE HARGA 34 JT DAN 35,5 JT APABILA RED CALIPER.
    **DENGAN DISCBRAKE FLOATING SLOTTED 362MM HARGA 36 JT.
    ********** BREMBO MADE IN ITALY **************
    -BREMBO GT 4 POT,BREMBO BRAKE PAD,BRAKE HOSE WITH CENTER BELL PLUG & PLAY ALUMUNIUM AND ADAPTOR.
    **DENGAN DISCBRAKE FLOATING DRILLED 330MM HARGA 34 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 345MM HARGA 36 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 355MM HARGA 37 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 380MM HARGA 39 JT.
    -BREMBO 17Z 6 POT,BREMBO BRAKE PAD,WITH CENTER BELL PLUG & PLAY ALUMUNIUM AND ADAPTOR DENGAN DISCBRAKE FLOATING DRILLED 355MM HARGA 37 JT.
    -BREMBO 19Z 6 POT ,BREMBO BRAKE PAD WITH CENTER BELL PLUG & PLAY ALUMUNIUM , AND ADAPTOR DENGAN DISCBRAKE 380MM FLOATING DRILLED HARGA 43 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 380MM HARGA 45 JT.
    -BREMBO GT 6 POT.BREMBO BRAKE PAD GT,BRAKE HOSE WITH CENTER BELL PLUG N PLAY ALUMUNIUM DAN ADAPTOR.
    **DENGAN DISCBRAKE FLOATING DRILLED 355MM(BUAT VELG MINIMAL 18 INCH) HARGA 45 JT.
    **DENGAN DISCBRAKE FLOATING DRILLED 380 MM(BUAT VELG MINIMAL 19 INCH ) HARGA 47 JT.
    **DENGAN DISCBRAKE FLOATING DRILLED 405MM(BUAT VELG MINIMAL 20 INCH) HARGA 49 JT.
    -BREMBO REAR PORSCHE NEW CAYENNE CALIPER (FOR REAR USE ONLY),BREMBO BRAKE PAD WITH DISCBRAKE 345MM FLOATING DRILLED HARGA 34 JT.
    **DISCBRAKE 380MM FLOATING DRILLED HARGA 37 JT.
    -BREMBO 4POT MODEL 7L6 (FOR REAR USE ONLY ),BREMBO BRAKE PAD WITH DISCBRAKE 345MM FLOATING DRILLED HARGA 32 JT.
    **DISCBRAKE 380MM FLOATING DRILLED HARGA 35 JT.
    FOR ORDER CALL/WHATSAPP:081382077777/085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    JALAN BIAK NO 48-48A
    JAKARTA PUSAT 10150
  2. #212
    cipondoh-tangerang
    Auto Update Harga di bulan April 2016 for Big Brake Kit AP RACING and BREMBO.
    We bring genuine big brake kit BREMBO and AP RACING ,we supply for INDONESIA and MALAYSIA market, and many installation in customer car & dealer wanted.
    *****AP Racing made in UNITED KINGDOM*********
    -CP7600 caliper 4 pot ,AP disbrake 295mm floating slotted ,AP brake pad APF 404,HEL Brake hose harga 24 jt(black caliper) dan harga 25,5 jt (red caliper ) applikasi utk velg 15-16 inch.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad APF 404, HEL brake hose dengan harga 29 jt (black caliper) dan 30,5 jt (red caliper) applikasi utk velg 17 inch.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted 330mm, AP brake pad APF 402, HEL brake hose harga 36 jt. (applikasi utk velg 17 inch).
    -CP 9040 caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, HEL brake hose harga 36 jt (black caliper) dan 37,5 jt( red caliper) applikasi utk velg 18inch
    *dengan discbrake floating slotted 362mm harga 39 jt.(applikasi utk velg 19 inch).
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake 355mm floating slotted , AP brake pad APF 402, HEL brake hose harga 42 jt. (applikasi utk velg 18inch)
    *dengan discbrake floating slotted 362mm harga 45 jt.(applikasi utk velg 19 inch).
    **** BREMBO Made in ITALY ********
    -Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug & play alumunium and adaptor.
    *Dengan floating drilled discbrake 355mm harga 39 Jt.(velg minimal 18 inch)
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch)
    ---extra 4 jt apabila dipasang ke caliper belakang karena pembuatan center bell besar --------
    -BREMBO 17Z caliper 6 pot,BREMBO brake pad,with center bell plug & play alumunium and adaptor dengan discbrake floating drilled 355mm & brake hose harga 38 jt.(velg minimal 18 inch).
    -BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan discbrake 380mm floating drilled harga 44 jt.(velg minimal 19inch)
    **dengan floating drilled disbrake 405mm harga 46 jt. (velg minimal 20 inch).
    -BREMBO GT 6 pot.BREMBO brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    -BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad With Discbrake 345MM Floating Drilled Harga 35 JT.(velg minimal 18 inch)
    **Discbrake 380Mm Floating Drilled HARGA 38 JT.(velg minimal 19 inch).
    -BREMBO 4POT Model 7L6 (For Rear use only ),BREMBO Brake Pad With Discbrake 345MM Floating Discbrake Harga 33 JT.(velg minimal 18 inch)
    **Discbrake 380MM Floating Drilled Harga 36 JT.(velg minimal 19 inch).
    $$$$$---untuk pembelian big brake kit depan+belakang dapetkan potongan harga 3 jt-----$$$$$
    For Order Call/Whatsapp:
    081382077777-085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Tangerang 11750
  3. #213
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    Tangerang 11750
  1. PIVOT MAIN DISTRIBUTOR IN INDONESIA
    By [speed'Z] in forum Speed'Z Performance
    Last Post: 25th February 2018, 03:40
  2. MSD MAIN DEALER IN INDONESIA
  3. TURBOSMART MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 31st October 2016, 02:33
  4. A'PEX-i MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 6th October 2016, 16:18
  5. T.M. WORKS MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 19th September 2015, 15:35
